 Post subject: WD5000KS-55MNB0
PostPosted: November 29th, 2008, 10:56
i have this disk that was clicking so i cut head 6/7 and the clik was gone, and i get ID in the pc3k.
When i try to copy with DE, it give ECC error.
Also i try to use the head maps in DE, but nothing new.. dont copy.
I put here the SA Structure test: i have a lot off erros in the COPY 1:
The modules is all green when i test it:
Anyone know how can i solve this case:
ZeBong
28: 1 : : -1: 1: 238: 16:Yes :Error: Ok : 00 :/WRONG/ :..... :
0C: 0 : B : -1: 0: 258: 5:Yes : Ok : Ok : 82 :14-07-06:0101? :Models table
0C: 1 : B : -1: 1: 258: 5:Yes :Error: Ok : 00 :/WRONG/ :..... :Models table
4D: 0 : : -1: 0: 267: 1:Yes : Ok : Ok : 70 :14-07-06:071P? :
4D: 1 : : -1: 1: 267: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :
35: 0 : Dd : -2: 0: 0: 1:Yes : Ok : Ok : 94 :13-10-02:B327? :SA Defects
35: 1 : Dd : -2: 1: 0: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :SA Defects
02: 0 : B : -2: 0: 5: 2:Yes : Ok : Ok : 6D :14-07-06:0800? :Configuration (HDD ID)
02: 1 : B : -2: 1: 5: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Configuration (HDD ID)
33: 0 : Dd : -2: 0: 11: 510:Yes : Ok : Ok : A9 :14-07-06:1500? :P-List (Primary defect list)
33: 1 : Dd : -2: 1: 11: 510:Yes :Error: Ok : 00 :/WRONG/ :..... :P-List (Primary defect list)
06: 0 : B : -2: 0: 525: 127:Yes : Ok : Ok : 78 :14-07-06:0200? :Family models configuration (Alt2)
06: 1 : B : -2: 1: 525: 127:Yes :Error: Ok : 00 :/WRONG/ :..... :Family models configuration (Alt2)
40: 0 : As : -2: 0: 656: 63:Yes : Ok : Ok : 27 :14-07-06:071P? :Adaptive data
40: 1 : As : -2: 1: 656: 63:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data
61: 0 : B : -2: 0: 723: 28:Yes : Ok : Ok : 59 :14-07-06:071PE :Loaded part of microprogram code
61: 1 : B : -2: 1: 723: 28:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
3D: 0 : : -2: 0: 755: 16:Yes : Ok : Ok : 23 :14-07-06:0300? :
3D: 1 : : -2: 1: 755: 16:Yes :Error: Ok : 00 :/WRONG/ :..... :
4A: 0 : As : -2: 0: 775: 5:Yes : Ok : Ok : D7 :14-07-06:071P? :Adaptive data
4A: 1 : As : -2: 1: 775: 5:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data
37: 0 : : -2: 0: 784: 1:Yes : Ok : Ok : 4E :14-07-06:0100? :
37: 1 : : -2: 1: 784: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :
11: 0 : B : -3: 0: 0: 372:Yes : Ok : Ok : B8 :14-07-06:071PE :Loaded part of microprogram code
11: 1 : B : -3: 1: 0: 372:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
04: 0 : B : -3: 0: 392: 127:Yes : Ok : Ok : C9 :14-07-06:0200? :Family models configuration (Main)
04: 1 : B : -3: 1: 392: 127:Yes :Error: Ok : 00 :/WRONG/ :..... :Family models configuration (Main)
43: 0 : As : -3: 0: 523: 63:Yes : Ok : Ok : B9 :14-07-06:071P? :Adaptive data
43: 1 : As : -3: 1: 523: 63:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data
03: 0 : : -3: 0: 590: 26:Yes : Ok : Ok : 8C :14-07-06:0200? :
03: 1 : : -3: 1: 590: 26:Yes :Error: Ok : 00 :/WRONG/ :..... :
3B: 0 : : -3: 0: 620: 16:Yes : Ok : Ok : A9 :14-07-06:0300? :
3B: 1 : : -3: 1: 620: 16:Yes :Error: Ok : 00 :/WRONG/ :..... :
36: 0 : : -3: 0: 640: 5:Yes : Ok : Ok : 57 :14-07-06:071P? :
36: 1 : : -3: 1: 640: 5:Yes :Error: Ok : 00 :/WRONG/ :..... :
6C: 0 : : -3: 0: 649: 1:Yes : Ok : Ok : 51 :14-07-06:071P? :
6C: 1 : : -3: 1: 649: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :
31: 0 : Ad : -8: 0: 0: 263:Yes : Ok : Ok : 14 :20-08-49:1500? :Translator
31: 1 : Ad : -8: 1: 0: 263:Yes :Error: Ok : 00 :/WRONG/ :..... :Translator
1B: 0 : B : -8: 0: 273: 107:Yes : Ok : Ok : 80 :14-07-06:071PE :Loaded part of microprogram code
1B: 1 : B : -8: 1: 273: 107:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
12: 0 : B : -8: 0: 390: 53:Yes : Ok : Ok : 81 :14-07-06:071PE :Loaded part of microprogram code
12: 1 : B : -8: 1: 390: 53:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
32: 0 : Ad : -8: 0: 453: 20:Yes : Ok : Ok : 17 :20-08-49:1500? :Translator
