 Post subject: SAMSUNG JUST SHOW "00" ZERO ZERO
PostPosted: November 28th, 2008, 11:17
I HAVE a Samsung disk that was not SPIN, when i resolve the bearings problem, now it can SPIN it detect the ID and the size / serial number, but when i edit it appear all 00.
If someone format this with zero zero is possible to get data ?
Anyone was a case like this
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: SAMSUNG JUST SHOW "00" ZERO ZERO
PostPosted: December 2nd, 2008, 5:29
First of all, you should talk to your costumer to check what happened.
PostPosted: December 3rd, 2008, 11:54
Talk with the client and the client say´s that the disk have data there :(
Talk with a friend that say´s to me that could be FW problem, that once have a problem like this.
Anyone was a problem like this ?
ZeBong
ZeBong
" Россия еще раз"
PostPosted: December 3rd, 2008, 14:31
Hello zebong, did u tried to find any "hex code" or " ascii" code at all sectors?
PostPosted: December 3rd, 2008, 15:06
Can you access the sectors of the drive?
PostPosted: December 3rd, 2008, 15:36
I can copy all the drive ok "green".
When i edit the sectors all "00"
I use R-Studio to see any lost file or delete file but nothing happen.
I Heard that can be a FW Problem but all the Modules are OK
SA STRUCTURE
SA parameters
Zone #.................................. : 0
Initial cylinder........................ : 0
Final cylinder.......................... : 63
SPT..................................... : 960
ZONE TABLE
Number of zones......................... : 24
# : Head : Initial cylinder : Final cylinder : SPT
1 : 0 : 64 : 4 139 : 1 511
1 : 1 : 64 : 4 139 : 1 511
2 : 0 : 4 140 : 8 672 : 1 498
2 : 1 : 4 140 : 8 672 : 1 498
3 : 0 : 8 673 : 12 291 : 1 472
3 : 1 : 8 673 : 12 291 : 1 472
4 : 0 : 12 292 : 17 589 : 1 440
4 : 1 : 12 292 : 17 589 : 1 440
5 : 0 : 17 590 : 20 748 : 1 424
5 : 1 : 17 590 : 20 748 : 1 424
6 : 0 : 20 749 : 24 519 : 1 400
6 : 1 : 20 749 : 24 519 : 1 400
7 : 0 : 24 520 : 29 013 : 1 371
7 : 1 : 24 520 : 29 013 : 1 371
8 : 0 : 29 014 : 32 671 : 1 344
8 : 1 : 29 014 : 32 671 : 1 344
9 : 0 : 32 672 : 37 052 : 1 320
9 : 1 : 32 672 : 37 052 : 1 320
10 : 0 : 37 053 : 42 045 : 1 280
10 : 1 : 37 053 : 42 045 : 1 280
11 : 0 : 42 046 : 44 899 : 1 264
