 Post subject: Seagate 160GB PATA issue with System Area
PostPosted: May 4th, 2009, 6:43
Got a 160GB Seagate PATA HDD, when connected to the Termial it tries reading and gives out erros like :
AutoRead Err
Auto Read Err 47 ..
Pri master
and I am not able to access the drive.
Any idea what is wrong ??
Cheers,
 Post subject: Re: Seagate 160GB PATA issue with System Area
PostPosted: May 4th, 2009, 7:27
The "master" indicates the the drive has eventually started up from the SA, but the "Autoread" messages indicate that it was struggling badly to do so,
My guess is weak/dirty heads. Head stack replacement almost certainly required.
It "may" be worth cleaning the contacts on the PCB that connect it to the HDA. You'll have to remove the PCB and clean with a pencil eraser.
PostPosted: May 4th, 2009, 9:37
Can the bad head be deactivated and activate anither one.
/8
8>H1
8> C18,
Does linearization help.
any help is appreciated.
Cheers,
