| ROM for WD400UE-xxHCT0 required. http://forum.hddguru.com/viewtopic.php?f=11&t=10523 |
Page 1 of 1 |
| Author: | pcimage [ November 20th, 2008, 8:02 ] |
| Post subject: | ROM for WD400UE-xxHCT0 required. |
Hi, I need a ROM for a WD400UE-22HCTO. The ROM version needs to match the SA ROM version on my patient which is 10.4S. (shown in "status" on a good drive, and held in a module on the platters, from which I got the version of my patients f/w) The original PCB is dead and the orginal ROM is broken (physically) I did some research and found that if the SA ROM version matches the PCB ROM version, the boards are interchangable. I have 2 WD400UEs with SA ROM version 10.4Q, and both PCB's work with both HDA's. Any help would be appreciated. Sean |
| Author: | Mikippp [ November 20th, 2008, 8:51 ] |
| Post subject: | Re: ROM for WD400UE-xxHCT0 required. |
Hi, ROM_104SD_0767_WD800UE-22HCT0 Mikippp |
| Author: | pcimage [ November 20th, 2008, 10:14 ] |
Thanks Mikippp, I actually managed to get the drive going and imaging by smart hot-swapping with the 10.4Q drive, but will try your ROM in case this method doesn't work, and for future reference. Will let you know the results. Sean |
| Author: | pcimage [ November 25th, 2008, 7:19 ] |
Update. Re-write of 10.4S ROM to a donor PCB worked perfectly after head map change to suit my 2-headed WD400UE Thanks again mikippp |