11 : 1 : 42 046 : 44 899 : 1 264
12 : 0 : 44 900 : 49 425 : 1 234
12 : 1 : 44 900 : 49 425 : 1 234
13 : 0 : 49 426 : 53 273 : 1 208
13 : 1 : 49 426 : 53 273 : 1 208
14 : 0 : 53 274 : 57 343 : 1 184
14 : 1 : 53 274 : 57 343 : 1 184
15 : 0 : 57 344 : 62 425 : 1 137
15 : 1 : 57 344 : 62 425 : 1 137
16 : 0 : 62 426 : 66 501 : 1 120
16 : 1 : 62 426 : 66 501 : 1 120
17 : 0 : 66 502 : 69 912 : 1 097
17 : 1 : 66 502 : 69 912 : 1 097
18 : 0 : 69 913 : 73 431 : 1 072
18 : 1 : 69 913 : 73 431 : 1 072
19 : 0 : 73 432 : 78 729 : 1 040
19 : 1 : 73 432 : 78 729 : 1 040
20 : 0 : 78 730 : 81 899 : 1 013
20 : 1 : 78 730 : 81 899 : 1 013
21 : 0 : 81 900 : 86 259 : 980
21 : 1 : 81 900 : 86 259 : 980
22 : 0 : 86 260 : 89 735 : 960
22 : 1 : 86 260 : 89 735 : 960
23 : 0 : 89 736 : 93 811 : 916
23 : 1 : 89 736 : 93 811 : 916
24 : 0 : 93 812 : 97 887 : 888
24 : 1 : 93 812 : 97 887 : 888
MODULES TABLE
Module : CrLev : Cyl :Head: Sec : Length : Read : Real Header : Standard Hdr :
00 FSI : D : 0 : 0 : 1 : 1 : OK : FSI : FSI
02 FIT : D : 0 : 0 : 2 : 4 : OK : FIT : FIT
06 MLIST : As : 0 : 0 : 6 : 1 : OK : MLIST : MLIST
07 SRVTBL : As : 0 : 0 : 7 : 4 : OK : SV_TBL : SV_TBL
53 SEEKTIME : C : 0 : 0 : 11 : 1 : OK : SEEKTIME : SEEKTIME
8E : : 1 : 0 : 1 : 700 : OK : :
5D SNTBL : C : 0 : 0 : 15 : 2 : OK : :
5F LMBACKUP : : 0 : 0 : 21 : 1 : OK : ^ ¨ †³†¤ : LMBACKUP
4C CAPSELDA : : 0 : 0 : 22 : 1 : OK : SPSTW_DA : SPSTW_DA
61 REF_TMR : : 0 : 0 : 27 : 2 : OK : 21Q : REF_TMR
5B MODEL_ID : : 0 : 0 : 20 : 1 : OK : MODEL_ID : MODEL_ID
5E ARCOTBL2 : As : 0 : 0 : 30 : 12 : OK : CHN_TBL2 : CHN_TBL2
77 PROC_CNT : : 0 : 0 : 71 : 1 : OK : PROC_CNT : PROC_CNT
75 STR_RSRT : : 0 : 0 : 81 : 1 : OK : : STR_RSRT
04 CONFIG : As : 1 : 0 : 1 : 2 : OK : CONFIG : CONFIG
05 SNTBL : C : 1 : 0 : 3 : 2 : OK : :
08 BISPT : Dr : 1 : 0 : 5 : 5 : OK : END : END
09 BRSLT : Dr : 1 : 0 : 10 : 1 : OK : BI_RESLT : BI_RESLT
7B CRITERIA : Dr : 1 : 0 : 11 : 1 : OK : : BI_CRTRA
0B FINALTST : Dr : 1 : 0 : 12 : 8 : OK : :
0A ARCOTBL : As : 1 : 0 : 30 : 12 : OK : CHN_TBL : CHN_TBL
7A GEO_TBL : As : 1 : 0 : 46 : 16 : OK : :
0C VLISTHDR : As : 1 : 0 : 78 : 1 : OK : VLIST_H : VLIST_H
0D VLIST : Ad : 1 : 0 : 79 : 16 : OK : :
55 FDT_TBL : As : 1 : 0 : 96 : 1 : OK : FDT_TBL : FDT_TBL
