| WD5000KS-55MNB0 http://forum.hddguru.com/viewtopic.php?f=11&t=10601 |
Page 1 of 1 |
| Author: | zebong [ November 29th, 2008, 10:56 ] |
| Post subject: | WD5000KS-55MNB0 |
Hello, i have this disk that was clicking so i cut head 6/7 and the clik was gone, and i get ID in the pc3k. When i try to copy with DE, it give ECC error. Also i try to use the head maps in DE, but nothing new.. dont copy. I put here the SA Structure test: i have a lot off erros in the COPY 1: The modules is all green when i test it: Anyone know how can i solve this case: Thanks ZeBong 28: 1 : : -1: 1: 238: 16:Yes :Error: Ok : 00 :/WRONG/ :..... : 0C: 0 : B : -1: 0: 258: 5:Yes : Ok : Ok : 82 :14-07-06:0101? :Models table 0C: 1 : B : -1: 1: 258: 5:Yes :Error: Ok : 00 :/WRONG/ :..... :Models table 4D: 0 : : -1: 0: 267: 1:Yes : Ok : Ok : 70 :14-07-06:071P? : 4D: 1 : : -1: 1: 267: 1:Yes :Error: Ok : 00 :/WRONG/ :..... : 35: 0 : Dd : -2: 0: 0: 1:Yes : Ok : Ok : 94 :13-10-02:B327? :SA Defects 35: 1 : Dd : -2: 1: 0: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :SA Defects 02: 0 : B : -2: 0: 5: 2:Yes : Ok : Ok : 6D :14-07-06:0800? :Configuration (HDD ID) 02: 1 : B : -2: 1: 5: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Configuration (HDD ID) 33: 0 : Dd : -2: 0: 11: 510:Yes : Ok : Ok : A9 :14-07-06:1500? 33: 1 : Dd : -2: 1: 11: 510:Yes :Error: Ok : 00 :/WRONG/ :..... 06: 0 : B : -2: 0: 525: 127:Yes : Ok : Ok : 78 :14-07-06:0200? :Family models configuration (Alt2) 06: 1 : B : -2: 1: 525: 127:Yes :Error: Ok : 00 :/WRONG/ :..... :Family models configuration (Alt2) 40: 0 : As : -2: 0: 656: 63:Yes : Ok : Ok : 27 :14-07-06:071P? :Adaptive data 40: 1 : As : -2: 1: 656: 63:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data 61: 0 : B : -2: 0: 723: 28:Yes : Ok : Ok : 59 :14-07-06:071PE :Loaded part of microprogram code 61: 1 : B : -2: 1: 723: 28:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 3D: 0 : : -2: 0: 755: 16:Yes : Ok : Ok : 23 :14-07-06:0300? : 3D: 1 : : -2: 1: 755: 16:Yes :Error: Ok : 00 :/WRONG/ :..... : 4A: 0 : As : -2: 0: 775: 5:Yes : Ok : Ok : D7 :14-07-06:071P? :Adaptive data 4A: 1 : As : -2: 1: 775: 5:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data 37: 0 : : -2: 0: 784: 1:Yes : Ok : Ok : 4E :14-07-06:0100? : 37: 1 : : -2: 1: 784: 1:Yes :Error: Ok : 00 :/WRONG/ :..... : 11: 0 : B : -3: 0: 0: 372:Yes : Ok : Ok : B8 :14-07-06:071PE :Loaded part of microprogram code 11: 1 : B : -3: 1: 0: 372:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 04: 0 : B : -3: 0: 392: 127:Yes : Ok : Ok : C9 :14-07-06:0200? :Family models configuration (Main) 04: 1 : B : -3: 1: 392: 127:Yes :Error: Ok : 00 :/WRONG/ :..... :Family models configuration (Main) 43: 0 : As : -3: 0: 523: 63:Yes : Ok : Ok : B9 :14-07-06:071P? :Adaptive data 43: 1 : As : -3: 1: 523: 63:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data 03: 0 : : -3: 0: 590: 26:Yes : Ok : Ok : 8C :14-07-06:0200? : 03: 1 : : -3: 1: 590: 26:Yes :Error: Ok : 00 :/WRONG/ :..... : 3B: 0 : : -3: 0: 620: 16:Yes : Ok : Ok : A9 :14-07-06:0300? : 3B: 1 : : -3: 1: 620: 16:Yes :Error: Ok : 00 :/WRONG/ :..... : 36: 0 : : -3: 0: 640: 5:Yes : Ok : Ok : 57 :14-07-06:071P? : 36: 1 : : -3: 1: 640: 5:Yes :Error: Ok : 00 :/WRONG/ :..... : 6C: 0 : : -3: 0: 649: 1:Yes : Ok : Ok : 51 :14-07-06:071P? : 6C: 1 : : -3: 1: 649: 1:Yes :Error: Ok : 00 :/WRONG/ :..... : 31: 0 : Ad : -8: 0: 0: 263:Yes : Ok : Ok : 14 :20-08-49:1500? :Translator 31: 1 : Ad : -8: 1: 0: 263:Yes :Error: Ok : 00 :/WRONG/ :..... :Translator 1B: 0 : B : -8: 0: 273: 107:Yes : Ok : Ok : 80 :14-07-06:071PE :Loaded part of microprogram code 1B: 1 : B : -8: 1: 273: 107:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 12: 0 : B : -8: 0: 390: 53:Yes : Ok : Ok : 81 :14-07-06:071PE :Loaded part of microprogram code 12: 1 : B : -8: 1: 390: 53:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 32: 0 : Ad : -8: 0: 453: 20:Yes : Ok : Ok : 17 :20-08-49:1500? :Translator 32: 1 : Ad : -8: 1: 453: 20:Yes : Ok : Ok : 17 :20-08-49:1500? :Translator 3F: 0 : : -8: 0: 477: 16:Yes : Ok : Ok : 21 :14-07-06:0300? : 3F: 1 : : -8: 1: 477: 16:Yes :Error: Ok : 00 :/WRONG/ :..... : 49: 0 : As : -8: 0: 497: 3:Yes : Ok : Ok : CD :14-07-06:071P? :Adaptive data 49: 1 : As : -8: 1: 497: 3:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data 6D: 0 : : -8: 0: 504: 1:Yes : Ok : Ok : 77 :14-07-06:0100? : 6D: 1 : : -8: 1: 504: 1:Yes :Error: Ok : 00 :/WRONG/ :..... : 2D: 0 : : -9: 0: 0: 256:Yes : Ok : Ok : 90 :14-07-06:071P? : 2D: 1 : : -9: 1: 0: 256:Yes :Error: Ok : 00 :/WRONG/ :..... : 22: 0 : B : -9: 0: 266: 68:Yes : Ok : Ok : E3 :14-07-06:8001? :S.M.A.R.T. 22: 1 : B : -9: 1: 266: 68:Yes : Ok : Ok : E3 :14-07-06:8001? :S.M.A.R.T. 17: 0 : B : -9: 0: 338: 35:Yes : Ok : Ok : 6A :14-07-06:071PE :Loaded part of microprogram code 17: 1 : B : -9: 1: 338: 35:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 15: 0 : B : -9: 0: 383: 14:Yes : Ok : Ok : 39 :14-07-06:071PE :Loaded part of microprogram code 15: 1 : B : -9: 1: 383: 14:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 34: 0 : C : -9: 0: 407: 12:Yes : Ok : Ok : A0 :14-07-06:1500? :G-List (Grown defect list) 34: 1 : C : -9: 1: 407: 12:Yes :Error: Ok : 00 :/WRONG/ :..... :G-List (Grown defect list) 50: 0 : As : -9: 0: 423: 3:Yes : Ok : Ok : 43 :14-07-06:071P? 50: 1 : As : -9: 1: 423: 3:Yes :Error: Ok : 00 :/WRONG/ :..... 62: 0 : : -9: 0: 430: 1:Yes : Ok : Ok : 5B :14-07-06:071P? : 62: 1 : : -9: 1: 430: 1:Yes :Error: Ok : 00 :/WRONG/ :..... : 2E: 0 : B : -10: 0: 0: 256:Yes : Ok : Ok : 8F :14-07-06:071P? :Loaded part of microprogram code 2E: 1 : B : -10: 1: 0: 256:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 24: 0 : B : -10: 0: 266: 68:Yes : Ok : Ok : B6 :14-07-06:8001? :S.M.A.R.T. Log (reserved) 24: 1 : B : -10: 1: 266: 68:Yes :Error: Ok : 00 :/WRONG/ :..... :S.M.A.R.T. Log (reserved) 19: 0 : B : -10: 0: 338: 29:Yes : Ok : Ok : DE :14-07-06:071PE :Loaded part of microprogram code 19: 1 : B : -10: 1: 338: 29:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 1F: 0 : B : -10: 0: 377: 18:Yes : Ok : Ok : 7A :14-07-06:071PE :Loaded part of microprogram code 1F: 1 : B : -10: 1: 377: 18:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 6B: 0 : B : -10: 0: 399: 4:Yes : Ok : Ok : B7 :14-07-06:071P? :Loaded part of microprogram code 6B: 1 : B : -10: 1: 399: 4:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 51: 0 : As : -10: 0: 413: 3:Yes : Ok : Ok : A5 :14-07-06:071P? 51: 1 : As : -10: 1: 413: 3:Yes :Error: Ok : 00 :/WRONG/ :..... 38: 0 : B : -11: 0: 0: 257:Yes : Ok : Ok : 84 :14-07-06:071P? :Loaded part of microprogram code 38: 1 : B : -11: 1: 0: 257:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 23: 0 : B : -11: 0: 261: 68:Yes : Ok : Ok : 57 :14-07-06:8001? :S.M.A.R.T. Log (reserved) 23: 1 : B : -11: 1: 261: 68:Yes :Error: Ok : 00 :/WRONG/ :..... :S.M.A.R.T. Log (reserved) 1C: 0 : B : -11: 0: 333: 27:Yes : Ok : Ok : 07 :14-07-06:071PE :Loaded part of microprogram code 1C: 1 : B : -11: 1: 333: 27:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 39: 0 : B : -11: 0: 370: 17:Yes : Ok : Ok : 74 :14-07-06:071P? :Loaded part of microprogram code 39: 1 : B : -11: 1: 370: 17:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 2F: 0 : B : -11: 0: 391: 6:Yes : Ok : Ok : 63 :14-07-06:071PE :Loaded part of microprogram code 2F: 1 : B : -11: 1: 391: 6:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 3A: 0 : : -11: 0: 401: 3:Yes : Ok : Ok : E7 :14-07-06:0001? : 3A: 1 : : -11: 1: 401: 3:Yes :Error: Ok : 00 :/WRONG/ :..... : 25: 0 : : -12: 0: 0: 257:Yes : Ok : Ok : 97 :14-07-06:071P? : 25: 1 : : -12: 1: 0: 257:Yes :Error: Ok : 00 :/WRONG/ :..... : 21: 0 : B : -12: 0: 261: 68:Yes : Ok : Ok : E4 :14-07-06:8001? :S.M.A.R.T. 21: 1 : B : -12: 1: 261: 68:Yes : Ok : Ok : E4 :14-07-06:8001? :S.M.A.R.T. 14: 0 : B : -12: 0: 333: 27:Yes : Ok : Ok : 8A :14-07-06:071PE :Loaded part of microprogram code 14: 1 : B : -12: 1: 333: 27:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 3E: 0 : : -12: 0: 370: 16:Yes : Ok : Ok : 22 :14-07-06:0300? : 3E: 1 : : -12: 1: 370: 16:Yes :Error: Ok : 00 :/WRONG/ :..... : 29: 0 : : -12: 0: 390: 5:Yes : Ok : Ok : 76 :14-07-06:071P? : 29: 1 : : -12: 1: 390: 5:Yes :Error: Ok : 00 :/WRONG/ :..... : 52: 0 : As : -12: 0: 399: 2:Yes : Ok : Ok : 39 :14-07-06:071P? 52: 1 : As : -12: 1: 399: 2:Yes :Error: Ok : 00 :/WRONG/ :..... 