Page 1 of 1
Format SA using PC3K
Posted: October 5th, 2008, 13:51
by sharon
Hello firend in the net,
Is there any body know how to FORMAT SA for Maxtor Drive using PC3K? this format SA can be done using Salvation and as an available menu. Maybe some trick needed in PC3K.
Thank you and love
Sharon.
:D
Re: Format SA using PC3K
Posted: October 6th, 2008, 4:17
by hddguy
What exactly do you mean by Format?
Posted: October 6th, 2008, 12:49
by rameez
The pc3k utility does not have the Format SA option in maxtor but has in WD .
Posted: October 7th, 2008, 21:30
by networkpc3000
Rameez is right. what your problem, tell us more detail, may be we can help you solve the problem. 8)
Posted: October 21st, 2008, 11:11
by pkure
use C loader and start selfscan from C
Posted: October 21st, 2008, 11:57
by sharon
pkure wrote:use C loader and start selfscan from C
-first thank you guys.
-second. problem is : some sa file still bad after several time rewrite from db. by format sa from salvation them the surface is okey them rewrite group and all module.
- third. start from C is okey but seem only fix the hdd sometimes but sa area sometimes still bad.
- four. still awaiting any sugesstion.
Thank you and love.
Sharon :lol:
Posted: October 21st, 2008, 14:24
by rameez
If SA-C selfscan completes successfully its ok if not throw the drive away u will not be able to repair it .
Posted: October 21st, 2008, 16:28
by pcimage
Sharon,
Do you happen to work for Salvation, by any chance? ;-)
Posted: October 25th, 2008, 16:56
by sharon
pcimage wrote:Sharon,
yes. after format the sa then all module group and module can be upload smoothly. but it takes time. that why ask question for pc3k and also more familiar.
Thank you anyway for all the answer guys.
Sharon.