54 RDRTY_01 : : 1 : 0 : 97 : 2 : OK : RDRTY_01 : RDRTY_01
0E SLISTHDR : As : 1 : 0 : 111 : 1 : OK : SLIST_H : SLIST_H
0F SLIST : Ad : 6 : 0 : 1 : 512 : OK : :
11 ALIST : Ad : 1 : 0 : 201 : 35 : OK : :
81 RLIST : : 16 : 0 : 201 : 35 : OK : :
64 ALISTHDR : Ad : 1 : 0 : 372 : 2 : OK : RLIST_H : RLIST_H
82 RLIST_H : : 16 : 0 : 372 : 2 : OK : : RLIST_H
15 SRVTBL2 : As : 1 : 0 : 383 : 4 : OK : SV_TBL2 : SV_TBL2
12 TMPRTR : C : 1 : 0 : 395 : 4 : OK : TMPRTURE : TMPRTURE
17 OVERLAY : Bs : 1 : 0 : 401 : 230 : OK : OMLV0Y10 : OMLV0Y10
10 TLIST : Ad : 1 : 0 : 641 : 25 : OK : TLIST : TLIST
16 CHN_TBL2 : : 1 : 0 : 701 : 12 : OK : CHN_TB2 : CHN_TB2
51 M30CODE : Dr : 2 : 0 : 1 : 630 : OK : :
68 DLIST_H : : 3 : 0 : 1 : 1 : OK : LDSI_TH : LDSI_TH
26 DLISTOR : : 3 : 0 : 2 : 768 : OK : DLIST OR : DLIST OR
95 DLISTOR2 : : 24 : 0 : 2 : 512 : OK : :
18 HDAF_RPT : : 4 : 0 : 1 : 1 : OK : :
19 HD_DLIST : : 4 : 0 : 2 : 2 : OK : :
1A LUL : : 4 : 0 : 4 : 1 : OK : LUL : LUL
1B RCOSCRPT : Dr : 4 : 0 : 5 : 50 : OK : RCOSCPT : RCOSCPT
1D ERRTRK : Dr : 4 : 0 : 55 : 2 : OK : : BER
1E ERRZN : Dr : 4 : 0 : 57 : 1 : OK : BER1 : BER1
1F ERRDRV : Dr : 4 : 0 : 58 : 1 : OK : BER2 : BER2
20 SRTDATA : : 4 : 0 : 59 : 1 : OK : ER_CNT : ER_CNT
21 SRTSRVO : : 4 : 0 : 60 : 1 : OK : SV_ERCNT : SV_ERCNT
22 PARAM : : 4 : 0 : 62 : 2 : OK : PAR_MON : PAR_MON
23 WKHEAD : : 4 : 0 : 72 : 10 : OK : : WK_HEAD
24 TSTPI : : 4 : 0 : 82 : 4 : OK : TPI_WRW : TPI_WRW
25 MRTUNEMT : As : 4 : 0 : 86 : 5 : OK : MR_TUNE : MR_TUNE
1C BTIME : Dr : 4 : 0 : 91 : 3 : OK : BI_TIME : BI_TIME
62 HD_BER : : 4 : 0 : 125 : 1 : OK : : HD_BER
4E MRRTABLE : : 4 : 0 : 126 : 1 : OK : MRR_TBL : MRR_TBL
6D OWC_CSM : : 4 : 0 : 151 : 2 : OK : OWC_CSM : OWC_CSM
28 ERR_HDR : : 4 : 0 : 201 : 1 : OK : ERR_HDR : ERR_HDR
29 SMRT_HDR : : 4 : 0 : 202 : 1 : OK : SMRT_HDR : SMRT_HDR
2A BISP_HDR : : 4 : 0 : 203 : 1 : OK : BISP_HDR : BISP_HDR
2B SERIAL_H : : 4 : 0 : 204 : 1 : OK : SERIAL_H : SERIAL_H
2C PES_HDR : : 4 : 0 : 205 : 1 : OK : PES_HDR : PES_HDR
2D SVTRC_HD : : 4 : 0 : 206 : 1 : OK : SVTRC_HD : SVTRC_HD
42 CAPSEL : : 4 : 0 : 511 : 1 : OK : : CAP_SEL
43 CURBPI : : 4 : 0 : 512 : 1 : OK : : CUR_BPI
44 AZLCSM : : 4 : 0 : 513 : 1 : OK : : AZL_CSM
