 Post subject: WD400BB not rewriter firmware
PostPosted: December 8th, 2008, 3:44
WD400BB-00jha0
Family:sabre53
Techno mode key:
Tech on................................. : Ok
RAM:
Soft reset ...
Ok
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected 51/04 (ABR)
Head number reading..................... : Ok
Heads number............................ : 1
ROM:
ROM reading............................. : Ok
Heads configuration..................... : by map
Heads number in use..................... : 1
Switched off heads...................... : No
Head map................................ : 0
Service area:
SA dir reading.......................... : SA Dir data reading error
Configuration reading................... : Module 02 not found
Utility status
HDD pameters:
Cylinders number 0
Heads number 1
SA SPT 0
 Post subject: Re: WD400BB not rewriter firmware
PostPosted: December 8th, 2008, 5:10
WD400BB is a Caviar16 drive last time I checked...
PostPosted: December 8th, 2008, 5:22
Family:sabre53
Black
PostPosted: December 8th, 2008, 7:31
WDxxxBB-JHxx is Sabre
This looks like a head problem to me.
PostPosted: December 8th, 2008, 9:02
head is ok
because writer bad other firmware...
PostPosted: December 8th, 2008, 14:32
Sorry had a momentary brain fart. Did you try a resources track scan of head 0?
