Discussions related to PC-3000
Please no pirated software here!
Jumper setting problems with Toshiba
August 26th, 2008, 17:41
Good day gurus,
I am trying to recover data from a Toshiba MK8025GAS and went I plug it in, Christmas lights light up. I tried other jumper settings and same thing. I tried a working Toshiba MK8025GAS and went from busy to ready. I moved jumpers around with working Toshiba and it went from busy to ready.
Any thoughts?
I am confused.
Re: Jumper setting problems with Toshiba
August 26th, 2008, 18:14
If i understand clearly, you have pcb problem.
I suggest to resolder the ee, and try the new pcb...
(Additionally, not exactly in this case, but generally take care about random jumpering, because you can damage the pcb!
You can short some gnd and 5V lines, or 2 output pins with different logical level, or can drive overvoltage to the 2V7 or 3V3 serial input/output on another drives....)
Regards,
Janos
August 26th, 2008, 18:40
If that is the case, I have a pretty much unrecoverable drive because of the NVRAM or ROM. Correct?
August 26th, 2008, 18:57
how-swap-toshiba-pcb-any-tips-t9265.html?hilit=toshiba%20rom%20pcb
August 27th, 2008, 4:00
From the main PC3000 screen you need to select TOOLS --> CABLE SELECT CONTROL --> ATA0/1 depending on the channel your toshiba is connected to.
August 27th, 2008, 9:43
Thank you all for your assistance. I was able to head swap and dd drive and recover it.