45 AZL_CSM0 : : 4 : 0 : 514 : 1 : OK : : AZL_CSM0
46 AZL_CSM1 : : 4 : 0 : 515 : 1 : OK : : AZL_CSM1
47 AZL_CSM2 : : 4 : 0 : 516 : 1 : OK : : AZL_CSM2
48 AZL_CSM3 : : 4 : 0 : 517 : 1 : OK : : AZL_CSM3
49 AZL_CSM4 : : 4 : 0 : 518 : 1 : OK : : AZL_CSM4
4A AZL_CSM5 : : 4 : 0 : 519 : 1 : OK : : AZL_CSM5
4B AZL_CSM6 : : 4 : 0 : 520 : 1 : OK : : AZL_CSM6
5C PWR_CNT : : 4 : 0 : 580 : 1 : OK : :
56 SPN_MNTR : : 4 : 0 : 581 : 4 : OK : SPN_MNTR : SPN_MNTR
57 IRD_DOWN : : 4 : 0 : 585 : 1 : OK : : IRD_DOWN
31 ATW_TEST : : 4 : 0 : 586 : 1 : OK : ATW_TEST : ATW_TEST
58 ATW_TST2 : : 4 : 0 : 587 : 1 : OK : : ATW_TST2
38 SPESB0 : : 4 : 0 : 601 : 2 : OK : : BPES0
39 SPESB1 : : 4 : 0 : 603 : 2 : OK : : BPES1
3A SPESB2 : : 4 : 0 : 605 : 2 : OK : : BPES2
3B SPESB3 : : 4 : 0 : 607 : 2 : OK : : BPES3
3C SPESB4 : : 4 : 0 : 609 : 12 : OK : : BPES4
73 LOW_BER : : 4 : 0 : 702 : 1 : OK : : LOW_BER
27 GEO_00 : As : 7 : 0 : 1 : 588 : OK : EG_O00 : EG_O00
90 TNU_LOG : : 8 : 0 : 1 : 2 : OK : : TNU_LOG
91 LONGSEEK : : 8 : 0 : 3 : 1 : OK : : LONGSEEK
32 SMART : Bs : 11 : 0 : 1 : 9 : OK : SMARTMEM : SMARTMEM
33 SMRT_LOG : : 11 : 0 : 3 : 4 : OK : :
83 SDATAMEM : : 11 : 0 : 71 : 100 : OK : :
3D ELOG : Dr : 12 : 0 : 1 : 960 : OK : :
36 SV_TRACE : : 20 : 0 : 1 : 3 : OK : :
37 PES_LOG : : 20 : 0 : 11 : 4 : OK : :
40 IPC_DBG : : 20 : 0 : 302 : 1 : OK : :
59 PMP : : 20 : 0 : 305 : 1 : OK : :
69 DLIST : D : 21 : 0 : 1 : 767 : OK : DLIST : DLIST
7C FOD_FH : : 15 : 0 : 2 : 8 : OK : FOD_FH : FOD_FH
7E FOD_DATA : : 15 : 0 : 10 : 18 : OK : FOD_DATA : FOD_DATA
87 FOD_FREQ : : 15 : 0 : 29 : 8 : OK : FOD_FREQ : FOD_FREQ
7D FOD_VU : : 15 : 0 : 40 : 8 : OK : : FOD_VU
7F FOD_FHT : : 15 : 0 : 48 : 8 : OK : FOD_FHT : FOD_FHT
86 FOD_RST : : 15 : 0 : 28 : 1 : OK : FOD_RST : FOD_RST
88 HSC_CYL : : 15 : 0 : 56 : 1 : OK : : HSC_CYL
8C FOD_FH2 : : 15 : 0 : 57 : 8 : OK : : FOD_FH2
8B FOD_DAT2 : : 15 : 0 : 65 : 18 : OK : : FOD_DAT2
89 FOD_RST2 : : 15 : 0 : 83 : 1 : OK : : FOD_RST2
8A FOD_FRE2 : : 15 : 0 : 84 : 8 : OK : : FOD_FRE2
8D FOD_INSI : : 15 : 0 : 92 : 8 : OK : : FOD_INSI
HDD SECURITY SUBSYSTEM
MASTER password......................... :
USER password........................... :
Master Code............................. : 0000
USER password is set.................... : No