32: 1 : Ad : -8: 1: 453: 20:Yes : Ok : Ok : 17 :20-08-49:1500? :Translator
3F: 0 : : -8: 0: 477: 16:Yes : Ok : Ok : 21 :14-07-06:0300? :
3F: 1 : : -8: 1: 477: 16:Yes :Error: Ok : 00 :/WRONG/ :..... :
49: 0 : As : -8: 0: 497: 3:Yes : Ok : Ok : CD :14-07-06:071P? :Adaptive data
49: 1 : As : -8: 1: 497: 3:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data
6D: 0 : : -8: 0: 504: 1:Yes : Ok : Ok : 77 :14-07-06:0100? :
6D: 1 : : -8: 1: 504: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :
2D: 0 : : -9: 0: 0: 256:Yes : Ok : Ok : 90 :14-07-06:071P? :
2D: 1 : : -9: 1: 0: 256:Yes :Error: Ok : 00 :/WRONG/ :..... :
22: 0 : B : -9: 0: 266: 68:Yes : Ok : Ok : E3 :14-07-06:8001? :S.M.A.R.T.
22: 1 : B : -9: 1: 266: 68:Yes : Ok : Ok : E3 :14-07-06:8001? :S.M.A.R.T.
17: 0 : B : -9: 0: 338: 35:Yes : Ok : Ok : 6A :14-07-06:071PE :Loaded part of microprogram code
17: 1 : B : -9: 1: 338: 35:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
15: 0 : B : -9: 0: 383: 14:Yes : Ok : Ok : 39 :14-07-06:071PE :Loaded part of microprogram code
15: 1 : B : -9: 1: 383: 14:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
34: 0 : C : -9: 0: 407: 12:Yes : Ok : Ok : A0 :14-07-06:1500? :G-List (Grown defect list)
34: 1 : C : -9: 1: 407: 12:Yes :Error: Ok : 00 :/WRONG/ :..... :G-List (Grown defect list)
50: 0 : As : -9: 0: 423: 3:Yes : Ok : Ok : 43 :14-07-06:071P? :Parameters table 1
50: 1 : As : -9: 1: 423: 3:Yes :Error: Ok : 00 :/WRONG/ :..... :Parameters table 1
62: 0 : : -9: 0: 430: 1:Yes : Ok : Ok : 5B :14-07-06:071P? :
62: 1 : : -9: 1: 430: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :
2E: 0 : B : -10: 0: 0: 256:Yes : Ok : Ok : 8F :14-07-06:071P? :Loaded part of microprogram code
2E: 1 : B : -10: 1: 0: 256:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
24: 0 : B : -10: 0: 266: 68:Yes : Ok : Ok : B6 :14-07-06:8001? :S.M.A.R.T. Log (reserved)
24: 1 : B : -10: 1: 266: 68:Yes :Error: Ok : 00 :/WRONG/ :..... :S.M.A.R.T. Log (reserved)
19: 0 : B : -10: 0: 338: 29:Yes : Ok : Ok : DE :14-07-06:071PE :Loaded part of microprogram code
19: 1 : B : -10: 1: 338: 29:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
1F: 0 : B : -10: 0: 377: 18:Yes : Ok : Ok : 7A :14-07-06:071PE :Loaded part of microprogram code
1F: 1 : B : -10: 1: 377: 18:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
6B: 0 : B : -10: 0: 399: 4:Yes : Ok : Ok : B7 :14-07-06:071P? :Loaded part of microprogram code
6B: 1 : B : -10: 1: 399: 4:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
51: 0 : As : -10: 0: 413: 3:Yes : Ok : Ok : A5 :14-07-06:071P? :Parameters table 2
51: 1 : As : -10: 1: 413: 3:Yes :Error: Ok : 00 :/WRONG/ :..... :Parameters table 2
38: 0 : B : -11: 0: 0: 257:Yes : Ok : Ok : 84 :14-07-06:071P? :Loaded part of microprogram code
38: 1 : B : -11: 1: 0: 257:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
23: 0 : B : -11: 0: 261: 68:Yes : Ok : Ok : 57 :14-07-06:8001? :S.M.A.R.T. Log (reserved)
23: 1 : B : -11: 1: 261: 68:Yes :Error: Ok : 00 :/WRONG/ :..... :S.M.A.R.T. Log (reserved)
1C: 0 : B : -11: 0: 333: 27:Yes : Ok : Ok : 07 :14-07-06:071PE :Loaded part of microprogram code
1C: 1 : B : -11: 1: 333: 27:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
39: 0 : B : -11: 0: 370: 17:Yes : Ok : Ok : 74 :14-07-06:071P? :Loaded part of microprogram code
39: 1 : B : -11: 1: 370: 17:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
2F: 0 : B : -11: 0: 391: 6:Yes : Ok : Ok : 63 :14-07-06:071PE :Loaded part of microprogram code
2F: 1 : B : -11: 1: 391: 6:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
3A: 0 : : -11: 0: 401: 3:Yes : Ok : Ok : E7 :14-07-06:0001? :
3A: 1 : : -11: 1: 401: 3:Yes :Error: Ok : 00 :/WRONG/ :..... :
25: 0 : : -12: 0: 0: 257:Yes : Ok : Ok : 97 :14-07-06:071P? :
25: 1 : : -12: 1: 0: 257:Yes :Error: Ok : 00 :/WRONG/ :..... :
21: 0 : B : -12: 0: 261: 68:Yes : Ok : Ok : E4 :14-07-06:8001? :S.M.A.R.T.
