 Post subject: ROM for WD400UE-xxHCT0 required.
PostPosted: November 20th, 2008, 8:02
I need a ROM for a WD400UE-22HCTO.
The ROM version needs to match the SA ROM version on my patient which is 10.4S. (shown in "status" on a good drive, and held in a module on the platters, from which I got the version of my patients f/w)
The original PCB is dead and the orginal ROM is broken (physically)
I did some research and found that if the SA ROM version matches the PCB ROM version, the boards are interchangable. I have 2 WD400UEs with SA ROM version 10.4Q, and both PCB's work with both HDA's.
Any help would be appreciated.
Sean
 Post subject: Re: ROM for WD400UE-xxHCT0 required.
PostPosted: November 20th, 2008, 8:51
ROM_104SD_0767_WD800UE-22HCT0
Mikippp
PostPosted: November 20th, 2008, 10:14
Thanks Mikippp,
I actually managed to get the drive going and imaging by smart hot-swapping with the 10.4Q drive, but will try your ROM in case this method doesn't work, and for future reference.
Will let you know the results.
Sean
PostPosted: November 25th, 2008, 7:19
Update.
Re-write of 10.4S ROM to a donor PCB worked perfectly after head map change to suit my 2-headed WD400UE
Thanks again mikippp
