 Post subject: PC3000 UDMA - IDE Ribbon Cable
PostPosted: July 26th, 2009, 6:54
Does anyone know where to get the IDE Cable that comes with PC3000 UDMA, I like it because its robustness and the cable is not stiff and very flexible.
 Post subject: Re: PC3000 UDMA - IDE Ribbon Cable
PostPosted: July 27th, 2009, 15:39
Did you try contacting ACE? It is possible that they custom made the cables, just to give the extended length.
PostPosted: July 27th, 2009, 15:41
I have contacted Ace on a few occasions where I need replacement parts such as adaptors and cables, and I am pretty sure you can purchase extras from them
PostPosted: July 28th, 2009, 0:37
You can make few for yourself, just get a hold of the cable.
www.datarecoveryne.com
PostPosted: July 28th, 2009, 8:31
i have a problem with my HD ..because it not detect the data...when i put in my computer i hear sound like the magnetic "tick" ...so how to recovery data from my hard disk broken ... does PC3000UDMA solve this problem for me? Thx!
PostPosted: July 28th, 2009, 19:24
Hi
Pc3000UDMA won't solve the issue for you.
An expert tool requires expert knowledge to work with.
The very basic thing in DR is proper diagnostics, so if u need your data back you'd be better have a pro look at it.
