| WD1200JB-00FUA0 http://forum.hddguru.com/viewtopic.php?f=11&t=10527 |
Page 1 of 2 |
| Author: | zebong [ November 20th, 2008, 13:30 ] |
| Post subject: | WD1200JB-00FUA0 |
Hello Have a disk with this when i connect : It can not show-me the SA FW Version Anyone have this error ? Techno mode key: HDD geometry loading.................... : Ok Cyl Count............................... : 81004 Head Count.............................. : 4 SPT..................................... : 900 RAM: Zone allocation table................... : Ok ROM version............................. : 15.BE. SA FW version........................... : ...... Link table version...................... : 05.66. Serial ROM: Read ROM................................ : Ok Heads configuration..................... : From map Heads number............................ : 6 The number of heads in use.............. : 4 Disabled heads.......................... : Yes Head map................................ : 0,1,4,5 Service area: Modules table loading................... : Drive is not ready Configuration loading................... : WD Techno Key Error Drive is not ready Translation overlay checking (Copy 0)... : Not found in modules directory Translation overlay checking (Copy 1)... : Not found in modules directory Thanks ZeBong |
| Author: | pcimage [ November 20th, 2008, 16:39 ] |
| Post subject: | Re: WD1200JB-00FUA0 |
What about the modules? Can you read/check them? |
| Author: | networkpc3000 [ November 20th, 2008, 17:09 ] |
i think i have idea to find out which version it's. |
| Author: | zebong [ November 20th, 2008, 18:20 ] |
pcimage wrote: What about the modules? Can you read/check them? i can not read them, it appear blank. i also try to cut head by head but nothing happen. |
| Author: | zebong [ November 20th, 2008, 18:21 ] |
networkpc3000 wrote: i think i have idea to find out which version it's. So what do you think it is ? |
| Author: | Mikippp [ November 21st, 2008, 3:16 ] |
Hi, Quote: Modules table loading................... : Drive is not ready Modules table NOT loaded!!! (module 41.rpm [~Dir.rpm]) At first Read (backup) all service tracks... Mikippp |
| Author: | zebong [ November 21st, 2008, 10:38 ] |
hi, that´s the problem i can not see any module and i can not backup |
| Author: | Mikippp [ November 21st, 2008, 12:17 ] |
At first Read (backup) all service tracks... (tracks not modules) You can not read modules becouse modules table was NOT loaded!!! Then read the manual... especially informations about module "ID=41h" and about "Utility extensions". Mikippp |
| Author: | zebong [ November 22nd, 2008, 11:51 ] | ||
| Post subject: | Re: WD1200JB-00FUA0 | ||
Thanks, i go there and i dont see any backup off tracks. ZeBong
| Author: | rameez [ November 22nd, 2008, 16:38 ] |
Its in the test menu . |
| Author: | zebong [ November 24th, 2008, 14:28 ] |
Hi try to make the backup off the tracks: But i can not, what do you think the problem is : Thanks Reading service tracks Into folder............................. : <HDD Profile>\Data\Tracks Reading heads........................... : 0,1,4,5 WD Techno Read Error C/H/S: -1/0/0 WD Techno Read Error C/H/S: -1/0/1 Cyl -1; Head 0.......................... : Break WD Techno Read Error C/H/S: -1/1/0 WD Techno Read Error C/H/S: -1/1/1 WD Techno Read Error C/H/S: -1/1/2 WD Techno Read Error C/H/S: -1/1/3 WD Techno Read Error C/H/S: -1/1/4 Cyl -1; Head 1.......................... : Break |
| Author: | Mikippp [ November 25th, 2008, 8:20 ] |
Hi, You use original PCB with original ROM ? Did you try the head check? wd1200bb-changed-rom-and-pcb-still-not-work-t7717.html Mikippp |
| Author: | zebong [ November 25th, 2008, 14:49 ] |
Mikippp wrote: Hi, You use original PCB with original ROM ? Did you try the head check? wd1200bb-changed-rom-and-pcb-still-not-work-t7717.html Mikippp Yes, Everything is original. |
| Author: | rameez [ November 27th, 2008, 14:33 ] |
I think problem with head 1 . |
| Author: | zebong [ December 22nd, 2008, 19:21 ] |
Anyone have one disk to seel need the heads match WD1200JB-00FUA0 ZeBong |
| Author: | harddrivespecialist [ December 23rd, 2008, 10:59 ] |
Do you need a drive to work with a drive discussed above? |
| Author: | zebong [ December 23rd, 2008, 14:13 ] |
Hello, This things happen Techno mode key: HDD geometry loading.................... : Ok Cyl Count............................... : 15468 Head Count.............................. : 4 SPT..................................... : 900 RAM: Zone allocation table................... : Ok ROM version............................. : 15.BE. SA FW version........................... : 15.BER Link table version...................... : 05.66. Serial ROM: Read ROM................................ : Ok Heads configuration..................... : From map Heads number............................ : 6 The number of heads in use.............. : 4 Disabled heads.......................... : Yes Head map................................ : 0,1,4,5 Service area: Modules table loading................... : Ok (Copy 0) Configuration loading................... : Ok Master Password......................... : has not been set User Password........................... : has not been set Translation overlay checking............ : Ok Also i start to make a copy with DE but it give ecc error, Anyone can help on this ? Thanks ZeBong |
