 Post subject: WD400BB-77AUA1 - PCB dead !!!
PostPosted: September 5th, 2009, 7:41
Hi to all,
Have this disk WD400BB-77AUA1, when i connect to the udma it stays BSY forever.
So i found a similiar PCB
Patiente: 000 001003-001 G
Donor : 000 001003-000 C
When i change it , i could have ID, serial size, all the modules are ok in the utility, and i see two heads 0 1
I test the SA copy in the Composite reading , Copy 0 , Copy 1, and all the modules are green.
The info from service tracks i have this error but i think is normal for this model
Cyl -9; Head 0.......................... : Ok
WD Techno Read Error C/H/S: -9/1/280 Device Error Detected 59/40 (UNC)
WD Techno Read Error C/H/S: -9/1/327 Device Error Detected 59/40 (UNC)
Cyl -20; Head 0......................... : Ok
WD Techno Read Error C/H/S: -20/1/1 Device Error Detected 59/01 (AMN)
WD Techno Read Error C/H/S: -20/1/519 Device Error Detected 59/01 (AMN)
Cyl -20; Head 1......................... : Ok
When i start in DE and build the head maps it appear 3 Heads.
i start to clone, and i just can clone 41 215 sectors, after disk it give error reading any sector
Anyone have an opinion about this.
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: WD400BB-77AUA1 - PCB dead !!!
PostPosted: September 5th, 2009, 8:36
This HDD will have 3 heads enabled...
PS Probably U use PCB from 20GB or 30GB donor...
Mikippp
PostPosted: September 6th, 2009, 11:11
change the ROM from original pcb to this donor pcb .
PostPosted: September 7th, 2009, 10:02
Thanks to all,
I prefer to try first just to write a ROM do the patient PCB.
Anyone have this ROM, WD400BB-77AUA1
ZeBong
ZeBong
" Россия еще раз"
PostPosted: September 7th, 2009, 10:31
U not need ROM...
U must enable more 1 head...
PS In this PCB ROM may be saved in Flash, or in Eprom...
Mikippp
PostPosted: September 7th, 2009, 16:37
Thanks Mikippp, the donor PCB was from a 20GB disk.
Can anoyone knows how much heads have this model ?
I enable one more head, and now in DE it appear 4 Heads.
Tomorow i will enable other Head, but would like to know if this model have 4 heads.
ZeBong
ZeBong
" Россия еще раз"
PostPosted: September 8th, 2009, 6:20
Enable 4 Heads, and cloning 100%
Thanks Mikippp :D
ZeBong
" Россия еще раз"