26: 0 : : -13: 0: 0: 129:Yes : Ok : Ok : 17 :14-07-06:071P? : 26: 1 : : -13: 1: 0: 129:Yes :Error: Ok : 00 :/WRONG/ :..... : 41: 0 : As : -13: 0: 133: 63:Yes : Ok : Ok : 93 :14-07-06:071P? :Adaptive data 41: 1 : As : -13: 1: 133: 63:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data 4E: 0 : B : -13: 0: 200: 31:Yes : Ok : Ok : A5 :14-07-06:071P? :Loaded part of microprogram code 4E: 1 : B : -13: 1: 200: 31:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 3C: 0 : : -13: 0: 235: 16:Yes : Ok : Ok : 24 :14-07-06:0300? : 3C: 1 : : -13: 1: 235: 16:Yes :Error: Ok : 00 :/WRONG/ :..... : 2A: 0 : B : -13: 0: 255: 5:Yes : Ok : Ok : 1B :14-07-06:071P? :Loaded part of microprogram code 2A: 1 : B : -13: 1: 255: 5:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code 53: 0 : As : -13: 0: 264: 2:Yes : Ok : Ok : 67 :14-07-06:071P? 53: 1 : As : -13: 1: 264: 2:Yes :Error: Ok : 00 :/WRONG/ :..... B5: 0 : B : -31: 0: 0: 824:Yes : Ok : Ok : 51 :14-07-06:071P? :Loaded part of microprogram code B5: 1 : B : -31: 1: 0: 824:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code C4: 0 : Dr : -3: 0: 654: 133:Yes : Ok : Ok : 81 :25-07-06:E.11? :Calibrations module C4: 1 : Dr : -3: 1: 654: 133:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module C5: 0 : Dr : -2: 0: 789: 6:Yes : Ok : Ok : 70 :25-07-06:E.01? :Calibration script (DCM) C5: 1 : Dr : -2: 1: 789: 6:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibration script (DCM) CC: 0 : Dr : -2: 0: 795: 12:Yes : Ok : Ok : 22 :25-07-06:E.11? :Calibrations module CC: 1 : Dr : -2: 1: 795: 12:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module CA: 0 : Dr : -2: 0: 807: 12:Yes : Ok : Ok : 7A :25-07-06:E.11? :Calibrations module CA: 1 : Dr : -2: 1: 807: 12:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module CB: 0 : Dr : -3: 0: 787: 12:Yes : Ok : Ok : 2C :25-07-06:E.11? :Calibrations module CB: 1 : Dr : -3: 1: 787: 12:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module CD: 0 : Dr : -3: 0: 799: 12:Yes : Ok : Ok : 6B :25-07-06:E.11? :Calibrations module CD: 1 : Dr : -3: 1: 799: 12:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module CF: 0 : Dr : -3: 0: 811: 6:Yes : Ok : Ok : F1 :25-07-06:E.11? :Calibrations module CF: 1 : Dr : -3: 1: 811: 6:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module CE: 0 : Dr : -8: 0: 509: 12:Yes : Ok : Ok : B1 :25-07-06:E.11? :Calibrations module CE: 1 : Dr : -8: 1: 509: 12:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module 91: 0 : Dr : -2: 0: 819: 1:Yes : Ok : Ok : 34 :25-07-06:E.11? :Calibrations module 91: 1 : Dr : -2: 1: 819: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module 92: 0 : Dr : -2: 0: 820: 1:Yes : Ok : Ok : 33 :25-07-06:E.11? :Calibrations module 92: 1 : Dr : -2: 1: 820: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module 93: 0 : Dr : -3: 0: 817: 6:Yes : Ok : Ok : 2D :25-07-06:E.11? :Calibrations module 93: 1 : Dr : -3: 1: 817: 6:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module C1: 0 : Dr : -2: 0: 821: 1:Yes : Ok : Ok : 1E :25-07-06:E.11? :Calibrations module C1: 1 : Dr : -2: 1: 821: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module C2: 0 : Dr : -2: 0: 822: 2:Yes : Ok : Ok : 03 :25-07-06:E.11? :Calibrations module C2: 1 : Dr : -2: 1: 822: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module