21: 1 : B : -12: 1: 261: 68:Yes : Ok : Ok : E4 :14-07-06:8001? :S.M.A.R.T.
14: 0 : B : -12: 0: 333: 27:Yes : Ok : Ok : 8A :14-07-06:071PE :Loaded part of microprogram code
14: 1 : B : -12: 1: 333: 27:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
3E: 0 : : -12: 0: 370: 16:Yes : Ok : Ok : 22 :14-07-06:0300? :
3E: 1 : : -12: 1: 370: 16:Yes :Error: Ok : 00 :/WRONG/ :..... :
29: 0 : : -12: 0: 390: 5:Yes : Ok : Ok : 76 :14-07-06:071P? :
29: 1 : : -12: 1: 390: 5:Yes :Error: Ok : 00 :/WRONG/ :..... :
52: 0 : As : -12: 0: 399: 2:Yes : Ok : Ok : 39 :14-07-06:071P? :Parameters table 3
52: 1 : As : -12: 1: 399: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Parameters table 3
26: 0 : : -13: 0: 0: 129:Yes : Ok : Ok : 17 :14-07-06:071P? :
26: 1 : : -13: 1: 0: 129:Yes :Error: Ok : 00 :/WRONG/ :..... :
41: 0 : As : -13: 0: 133: 63:Yes : Ok : Ok : 93 :14-07-06:071P? :Adaptive data
41: 1 : As : -13: 1: 133: 63:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data
4E: 0 : B : -13: 0: 200: 31:Yes : Ok : Ok : A5 :14-07-06:071P? :Loaded part of microprogram code
4E: 1 : B : -13: 1: 200: 31:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
3C: 0 : : -13: 0: 235: 16:Yes : Ok : Ok : 24 :14-07-06:0300? :
3C: 1 : : -13: 1: 235: 16:Yes :Error: Ok : 00 :/WRONG/ :..... :
2A: 0 : B : -13: 0: 255: 5:Yes : Ok : Ok : 1B :14-07-06:071P? :Loaded part of microprogram code
2A: 1 : B : -13: 1: 255: 5:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
53: 0 : As : -13: 0: 264: 2:Yes : Ok : Ok : 67 :14-07-06:071P? :Parameters table 4
53: 1 : As : -13: 1: 264: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Parameters table 4
B5: 0 : B : -31: 0: 0: 824:Yes : Ok : Ok : 51 :14-07-06:071P? :Loaded part of microprogram code
B5: 1 : B : -31: 1: 0: 824:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
C4: 0 : Dr : -3: 0: 654: 133:Yes : Ok : Ok : 81 :25-07-06:E.11? :Calibrations module
C4: 1 : Dr : -3: 1: 654: 133:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
C5: 0 : Dr : -2: 0: 789: 6:Yes : Ok : Ok : 70 :25-07-06:E.01? :Calibration script (DCM)
C5: 1 : Dr : -2: 1: 789: 6:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibration script (DCM)
CC: 0 : Dr : -2: 0: 795: 12:Yes : Ok : Ok : 22 :25-07-06:E.11? :Calibrations module
CC: 1 : Dr : -2: 1: 795: 12:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
CA: 0 : Dr : -2: 0: 807: 12:Yes : Ok : Ok : 7A :25-07-06:E.11? :Calibrations module
CA: 1 : Dr : -2: 1: 807: 12:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
CB: 0 : Dr : -3: 0: 787: 12:Yes : Ok : Ok : 2C :25-07-06:E.11? :Calibrations module
CB: 1 : Dr : -3: 1: 787: 12:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
CD: 0 : Dr : -3: 0: 799: 12:Yes : Ok : Ok : 6B :25-07-06:E.11? :Calibrations module
CD: 1 : Dr : -3: 1: 799: 12:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
CF: 0 : Dr : -3: 0: 811: 6:Yes : Ok : Ok : F1 :25-07-06:E.11? :Calibrations module
CF: 1 : Dr : -3: 1: 811: 6:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
CE: 0 : Dr : -8: 0: 509: 12:Yes : Ok : Ok : B1 :25-07-06:E.11? :Calibrations module
CE: 1 : Dr : -8: 1: 509: 12:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
91: 0 : Dr : -2: 0: 819: 1:Yes : Ok : Ok : 34 :25-07-06:E.11? :Calibrations module
91: 1 : Dr : -2: 1: 819: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
92: 0 : Dr : -2: 0: 820: 1:Yes : Ok : Ok : 33 :25-07-06:E.11? :Calibrations module