| Author: | harddrivespecialist [ December 23rd, 2008, 14:31 ] |
You have to read it by head map and read the ones that do read and then work with the ones that don't read. |
| Author: | zebong [ December 23rd, 2008, 20:03 ] |
harddrivespecialist wrote: You have to read it by head map and read the ones that do read and then work with the ones that don't read. Try to build a head maps but it give error. |
| Author: | zebong [ December 23rd, 2008, 20:22 ] |
Make a head test : it gives OK, Heads test Cylinder to test........................ : -25 Heads to test........................... : 0,1,2,3 Head 0.................................. : Ok Head 1.................................. : Ok Head 4.................................. : Ok Head 5.................................. : Ok SA surface verification Initial cylinder........................ : -1 Final cylinder.......................... : -20 Head.................................... : 0,1 Cyl -1 Head 0........................... : Errors : 0 Cyl -1 Head 1........................... : Errors : 0 Cyl -2 Head 0........................... : Errors : 0 Cyl -2 Head 1........................... : Errors : 0 Cyl -3 Head 0........................... : Errors : 0 Cyl -3 Head 1........................... : Errors : 0 Cyl -4 Head 0........................... : Errors : 0 Cyl -4 Head 1........................... : Errors : 0 Cyl -5 Head 0........................... : Errors : 0 Cyl -5 Head 1........................... : Errors : 0 Cyl -6 Head 0........................... : Errors : 0 Cyl -6 Head 1........................... : Errors : 0 Cyl -7 Head 0........................... : Errors : 0 Cyl -7 Head 1........................... : Errors : 0 Cyl -8 Head 0........................... : Errors : 2 -------------------------------------------------- Sectors :Error -------------------------------------------------- 304..................................... 319..................................... -------------------------------------------------- Cyl -8 Head 1........................... : Errors : 0 Cyl -9 Head 0........................... : Errors : 0 Cyl -9 Head 1........................... : Errors : 0 Cyl -10 Head 0.......................... : Errors : 0 Cyl -10 Head 1.......................... : Errors : 0 Cyl -11 Head 0.......................... : Errors : 0 Cyl -11 Head 1.......................... : Errors : 0 Cyl -12 Head 0.......................... : Errors : 0 Cyl -12 Head 1.......................... : Errors : 0 Cyl -13 Head 0.......................... : Errors : 0 Cyl -13 Head 1.......................... : Errors : 0 Cyl -14 Head 0.......................... : Errors : 0 Cyl -14 Head 1.......................... : Errors : 0 Cyl -15 Head 0.......................... : Errors : 0 Cyl -15 Head 1.......................... : Errors : 0 Cyl -16 Head 0.......................... : Errors : 0 Cyl -16 Head 1.......................... : Errors : 0 Cyl -17 Head 0.......................... : Errors : 0 Cyl -17 Head 1.......................... : Errors : 0 Cyl -18 Head 0.......................... : Errors : 0 Cyl -18 Head 1.......................... : Errors : 0 Cyl -19 Head 0.......................... : Errors : 0 Cyl -19 Head 1.......................... : Errors : 0 Cyl -20 Head 0.......................... : Errors : 16 -------------------------------------------------- Sectors :Error -------------------------------------------------- 1....................................... 11...................................... 15 -- 16................................ 20 -- 21................................ 25 -- 26................................ 30 -- 31................................ 35 -- 36................................ 40 -- 41................................ 45 -- 46................................ -------------------------------------------------- Cyl -20 Head 1.......................... : Errors : 24 -------------------------------------------------- Sectors :Error -------------------------------------------------- 1....................................... 10 -- 11................................ 15 -- 16................................ 17......................................Drive is not ready 20 -- 21................................ 22......................................Drive is not ready 25 -- 26................................ 27......................................Drive is not ready 30 -- 31................................ 32......................................Drive is not ready 35 -- 36................................ 37......................................Drive is not ready 40 -- 41................................ 42......................................Drive is not ready 45 -- 46................................ 47......................................Drive is not ready -------------------------------------------------- SA surface verification completed |
| Page 1 of 2 | All times are UTC - 5 hours [ DST ] |
