Strange samsung HD321KJ problem
http://forum.hddguru.com/viewtopic.php?f=11&t=10035
Author:  thatdellguy [ October 1st, 2008, 22:30 ]
Post subject:  Strange samsung HD321KJ problem
I have this Samsung drive that does not ID but reports ready The terminal looks normal when compared to another drive but when you try to read a sector or firmware it goes busy. Once it goes busy a hard reset puts it ready again. Drive does not make any clicking noises and spins up and stays on. I'm thinking pcb but not really sure. Attached is the terminal log. Any help would be apreciated. Thanks
Author:  Doomer [ October 1st, 2008, 22:37 ]
Post subject:  Re: Strange samsung HD321KJ problem
Samsungs don't like PATA-SATA adapters could it be a problem?
Author:  thatdellguy [ October 1st, 2008, 23:05 ]
Tried without the PATA adapter but bios does not pick up the drive. MHDD sees the port as BSY. RST makes it ready but goes back to BSY on EID command. Any attempts at reading the surface result in BSY.
Author:  Doomer [ October 2nd, 2008, 0:10 ]
Might be bad PCB then
IMHO
Author:  thatdellguy [ October 2nd, 2008, 19:19 ]
Thanks Doomer.
Author:  networkpc3000 [ October 8th, 2008, 5:35 ]
hello,
i see some Samsung drive just spin up 4 second after down. and state busy. i start self-test direct. as if you make drive without busy state. but have bad sector you can not do any thing also. so i will start SF! my experensive just for reference. may be i am wrong.
Thanks & best regard.
Sunny
Author:  Doomer [ October 8th, 2008, 12:43 ]
networkpc3000 wrote:
hello,
That's SA problem
Author:  networkpc3000 [ October 8th, 2008, 19:16 ]
Dear Doomer,
oh....thanks for your help! buy i can not rest. then what can i do for this kind of drives? pleasse advice. thank you!
Thanks & best regard!
Sunny
Author:  Doomer [ October 8th, 2008, 22:51 ]
you need to find out exact problem and fix it
start problems search from A-List module
Author:  rameez [ October 9th, 2008, 12:11 ]
U can fix the SA using H/T test in these drives if u dont need data .
Author:  networkpc3000 [ October 9th, 2008, 19:55 ]
dear Doomer/Rameez,
thanks for your help. if the head problem what can i do? as i have one SATA drive have haed problem. which model i need to revise? please advice if you know about it.thanks
Sunny