92: 1 : Dr : -2: 1: 820: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
93: 0 : Dr : -3: 0: 817: 6:Yes : Ok : Ok : 2D :25-07-06:E.11? :Calibrations module
93: 1 : Dr : -3: 1: 817: 6:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
C1: 0 : Dr : -2: 0: 821: 1:Yes : Ok : Ok : 1E :25-07-06:E.11? :Calibrations module
C1: 1 : Dr : -2: 1: 821: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
C2: 0 : Dr : -2: 0: 822: 2:Yes : Ok : Ok : 03 :25-07-06:E.11? :Calibrations module
C2: 1 : Dr : -2: 1: 822: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
C7: 0 : Dr : -3: 0: 823: 1:Yes : Ok : Ok : FE :25-07-06:E.11? :Calibrations module
C7: 1 : Dr : -3: 1: 823: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
9E: 0 : Dr : -8: 0: 521: 3:Yes : Ok : Ok : 50 :25-07-06:E.11? :Calibrations module
9E: 1 : Dr : -8: 1: 521: 3:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
C3: 0 : : -8: 0: 524: 105:Yes : Ok : Ok : 9C :25-07-06:E.11? :
C3: 1 : : -8: 1: 524: 105:Yes :Error: Ok : 00 :/WRONG/ :..... :
C6: 0 : : -8: 0: 629: 16:Yes : Ok : Ok : 0E :25-07-06:E.11? :
C6: 1 : : -8: 1: 629: 16:Yes :Error: Ok : 00 :/WRONG/ :..... :
C8: 0 : : -8: 0: 645: 103:Yes : Ok : Ok : AF :25-07-06:E.11? :
C8: 1 : : -8: 1: 645: 103:Yes :Error: Ok : 00 :/WRONG/ :..... :
C9: 0 : : -8: 0: 748: 20:Yes : Ok : Ok : 2D :25-07-06:E.11? :
C9: 1 : : -8: 1: 748: 20:Yes :Error: Ok : 00 :/WRONG/ :..... :
94: 0 : : -8: 0: 768: 10:Yes : Ok : Ok : 29 :25-07-06:E.11? :
94: 1 : : -8: 1: 768: 10:Yes :Error: Ok : 00 :/WRONG/ :..... :
96: 0 : : -9: 0: 432: 64:Yes : Ok : Ok : 44 :25-07-06:E.11? :
96: 1 : : -9: 1: 432: 64:Yes :Error: Ok : 00 :/WRONG/ :..... :
B1: 0 : : -8: 0: 778: 5:Yes : Ok : Ok : FE :25-07-06:0118? :
B1: 1 : : -8: 1: 778: 5:Yes :Error: Ok : 00 :/WRONG/ :..... :
B2: 0 : : -8: 0: 783: 9:Yes : Ok : Ok : A1 :25-07-06:0016? :
B2: 1 : : -8: 1: 783: 9:Yes :Error: Ok : 00 :/WRONG/ :..... :
E0: 0 : Dr : -6: 0: 0: 600:Yes : Ok : Ok : A5 :25-07-06:B327? :Selfscan module
E0: 1 : Dr : -6: 1: 0: 600:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
E8: 0 : Dr : -7: 0: 0: 571:Yes : Ok : Ok : 0B :25-07-06:B327? :Selfscan module
E8: 1 : Dr : -7: 1: 0: 571:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
FE: 0 : Dr : -13: 0: 270: 256:Yes : Ok : Ok : BC :25-07-06:B327? :Selfscan module
FE: 1 : Dr : -13: 1: 270: 256:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
B6: 0 : Dr : -9: 0: 496: 94:Yes : Ok : Ok : 77 :25-07-06:B327? :Selfscan module
B6: 1 : Dr : -9: 1: 496: 94:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
B7: 0 : Dr : -7: 0: 571: 14:Yes : Ok : Ok : E0 :25-07-06:B327? :Selfscan module
B7: 1 : Dr : -7: 1: 571: 14:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
D5: 0 : Dr : -10: 0: 420: 121:Yes : Ok : Ok : B3 :25-07-06:B327? :Selfscan module
D5: 1 : Dr : -10: 1: 420: 121:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
DA: 0 : Dr : -11: 0: 408: 108:Yes : Ok : Ok : 93 :25-07-06:B327? :Selfscan module
DA: 1 : Dr : -11: 1: 408: 108:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
DB: 0 : Dr : -12: 0: 405: 97:Yes : Ok : Ok : 3D :25-07-06:B327? :Selfscan module
DB: 1 : Dr : -12: 1: 405: 97:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
DF: 0 : Dr : -14: 0: 0: 116:Yes : Ok : Ok : 7A :25-07-06:B327? :Selfscan module
DF: 1 : Dr : -14: 1: 0: 116:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
