 Post subject: Format SA using PC3K
PostPosted: October 5th, 2008, 13:51
Hello firend in the net,
Is there any body know how to FORMAT SA for Maxtor Drive using PC3K? this format SA can be done using Salvation and as an available menu. Maybe some trick needed in PC3K.
Thank you and love
Sharon.
:D
 Post subject: Re: Format SA using PC3K
PostPosted: October 6th, 2008, 4:17
What exactly do you mean by Format?
PostPosted: October 6th, 2008, 12:49
The pc3k utility does not have the Format SA option in maxtor but has in WD .
PostPosted: October 7th, 2008, 21:30
Rameez is right. what your problem, tell us more detail, may be we can help you solve the problem. 8)
data recovery service[/b]
PostPosted: October 21st, 2008, 11:11
use C loader and start selfscan from C
PostPosted: October 21st, 2008, 11:57
-first thank you guys.
-second. problem is : some sa file still bad after several time rewrite from db. by format sa from salvation them the surface is okey them rewrite group and all module.
- third. start from C is okey but seem only fix the hdd sometimes but sa area sometimes still bad.
- four. still awaiting any sugesstion.
Thank you and love.
Sharon :lol:
PostPosted: October 21st, 2008, 14:24
If SA-C selfscan completes successfully its ok if not throw the drive away u will not be able to repair it .
PostPosted: October 21st, 2008, 16:28
Sharon,
Do you happen to work for Salvation, by any chance? ;-)
PostPosted: October 25th, 2008, 16:56
pcimage wrote:
Sharon,
yes. after format the sa then all module group and module can be upload smoothly. but it takes time. that why ask question for pc3k and also more familiar.
Thank you anyway for all the answer guys.
Sharon.
Users browsing this forum: No registered users and 102 guests