C7: 0 : Dr : -3: 0: 823: 1:Yes : Ok : Ok : FE :25-07-06:E.11? :Calibrations module C7: 1 : Dr : -3: 1: 823: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module 9E: 0 : Dr : -8: 0: 521: 3:Yes : Ok : Ok : 50 :25-07-06:E.11? :Calibrations module 9E: 1 : Dr : -8: 1: 521: 3:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module C3: 0 : : -8: 0: 524: 105:Yes : Ok : Ok : 9C :25-07-06:E.11? : C3: 1 : : -8: 1: 524: 105:Yes :Error: Ok : 00 :/WRONG/ :..... : C6: 0 : : -8: 0: 629: 16:Yes : Ok : Ok : 0E :25-07-06:E.11? : C6: 1 : : -8: 1: 629: 16:Yes :Error: Ok : 00 :/WRONG/ :..... : C8: 0 : : -8: 0: 645: 103:Yes : Ok : Ok : AF :25-07-06:E.11? : C8: 1 : : -8: 1: 645: 103:Yes :Error: Ok : 00 :/WRONG/ :..... : C9: 0 : : -8: 0: 748: 20:Yes : Ok : Ok : 2D :25-07-06:E.11? : C9: 1 : : -8: 1: 748: 20:Yes :Error: Ok : 00 :/WRONG/ :..... : 94: 0 : : -8: 0: 768: 10:Yes : Ok : Ok : 29 :25-07-06:E.11? : 94: 1 : : -8: 1: 768: 10:Yes :Error: Ok : 00 :/WRONG/ :..... : 96: 0 : : -9: 0: 432: 64:Yes : Ok : Ok : 44 :25-07-06:E.11? : 96: 1 : : -9: 1: 432: 64:Yes :Error: Ok : 00 :/WRONG/ :..... : B1: 0 : : -8: 0: 778: 5:Yes : Ok : Ok : FE :25-07-06:0118? : B1: 1 : : -8: 1: 778: 5:Yes :Error: Ok : 00 :/WRONG/ :..... : B2: 0 : : -8: 0: 783: 9:Yes : Ok : Ok : A1 :25-07-06:0016? : B2: 1 : : -8: 1: 783: 9:Yes :Error: Ok : 00 :/WRONG/ :..... : E0: 0 : Dr : -6: 0: 0: 600:Yes : Ok : Ok : A5 :25-07-06:B327? :Selfscan module E0: 1 : Dr : -6: 1: 0: 600:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module E8: 0 : Dr : -7: 0: 0: 571:Yes : Ok : Ok : 0B :25-07-06:B327? :Selfscan module E8: 1 : Dr : -7: 1: 0: 571:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module FE: 0 : Dr : -13: 0: 270: 256:Yes : Ok : Ok : BC :25-07-06:B327? :Selfscan module FE: 1 : Dr : -13: 1: 270: 256:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module B6: 0 : Dr : -9: 0: 496: 94:Yes : Ok : Ok : 77 :25-07-06:B327? :Selfscan module B6: 1 : Dr : -9: 1: 496: 94:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module B7: 0 : Dr : -7: 0: 571: 14:Yes : Ok : Ok : E0 :25-07-06:B327? :Selfscan module B7: 1 : Dr : -7: 1: 571: 14:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module D5: 0 : Dr : -10: 0: 420: 121:Yes : Ok : Ok : B3 :25-07-06:B327? :Selfscan module D5: 1 : Dr : -10: 1: 420: 121:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module DA: 0 : Dr : -11: 0: 408: 108:Yes : Ok : Ok : 93 :25-07-06:B327? :Selfscan module DA: 1 : Dr : -11: 1: 408: 108:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module DB: 0 : Dr : -12: 0: 405: 97:Yes : Ok : Ok : 3D :25-07-06:B327? :Selfscan module DB: 1 : Dr : -12: 1: 405: 97:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module DF: 0 : Dr : -14: 0: 0: 116:Yes : Ok : Ok : 7A :25-07-06:B327? :Selfscan module DF: 1 : Dr : -14: 1: 0: 116:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module DD: 0 : Dr : -12: 