DD: 0 : Dr : -12: 0: 502: 90:Yes : Ok : Ok : F1 :25-07-06:B327? :Selfscan module
DD: 1 : Dr : -12: 1: 502: 90:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
D6: 0 : Dr : -14: 0: 116: 94:Yes : Ok : Ok : E1 :25-07-06:B327? :Selfscan module
D6: 1 : Dr : -14: 1: 116: 94:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
D7: 0 : Dr : -14: 0: 210: 94:Yes : Ok : Ok : 34 :25-07-06:B327? :Selfscan module
D7: 1 : Dr : -14: 1: 210: 94:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
D2: 0 : Dr : -14: 0: 304: 85:Yes : Ok : Ok : BB :25-07-06:B327? :Selfscan module
D2: 1 : Dr : -14: 1: 304: 85:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
BB: 0 : Dr : -14: 0: 389: 91:Yes : Ok : Ok : C9 :25-07-06:B327? :Selfscan module
BB: 1 : Dr : -14: 1: 389: 91:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
D9: 0 : Dr : -11: 0: 516: 79:Yes : Ok : Ok : C1 :25-07-06:B327? :Selfscan module
D9: 1 : Dr : -11: 1: 516: 79:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
D4: 0 : Dr : -14: 0: 480: 78:Yes : Ok : Ok : 59 :25-07-06:B327? :Selfscan module
D4: 1 : Dr : -14: 1: 480: 78:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
DC: 0 : Dr : -13: 0: 526: 73:Yes : Ok : Ok : 1C :25-07-06:B327? :Selfscan module
DC: 1 : Dr : -13: 1: 526: 73:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
D0: 0 : Dr : -15: 0: 0: 71:Yes : Ok : Ok : DA :25-07-06:B327? :Selfscan module
D0: 1 : Dr : -15: 1: 0: 71:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
D3: 0 : Dr : -15: 0: 71: 71:Yes : Ok : Ok : 46 :25-07-06:B327? :Selfscan module
D3: 1 : Dr : -15: 1: 71: 71:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
BA: 0 : Dr : -15: 0: 142: 90:Yes : Ok : Ok : 2E :25-07-06:B327? :Selfscan module
BA: 1 : Dr : -15: 1: 142: 90:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
B9: 0 : Dr : -15: 0: 232: 90:Yes : Ok : Ok : 01 :25-07-06:B327? :Selfscan module
B9: 1 : Dr : -15: 1: 232: 90:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
BC: 0 : Dr : -15: 0: 322: 89:Yes : Ok : Ok : E1 :25-07-06:B327? :Selfscan module
BC: 1 : Dr : -15: 1: 322: 89:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
D8: 0 : Dr : -15: 0: 411: 81:Yes : Ok : Ok : 1F :25-07-06:B327? :Selfscan module
D8: 1 : Dr : -15: 1: 411: 81:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
BD: 0 : : -16: 0: 0: 113:Yes : Ok : Ok : 05 :25-07-06:B327? :
BD: 1 : : -16: 1: 0: 113:Yes :Error:Error: 00/81 :13-10-02:B327? :
FD: 0 : Dr : -15: 0: 492: 64:Yes : Ok : Ok : 0D :25-07-06:B327? :Selfscan module
FD: 1 : Dr : -15: 1: 492: 64:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
FB: 0 : Dr : -16: 0: 113: 256:Yes : Ok : Ok : BF :25-07-06:B327? :Selfscan module
FB: 1 : Dr : -16: 1: 113: 256:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
E6: 0 : Dr : -16: 0: 369: 64:Yes : Ok : Ok : 7F :25-07-06:B327? :Selfscan module
E6: 1 : Dr : -16: 1: 369: 64:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
E7: 0 : Dr : -10: 0: 541: 32:Yes : Ok : Ok : 2D :27-10-06:B327? :Selfscan module
E7: 1 : Dr : -10: 1: 541: 32:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
BE: 0 : Dr : -10: 0: 573: 27:Yes : Ok : Ok : 8E :25-07-06:B327? :Selfscan module
BE: 1 : Dr : -10: 1: 573: 27:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
B8: 0 : Dr : -7: 0: 585: 2:Yes : Ok : Ok : A4 :27-10-06:B327? :Selfscan module
B8: 1 : Dr : -7: 1: 585: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
BF: 0 : Dr : -7: 0: 587: 8:Yes : Ok : Ok : B7 :25-07-06:B327? :Selfscan module
