Discussions related to PC-3000
Please no pirated software here!
Seagate age99
August 7th, 2007, 8:39
HI
I have a segate ST3500841A fw3.AAE(TONKA4D) with many bad sectors.
in the beginning i tried logical scan and hide to p-list butt did not work because i keep getting a write error at plist writhing
so i tried self scan butt the test ended in age99(i think is an error). i tried for 2 times( same result)
Begin Test 99
ASCII logging on
ASCII logging off
ASCII logging on
TestIndex=20/111, Stage 1/1, Prev test 56, Next test 10
ASCII logging off
Test=99, Feature=0, cumhlth=0008, curhlth=0000
OkEnd Test 99
T>
now i rewrite cert, overlay, vendor and the hdd is detected ok butt the reserved track list,user track list and, alt list are empty and the hdd is full of bad sectors
i have attached a file with the self scan report
anyone know haw to repair this drive?
thanks
seagate500G.txt
(214.73 KiB) Downloaded 1003 times
Re: Seagate age99
August 8th, 2007, 9:11
nobody knows?
Re: Seagate age99
August 8th, 2007, 12:57
continue ^T
Re: Seagate age99
January 15th, 2008, 10:17
N50,,22
T50
AND THEN N10,,22
.....WAIT FOR FINISHING
Re: Seagate age99
August 3rd, 2008, 11:29
mulan wrote:HI
Begin Test 99
ASCII logging on
ASCII logging off
ASCII logging on
ASCII logging off
OkEnd Test 99
T>
thanks
/T
N10,,22
ctrl+t
RUN TEST,until the test end
DON'T power off,write ovelay ,vendor,save to disk
this disk will be repaired.
good luck for you
Re: Seagate age99
August 4th, 2008, 14:25
These newer seagate drives use two selfscan after first finishes u have to give CTRL+T to start with the second one .
Re: Seagate age99
August 15th, 2008, 9:26
It's at test 99 when the past tests are checked and overlay's etc are loaded in the factory
