WD5000AAVS-00ZTB0
Posted: November 4th, 2008, 19:14
by zebong
Anyone was made this disk on the pc3kumda.
WD5000AAVS-00ZTB0
Techno mode key
Techno mode key......................... : Ok
RAM:
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected: "VSCE PERM OVL NOT LOADED"
SA SPT.................................. : SA SPT determination error Techno CMD sending error Device Error Detected: "SERVO ERROR CODE BASE SvirCalRRO Hd1"
Head number reading..................... : Ok
Heads number............................ : 4
ROM:
Flash Dir reading....................... : Ok
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 5C.3BG
ROM generation.......................... : 5C.3BG
Link table version...................... : 01.42.
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Head map................................ : 0,1,2,3
Firmware version........................ : 005C003B
Service area:
SA dir reading.......................... : Unknown error. Code(0)
SA Copies avalabled..................... : NONE
Configuration reading................... : Module 02 not found
ZeBong
Re: WD5000AAVS-00ZTB0
Posted: November 4th, 2008, 19:19
by Doomer
If it clicks it's most likely heads problem
Posted: November 4th, 2008, 19:38
by zebong
Hi thanks,
but i have some questions because i can make some backups off the ROM.
when i do a SA Structure test
it give this :
Id :Copy: Importance: ABA :Size:Read : Hdr : CS : CS Value: Vers. : Desription
MODULES DIRECTORY (01)
Not found in SA directory
CONFIGURATION MODULE (02)
Log DCM (C5)
But i can make a HDD resources backup
Read ROM
Into file............................... : <HDD Profile>\Data\SABackup\ROM\ROM.bin
Ok
Read ROM modules
Module : 0A............................. : Ok
Module : 0B............................. : Ok
Module : 30............................. : Ok
Module : 47............................. : Ok
Module : 0D............................. : Ok
Module : 4F............................. : Ok
Reading modules
Into folder............................. : <HDD Profile>\Data\SABackup\Modules\
Reading service tracks
Into folder............................. : <HDD Profile>\Data\SABackup\Tracks
Reading heads........................... : 0,1
Cyl -1; Head 0.......................... : Ok
Cyl -1; Head 1.......................... : Ok
Cyl -2; Head 0.......................... : Ok
Cyl -2; Head 1.......................... : Ok
Cyl -3; Head 0.......................... : Ok
Cyl -3; Head 1.......................... : Ok
Cyl -4; Head 0.......................... : Ok
Cyl -4; Head 1.......................... : Ok
Cyl -5; Head 0.......................... : Ok
Cyl -5; Head 1.......................... : Ok
Cyl -6; Head 0.......................... : Ok
Cyl -6; Head 1.......................... : Ok
Cyl -7; Head 0.......................... : Ok
Cyl -7; Head 1.......................... : Ok
Cyl -8; Head 0.......................... : Ok
Cyl -8; Head 1.......................... : Ok
Cyl -9; Head 0.......................... : Ok
Cyl -9; Head 1.......................... : Ok
Cyl -10; Head 0......................... : Ok
Cyl -10; Head 1......................... : Ok
Cyl -160; Head 0........................ : Ok
Cyl -160; Head 1........................ : Ok
Cyl -161; Head 0........................ : Ok
Cyl -161; Head 1........................ : Ok
Cyl -162; Head 0........................ : Ok
Cyl -162; Head 1........................ : Ok
Cyl -163; Head 0........................ : Ok
Cyl -163; Head 1........................ : Ok
Cyl -164; Head 0........................ : Ok
Cyl -164; Head 1........................ : Ok
Cyl -165; Head 0........................ : Ok
Cyl -165; Head 1........................ : Ok
Cyl -166; Head 0........................ : Ok
Cyl -166; Head 1........................ : Ok
Cyl -167; Head 0........................ : Ok
Cyl -167; Head 1........................ : Ok
Cyl -168; Head 0........................ : Ok
Cyl -168; Head 1........................ : Ok
Cyl -169; Head 0........................ : Ok
Cyl -169; Head 1........................ : Ok
Cyl -170; Head 0........................ : Ok
Cyl -170; Head 1........................ : Ok
Backup process completed
ZeBong
Posted: November 4th, 2008, 21:43
by Doomer
Does it click?
Posted: November 5th, 2008, 1:11
by networkpc3000
i think this problem SA 95% head 5%,if the PCB is original and ROM doesn't change, try to repair SA first
Posted: November 5th, 2008, 10:30
by zebong
Any one have any ideia how can i correct the problem
I Found the family is Spider, but Acelabs is not supported yet :(
ZeBong
Posted: November 5th, 2008, 11:12
by Doomer
Once again
Does it click?
Posted: November 5th, 2008, 11:36
by beto
Hello doomer i talk with zebong, the hdd doesnt click, but when u tried to read any sector show u ABRT, its looks like SA problem, but maybe this model its not supported by pc3k until now, but like u can see cannot load Zone table in buffer,
RAM:
Posted: November 5th, 2008, 12:14
by Doomer
If it doesn't click it is probably SA
As far as I know Acelab using ABA access to read modules on such models
ABA access will not work w/o inited ATA-overlay and this overlay has not been initilizied as we can see from this error - VSCE PERM OVL NOT LOADED
To fix such a problem AceLab suggested "Load Loader" for WD (actually it loads overlay 11 from external file) after that PC3K will be able to access SA in ABA coordinates
Another problem is the Spider model uses 32-bits ABA coordinates but there is no supported command to access 32-bit ABA on Spider drive, so AceLab decided to bypass such a problem by recalculating ABA to PCHS and access SA with PCHS. This change was made in latest Russian version of PC3K (not sure about English one)
So, if you don't have a good program to work with WD ROYL drives but have only PC3K your actions might be following:
1. You need to get latest version of PC3K which supports Loader for WD ROYL and Spider ABA access
2. You need to get Module 11 with this version - 5C.3BG
3. You need to load that Module 11 and find out the problem
Posted: November 5th, 2008, 12:22
by zebong
Thanks Beto and Doomer
Posted: November 5th, 2008, 13:46
by networkpc3000
Doomer answer is well! thanks :)