BF: 1 : Dr : -7: 1: 587: 8:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
FC: 0 : Dr : -7: 0: 595: 4:Yes : Ok : Ok : B5 :25-07-06:B327? :Selfscan module
FC: 1 : Dr : -7: 1: 595: 4:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
EE: 0 : Dr : -9: 0: 590: 5:Yes : Ok : Ok : 42 :25-07-06:B327? :Selfscan module
EE: 1 : Dr : -9: 1: 590: 5:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
F4: 0 : : -16: 0: 433: 99:Yes : Ok : Ok : B4 :25-07-06:B327? :
F4: 1 : : -16: 1: 433: 99:Yes :Error: Ok : 00 :/WRONG/ :..... :
D1: 0 : : -17: 0: 0: 108:Yes : Ok : Ok : C1 :25-07-06:B327? :
D1: 1 : : -17: 1: 0: 108:Yes :Error:Error: 00/81 :13-10-02:B327? :
E1: 0 : Dr : -33: 0: 0: 600:Yes : Ok : Ok : D7 :25-07-06:B327? :Selfscan module
E1: 1 : Dr : -33: 1: 0: 600:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
E2: 0 : Dr : -34: 0: 0: 600:Yes : Ok : Ok : CA :25-07-06:B327? :Selfscan module
E2: 1 : Dr : -34: 1: 0: 600:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
E3: 0 : Dr : -35: 0: 0: 600:Yes : Ok : Ok : E0 :25-07-06:B327? :Selfscan module
E3: 1 : Dr : -35: 1: 0: 600:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
E4: 0 : Dr : -36: 0: 0: 600:Yes : Ok : Ok : 23 :25-07-06:B327? :Selfscan module
E4: 1 : Dr : -36: 1: 0: 600:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
E5: 0 : Dr : -37: 0: 0: 600:Yes : Ok : Ok : C3 :25-07-06:B327? :Selfscan module
E5: 1 : Dr : -37: 1: 0: 600:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
ZeBong
" Россия еще раз"
 Post subject: Re: WD5000KS-55MNB0
PostPosted: November 29th, 2008, 10:59
Zone allocation table
Zones number............................ : 78
NN :Beg LBA : End LBA : SPT0 : SPT1 : SPT2 : SPT3 : SPT4 : SPT5
1 :0 : 0 : 864 : 864 : 864 : 864 : 864 : 0
2 :0 : 77 074 686 : 1332 : 1296 : 1339 : 1296 : 1332 : 0
3 :77 074 687 : 97 665 918 : 1332 : 1296 : 1323 : 1296 : 1332 : 0
4 :97 665 919 : 99 051 288 : 1332 : 1296 : 1323 : 1296 : 1332 : 0
5 :99 051 289 : 105 907 913 : 1296 : 1296 : 1323 : 1296 : 1296 : 0
6 :105 907 914 : 170 047 926 : 1296 : 1256 : 1323 : 1256 : 1296 : 0
7 :170 047 927 : 174 102 660 : 1296 : 1256 : 1296 : 1256 : 1296 : 0
8 :174 102 661 : 184 844 196 : 1296 : 1234 : 1296 : 1234 : 1296 : 0
9 :184 844 197 : 186 183 126 : 1296 : 1234 : 1296 : 1234 : 1296 : 0
10 :186 183 127 : 254 177 226 : 1296 : 1234 : 1296 : 1234 : 1296 : 0
11 :254 177 227 : 255 778 110 : 1296 : 1234 : 1296 : 1234 : 1296 : 0
12 :255 778 111 : 261 334 791 : 1296 : 1209 : 1296 : 1209 : 1296 : 0
13 :261 334 792 : 268 391 226 : 1252 : 1209 : 1296 : 1209 : 1252 : 0
14 :268 391 227 : 323 493 884 : 1252 : 1209 : 1296 : 1209 : 1252 : 0
15 :323 493 885 : 342 699 510 : 1252 : 1188 : 1296 : 1188 : 1252 : 0
16 :342 699 511 : 344 509 094 : 1252 : 1188 : 1252 : 1188 : 1252 : 0
17 :344 509 095 : 348 097 675 : 1224 : 1188 : 1252 : 1188 : 1224 : 0
18 :348 097 676 : 397 377 100 : 1224 : 1188 : 1252 : 1188 : 1224 : 0
19 :397 377 101 : 410 503 768 : 1224 : 1152 : 1252 : 1152 : 1224 : 0
20 :410 503 769 : 413 000 088 : 1188 : 1152 : 1252 : 1152 : 1188 : 0
21 :413 000 089 : 418 466 908 : 1188 : 1152 : 1252 : 1152 : 1188 : 0
22 :418 466 909 : 455 583 266 : 1188 : 1152 : 1215 : 1152 : 1188 : 0
23 :455 583 267 : 475 145 894 : 1188 : 1116 : 1215 : 1116 : 1188 : 0
24 :475 145 895 : 478 315 424 : 1188 : 1116 : 1215 : 1116 : 1188 : 0
25 :478 315 425 : 487 310 420 : 1188 : 1116 : 1188 : 1116 : 1188 : 0
