SEAGATE SELFSCAN
http://forum.hddguru.com/viewtopic.php?f=11&t=10528
Author:  zebong [ November 20th, 2008, 15:53 ]
Post subject:  SEAGATE SELFSCAN
Hi, anyone know this
Afther a selfscan it appear“s this message:
Interface task reset
1024k x 16 buffer detected
SNOWMASS - 2_Disk 3.19 11-20-01 12:12
Power Cycling
ATReset
Head Mask 000F - Switch to full int.
Spin Ready
Begin Test 08
Not Power Cycling
SkpCylList deleted
Sys= 7000-7028 02B9 SPTK on sys trks
<empty>
drive must be reformatted
EP=0, TA=0, HiGain=1, OTRd=0, Early Rd=0, Splash=1, Reload=1, VCO=1, MRBias=1
Bst/Zap=0, SrvoThrsh=1, RunOut=1, MaxECC=1, ECC 2=1, ECC 1=1, ECC 0=1
Data=FF, Write=80, ID=FF
ZeBong
Author:  networkpc3000 [ November 20th, 2008, 17:08 ]
Post subject:  Re: SEAGATE SELFSCAN
are you sure it's complete? i don't think so!
Author:  rameez [ November 21st, 2008, 17:18 ]
Let the test complete test 8 takes alot of time be petient .
Author:  jono-ats [ November 28th, 2008, 9:58 ]
I've never had much luck with Seagate's selfscan. I think it should be renamed, "self-destruct."
I've used it with drives that had problems. After running the test(s), the drives would always be busy and never come ready.
Impressive amount of test messages from terminal mode, though!
