 Post subject: Need ROM WD2000JD-22HBB0
PostPosted: October 3rd, 2008, 23:36
Does anyone have to share?
 Post subject: Re: Need ROM WD2000JD-22HBB0
PostPosted: October 4th, 2008, 10:19
I beleive the answer is no
Nobody has to share anything here
It's all by free will
PostPosted: October 4th, 2008, 11:27
I command you to give it to me! The information must leak! :)
PostPosted: October 7th, 2008, 21:38
add my MSN,if i have i will share to you
data recovery service[/b]
PostPosted: October 7th, 2008, 23:05
I have 2 WD2000JD-22HBB0 boards.
Any chance you might transfer the ROM/FIRMWARE from the bad board to the donor PCB board?
Meanwhile you can get your ROM.
PostPosted: October 8th, 2008, 0:08
rchadwick, which version do you need?
PostPosted: October 8th, 2008, 0:42
Actually, I should be good now. I have a donor on the way. Thanks everyone.
