 Post subject: SEAGATE SELFSCAN
PostPosted: November 20th, 2008, 15:53
Hi, anyone know this
Afther a selfscan it appear´s this message:
Interface task reset
1024k x 16 buffer detected
SNOWMASS - 2_Disk 3.19 11-20-01 12:12
Power Cycling
ATReset
Head Mask 000F - Switch to full int.
Spin Ready
Begin Test 08
Not Power Cycling
SkpCylList deleted
Sys= 7000-7028 02B9 SPTK on sys trks
<empty>
drive must be reformatted
EP=0, TA=0, HiGain=1, OTRd=0, Early Rd=0, Splash=1, Reload=1, VCO=1, MRBias=1
Bst/Zap=0, SrvoThrsh=1, RunOut=1, MaxECC=1, ECC 2=1, ECC 1=1, ECC 0=1
Data=FF, Write=80, ID=FF
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: SEAGATE SELFSCAN
PostPosted: November 20th, 2008, 17:08
are you sure it's complete? i don't think so!
data recovery service[/b]
PostPosted: November 21st, 2008, 17:18
Let the test complete test 8 takes alot of time be petient .
PostPosted: November 28th, 2008, 9:58
I've never had much luck with Seagate's selfscan. I think it should be renamed, "self-destruct."
I've used it with drives that had problems. After running the test(s), the drives would always be busy and never come ready.
Impressive amount of test messages from terminal mode, though!
http://www.datasaversllc.com