26 :487 310 421 : 525 014 375 : 1152 : 1116 : 1188 : 1116 : 1152 : 0
27 :525 014 376 : 533 777 207 : 1152 : 1080 : 1188 : 1080 : 1152 : 0
28 :533 777 208 : 541 489 615 : 1110 : 1080 : 1188 : 1080 : 1110 : 0
29 :541 489 616 : 549 172 633 : 1110 : 1080 : 1141 : 1080 : 1110 : 0
30 :549 172 634 : 586 869 306 : 1110 : 1080 : 1141 : 1080 : 1110 : 0
31 :586 869 307 : 590 564 378 : 1110 : 1080 : 1141 : 1080 : 1110 : 0
32 :590 564 379 : 594 907 806 : 1080 : 1080 : 1141 : 1080 : 1080 : 0
33 :594 907 807 : 600 606 601 : 1080 : 1080 : 1116 : 1080 : 1080 : 0
34 :600 606 602 : 633 812 660 : 1080 : 1036 : 1116 : 1036 : 1080 : 0
35 :633 812 661 : 634 706 468 : 1080 : 1036 : 1080 : 1036 : 1080 : 0
36 :634 706 469 : 641 380 807 : 1080 : 1036 : 1080 : 1036 : 1080 : 0
37 :641 380 808 : 659 878 510 : 1080 : 1008 : 1080 : 1008 : 1080 : 0
38 :659 878 511 : 675 483 556 : 1036 : 1008 : 1080 : 1008 : 1036 : 0
39 :675 483 557 : 681 685 607 : 1036 : 972 : 1080 : 972 : 1036 : 0
40 :681 685 608 : 692 953 142 : 1036 : 972 : 1080 : 972 : 1036 : 0
41 :692 953 143 : 696 518 195 : 999 : 972 : 1080 : 972 : 999 : 0
42 :696 518 196 : 725 669 450 : 999 : 972 : 1032 : 972 : 999 : 0
43 :725 669 451 : 728 547 080 : 999 : 936 : 1032 : 936 : 999 : 0
44 :728 547 081 : 730 389 452 : 999 : 936 : 1032 : 936 : 999 : 0
45 :730 389 453 : 732 618 074 : 972 : 936 : 1032 : 936 : 972 : 0
46 :732 618 075 : 762 876 697 : 972 : 936 : 999 : 936 : 972 : 0
47 :762 876 698 : 763 278 565 : 972 : 936 : 999 : 936 : 972 : 0
48 :763 278 566 : 766 636 609 : 972 : 894 : 999 : 894 : 972 : 0
49 :766 636 610 : 767 605 939 : 925 : 894 : 999 : 894 : 925 : 0
50 :767 605 940 : 799 193 709 : 925 : 894 : 956 : 894 : 925 : 0
51 :799 193 710 : 804 522 529 : 925 : 864 : 956 : 864 : 925 : 0
52 :804 522 530 : 808 463 510 : 891 : 864 : 956 : 864 : 891 : 0
53 :808 463 511 : 812 570 426 : 891 : 864 : 918 : 864 : 891 : 0
54 :812 570 427 : 837 764 925 : 891 : 864 : 918 : 864 : 891 : 0
55 :837 764 926 : 841 249 137 : 864 : 864 : 918 : 864 : 864 : 0
56 :841 249 138 : 846 355 917 : 864 : 864 : 918 : 864 : 864 : 0
57 :846 355 918 : 846 537 444 : 864 : 864 : 885 : 864 : 864 : 0
58 :846 537 445 : 865 642 027 : 864 : 828 : 885 : 828 : 864 : 0
59 :865 642 028 : 871 085 861 : 864 : 792 : 885 : 792 : 864 : 0
60 :871 085 862 : 874 063 394 : 864 : 792 : 864 : 792 : 864 : 0
61 :874 063 395 : 878 075 054 : 864 : 792 : 864 : 792 : 864 : 0
62 :878 075 055 : 898 935 498 : 820 : 792 : 864 : 792 : 820 : 0
63 :898 935 499 : 901 471 158 : 820 : 768 : 864 : 768 : 820 : 0
64 :901 471 159 : 902 138 598 : 792 : 768 : 864 : 768 : 792 : 0
65 :902 138 599 : 905 622 034 : 792 : 768 : 864 : 768 : 792 : 0
66 :905 622 035 : 919 109 722 : 792 : 768 : 810 : 768 : 792 : 0
67 :919 109 723 : 925 760 578 : 792 : 740 : 810 : 740 : 792 : 0
68 :925 760 579 : 935 006 238 : 756 : 740 : 810 : 740 : 756 : 0
69 :935 006 239 : 937 384 488 : 756 : 740 : 777 : 740 : 756 : 0
70 :937 384 489 : 942 442 536 : 756 : 740 : 777 : 740 : 756 : 0
71 :942 442 537 : 951 150 472 : 756 : 709 : 777 : 709 : 756 : 0
72 :951 150 473 : 955 795 185 : 756 : 709 : 777 : 709 : 756 : 0
73 :955 795 186 : 958 866 452 : 740 : 709 : 777 : 709 : 740 : 0
74 :958 866 453 : 965 563 620 : 740 : 709 : 756 : 709 : 740 : 0
75 :965 563 621 : 966 919 128 : 709 : 709 : 756 : 709 : 709 : 0
76 :966 919 129 : 971 823 229 : 709 : 691 : 756 : 691 : 709 : 0
77 :971 823 230 : 976 773 167 : 709 : 691 : 756 : 691 : 709 : 0