Security level.......................... : High
S-LIST - DEFECTS ALLOCATION BY ZONES
: Zone : Head 0 : Head 1 : Total :
: 1 : 30 : 30 : 60 :
: 2 : 78 : 5 : 83 :
: 3 : 25 : 22 : 47 :
: 4 : 4 : 23 : 27 :
: 5 : 2 : 23 : 25 :
: 6 : 67 : 35 : 102 :
: 7 : 19 : 40 : 59 :
: 8 : 118 : 1 : 119 :
: 9 : 8 : 18 : 26 :
: 10 : 4 : 8 : 12 :
: 11 : 3 : 12 : 15 :
: 12 : 39 : 5 : 44 :
: 13 : 31 : 49 : 80 :
: 14 : 0 : 63 : 63 :
: 15 : 1 : 28 : 29 :
: 16 : 1 : 36 : 37 :
: 17 : 60 : 1 : 61 :
: 18 : 47 : 33 : 80 :
: 19 : 37 : 42 : 79 :
: 20 : 1 : 26 : 27 :
: 21 : 24 : 46 : 70 :
: 22 : 18 : 3 : 21 :
: 23 : 18 : 19 : 37 :
: 24 : 1 : 63 : 64 :
: Total : 636 : 631 : 1267 :
Maximum possibly defects count: 21845
T-LIST - DEFECTIVE TRACKS LIST
: # : Zone : Head : Cyl :
: 1 : 1 : 0 : 2391 :
: 2 : 1 : 0 : 2392 :
: 3 : 1 : 0 : 2393 :
: 4 : 1 : 0 : 2400 :
: 5 : 1 : 0 : 2401 :
: 6 : 1 : 0 : 2402 :
: 7 : 2 : 0 : 5798 :
: 8 : 10 : 0 : 39850 :
: 9 : 10 : 0 : 39851 :
: 10 : 10 : 0 : 39852 :
: 11 : 17 : 0 : 67966 :
: 12 : 18 : 0 : 71475 :
: 13 : 18 : 0 : 71476 :
: 14 : 18 : 0 : 71477 :
: 15 : 18 : 0 : 73258 :
: 16 : 18 : 0 : 73259 :
: 17 : 18 : 0 : 73260 :
: 18 : 19 : 0 : 76100 :
: 19 : 19 : 0 : 76101 :
: 20 : 19 : 0 : 76102 :
: 21 : 21 : 0 : 82312 :
: 22 : 21 : 0 : 82313 :
: 23 : 21 : 0 : 82314 :
: 24 : 1 : 1 : 2391 :
: 25 : 1 : 1 : 2392 :
: 26 : 1 : 1 : 2393 :
: 27 : 10 : 1 : 39850 :
: 28 : 10 : 1 : 39851 :
: 29 : 10 : 1 : 39852 :
: 30 : 14 : 1 : 54455 :
: 31 : 14 : 1 : 54456 :
: 32 : 14 : 1 : 54457 :
Maximum possibly defects count: 2096
A-LIST - REASSIGNED SECTORS LIST
: # : Cyl : Head : Sector -> Cyl : Head : Sector :
Maximum possibly defects count: 1120
D-LIST - DEFECTS ALLOCATION BY ZONES
: 1 : 24 : 27 :
: 2 : 77 : 5 :
: 3 : 25 : 22 :
: 4 : 4 : 23 :
: 5 : 2 : 23 :
: 6 : 67 : 35 :
: 7 : 19 : 40 :
: 8 : 118 : 1 :
: 9 : 8 : 18 :
: 10 : 1 : 5 :
: 11 : 3 : 12 :
: 12 : 39 : 5 :
: 13 : 31 : 49 :
: 14 : 0 : 60 :
: 15 : 1 : 28 :
: 16 : 1 : 36 :
: 17 : 59 : 1 :
: 18 : 41 : 33 :
: 19 : 34 : 42 :
: 20 : 1 : 26 :
: 21 : 21 : 46 :
: 22 : 18 : 3 :
: 23 : 18 : 19 :
: 24 : 1 : 63 :
: Total : 613 : 622 :
ZeBong
" Россия еще раз"
PostPosted: December 3rd, 2008, 15:42
I don't think the drive has any fw problems. Maybe it was wiped out.
