Page 1 of 1
Barracuda 7200.9 stays busy
Posted: September 29th, 2008, 8:06
by yco
Hello everybody.
I have Seagate drive that makes one knock and stays BSY.
PC3K Terminal output:
Head Mask FFFF - Switch to full int.
              Spin Ready
Error Reading Application Code
F>
when I tried
F>j
and it says:
Application code incompatible with serial flash code
    Code - 76  Track 15873.0.01E  Sns 01E
Model: ST3500641AS
F/W: 2.AAA
DateCode: 06132
SiteCode: AMK
Any ideas weather it can be fixed with PC3K utility or does it need head/controller replacement?
Thanks for any response.
Re: Barracuda 7200.9 stays busy
Posted: September 29th, 2008, 8:20
by dobrevjetser
Application code cannot be read. Try using a loader.
Best regards,
Dobre
Posted: September 29th, 2008, 8:43
by pcimage
Are you 100% sure this if the ORIGINAL PCB?
Posted: September 29th, 2008, 11:52
by msurgeon
void message
Posted: September 29th, 2008, 11:58
by msurgeon
pcimage wrote:Are you 100% sure this if the ORIGINAL PCB?
That's a valid question: app code mismatch with flash ROM can indicate the board was swapped. You can try copying the ROM from same drive and firmware onto the current PCB but, if it turns out PCB is not original, always best to get hold of original.
Posted: September 29th, 2008, 12:36
by rameez
I dont think this is a problem of pcb mismatch i think APP code is corrupted .
Posted: September 29th, 2008, 18:50
by networkpc3000
PCB flash problem, write the flash can be solve the problem
Sunny
Posted: October 1st, 2008, 11:55
by yco
Thanks for all replies. I do not know if this is original PCB, that was my first thought when I saw "Application code incompatible with serial flash code". Will try to get replacement controller and check that (it is not very urgent). Otherwise I will use new drive to create loader and try it that way.