78 :976 773 167 : 976 773 167 : 709 : 691 : 720 : 691 : 709 : 0
MODULES DIRECTORY (01)
SA Copy num Location State
0 c: -1 H: 0 Ok
1 c: -1 H: 1 Ok
Modules number.......................... : 125
CONFIGURATION MODULE (02)
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Header
HDD Identify
Model................................... : WDC WD5000KS-55MNB0
Serial number........................... : WD-WCANUxxxxxxxxx.....
Logical parameters...................... : LBA : 976 773 167
Master-password
Set..................................... : No
User-password
Security level.......................... : High
Log DCM (C5)
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Header
Zeus ZEU
+--- Head DCM Codes -------- Media DCM Codes -----+
| ALPS: A,B | SHOWA: F,K,Q,7 |
| SAE: D | TRACE: D,E,J,M,P,3,4,9 |
| WDB : 7 | EXP : L,N,R |
P-List (33)
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Header
Defects number.......................... : 1649
G-List (34)
0 c: -9 H: 0 Ok
1 c: -9 H: 1 Header
Defects number.......................... : 0
ZeBong
" Россия еще раз"
PostPosted: December 1st, 2008, 14:30
I see that the problem is when i cut the heads the LBA now is different.
So the disk was the data with 8 heads but now is only work with 6 heads.
Anyone was work in a case like this:
Disk only detect by the pc3k iff cut head 6 and 7, with all the LBA size correct ID and Serial.
Afther that the disk is detect and in the DE i can edit sectores but all came with "dark green" ECC Error but it have data there.
Also i try the head map without the head 6 and 7 , and the problem is the same, "dark green" ECC Error.
So i think i just have to know how can i get the data by change the LBA size ?
Anyone have any ideia ?
ZeBong
ZeBong
" Россия еще раз"
PostPosted: December 12th, 2008, 17:14
I had the same problem, I got two cases from with same problem, when i disable Heads 6,7 , HD is identified, but look if you have ACE manuals, there is detailed decribtion of how to disable heads, you should remove defects from p-list, that are related to the defective heads, 6 and 7, if you do not have the manuals, tell me, i will check on my cases and inform you
good luck
PostPosted: December 12th, 2008, 19:09
I miss that in the manual :( also ask support off ace but nothing about that ... :(
8.2.1. Head disabling procedure
Disable the translator, To disable the translator, set to zero the checksum byte in modules ID=20h and ID=25h
Enter Defect list editor (P-List), select Remove defects for head.
Clear G-List
Edit HDD ID menu to correct the Max LBA
Perform internal formatting using P-List
Run a logical test and hide all revealed defects
ZeBong
" Россия еще раз"
PostPosted: December 16th, 2008, 5:25
Clear G-List
Is this the same procedure as used in CYL32 and MARVEL? Also, is this procedure with HDD repair or HDD recovery in mind?
PostPosted: December 16th, 2008, 18:54
It dont work for this disk WD5000KS-55MNB0
Anyone knows what can be done to recovery data , without two heads.
Rebuild new translator ?
ZeBong
" Россия еще раз"
PostPosted: December 16th, 2008, 19:24
I don't want to sound like I am stating the obvious, but
since you want to recover data, have you tried a head replacement?
PostPosted: December 17th, 2008, 7:58
I think the aim here is to try to get data, even a minimal ammount, without head repalcement as head replacement on these disks is actually quite difficult