0: 502: 90:Yes : Ok : Ok : F1 :25-07-06:B327? :Selfscan module DD: 1 : Dr : -12: 1: 502: 90:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module D6: 0 : Dr : -14: 0: 116: 94:Yes : Ok : Ok : E1 :25-07-06:B327? :Selfscan module D6: 1 : Dr : -14: 1: 116: 94:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module D7: 0 : Dr : -14: 0: 210: 94:Yes : Ok : Ok : 34 :25-07-06:B327? :Selfscan module D7: 1 : Dr : -14: 1: 210: 94:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module D2: 0 : Dr : -14: 0: 304: 85:Yes : Ok : Ok : BB :25-07-06:B327? :Selfscan module D2: 1 : Dr : -14: 1: 304: 85:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module BB: 0 : Dr : -14: 0: 389: 91:Yes : Ok : Ok : C9 :25-07-06:B327? :Selfscan module BB: 1 : Dr : -14: 1: 389: 91:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module D9: 0 : Dr : -11: 0: 516: 79:Yes : Ok : Ok : C1 :25-07-06:B327? :Selfscan module D9: 1 : Dr : -11: 1: 516: 79:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module D4: 0 : Dr : -14: 0: 480: 78:Yes : Ok : Ok : 59 :25-07-06:B327? :Selfscan module D4: 1 : Dr : -14: 1: 480: 78:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module DC: 0 : Dr : -13: 0: 526: 73:Yes : Ok : Ok : 1C :25-07-06:B327? :Selfscan module DC: 1 : Dr : -13: 1: 526: 73:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module D0: 0 : Dr : -15: 0: 0: 71:Yes : Ok : Ok : DA :25-07-06:B327? :Selfscan module D0: 1 : Dr : -15: 1: 0: 71:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module D3: 0 : Dr : -15: 0: 71: 71:Yes : Ok : Ok : 46 :25-07-06:B327? :Selfscan module D3: 1 : Dr : -15: 1: 71: 71:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module BA: 0 : Dr : -15: 0: 142: 90:Yes : Ok : Ok : 2E :25-07-06:B327? :Selfscan module BA: 1 : Dr : -15: 1: 142: 90:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module B9: 0 : Dr : -15: 0: 232: 90:Yes : Ok : Ok : 01 :25-07-06:B327? :Selfscan module B9: 1 : Dr : -15: 1: 232: 90:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module BC: 0 : Dr : -15: 0: 322: 89:Yes : Ok : Ok : E1 :25-07-06:B327? :Selfscan module BC: 1 : Dr : -15: 1: 322: 89:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module D8: 0 : Dr : -15: 0: 411: 81:Yes : Ok : Ok : 1F :25-07-06:B327? :Selfscan module D8: 1 : Dr : -15: 1: 411: 81:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module BD: 0 : : -16: 0: 0: 113:Yes : Ok : Ok : 05 :25-07-06:B327? : BD: 1 : : -16: 1: 0: 113:Yes :Error:Error: 00/81 :13-10-02:B327? : FD: 0 : Dr : -15: 0: 492: 64:Yes : Ok : Ok : 0D :25-07-06:B327? :Selfscan module FD: 1 : Dr : -15: 1: 492: 64:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module FB: 0 : Dr : -16: 0: 113: 256:Yes : Ok : Ok : BF :25-07-06:B327? :Selfscan module FB: 1 : Dr : -16: 1: 113: 256:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module E6: 0 : Dr : -16: 0: 369: 64:Yes : Ok : Ok : 7F :25-07-06:B327? :Selfscan module