 Post subject: I have problem in WD 800BB-00FJA0
PostPosted: November 12th, 2008, 8:18
PC-3000 detect Model: Rom Model mamoth
iI run kernel mode and write new rom into drive but the drive after update dos not work
the servo dos not work and the HSA stoped
and PC3000 cann't detect it (as if there is no power connected )
what should i do plese help me
 Post subject: Re: I have problem in WD 800BB-00FJA0
PostPosted: November 12th, 2008, 9:55
I believe you killed your ROM chip on that board.
You have to find a new board with matching firmware.
www.datarecoveryne.com
PostPosted: November 12th, 2008, 11:14
What do u need repair it or DR?
PostPosted: November 12th, 2008, 20:38
hello,
have succeed for updata ROM? if yes. i am sure you wrote ROM is wrong and the motor will not spin up!
data recovery service[/b]
PostPosted: November 28th, 2008, 5:12
thank you friends
PostPosted: November 28th, 2008, 6:55
Yes, you've almost certainly ruined the ROM on the PCB.
Good luck, you'll need it! ;-)
Users browsing this forum: No registered users and 110 guests