E6: 1 : Dr : -16: 1: 369: 64:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module E7: 0 : Dr : -10: 0: 541: 32:Yes : Ok : Ok : 2D :27-10-06:B327? :Selfscan module E7: 1 : Dr : -10: 1: 541: 32:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module BE: 0 : Dr : -10: 0: 573: 27:Yes : Ok : Ok : 8E :25-07-06:B327? :Selfscan module BE: 1 : Dr : -10: 1: 573: 27:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module B8: 0 : Dr : -7: 0: 585: 2:Yes : Ok : Ok : A4 :27-10-06:B327? :Selfscan module B8: 1 : Dr : -7: 1: 585: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module BF: 0 : Dr : -7: 0: 587: 8:Yes : Ok : Ok : B7 :25-07-06:B327? :Selfscan module BF: 1 : Dr : -7: 1: 587: 8:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module FC: 0 : Dr : -7: 0: 595: 4:Yes : Ok : Ok : B5 :25-07-06:B327? :Selfscan module FC: 1 : Dr : -7: 1: 595: 4:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module EE: 0 : Dr : -9: 0: 590: 5:Yes : Ok : Ok : 42 :25-07-06:B327? :Selfscan module EE: 1 : Dr : -9: 1: 590: 5:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module F4: 0 : : -16: 0: 433: 99:Yes : Ok : Ok : B4 :25-07-06:B327? : F4: 1 : : -16: 1: 433: 99:Yes :Error: Ok : 00 :/WRONG/ :..... : D1: 0 : : -17: 0: 0: 108:Yes : Ok : Ok : C1 :25-07-06:B327? : D1: 1 : : -17: 1: 0: 108:Yes :Error:Error: 00/81 :13-10-02:B327? : E1: 0 : Dr : -33: 0: 0: 600:Yes : Ok : Ok : D7 :25-07-06:B327? :Selfscan module E1: 1 : Dr : -33: 1: 0: 600:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module E2: 0 : Dr : -34: 0: 0: 600:Yes : Ok : Ok : CA :25-07-06:B327? :Selfscan module E2: 1 : Dr : -34: 1: 0: 600:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module E3: 0 : Dr : -35: 0: 0: 600:Yes : Ok : Ok : E0 :25-07-06:B327? :Selfscan module E3: 1 : Dr : -35: 1: 0: 600:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module E4: 0 : Dr : -36: 0: 0: 600:Yes : Ok : Ok : 23 :25-07-06:B327? :Selfscan module E4: 1 : Dr : -36: 1: 0: 600:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module E5: 0 : Dr : -37: 0: 0: 600:Yes : Ok : Ok : C3 :25-07-06:B327? :Selfscan module E5: 1 : Dr : -37: 1: 0: 600:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module ------------------------------------------------------------------------------------------------------------------------------- |
| Author: | zebong [ November 29th, 2008, 10:59 ] |
| Post subject: | Re: WD5000KS-55MNB0 |
Zone allocation table Zones number............................ : 78 ------------------------------------------------------------------------------------------------------------- NN :Beg LBA : End LBA : SPT0 : SPT1 : SPT2 : SPT3 : SPT4 : SPT5 ------------------------------------------------------------------------------------------------------------- 1 :0 : 0 : 864 : 864 : 864 : 864 : 864 : 0 2 :0 : 77 074 686 : 1332 : 1296 : 1339 : 1296 : 1332 : 0 3 :77 074 687 : 97 665 918 : 1332 : 1296 : 1323 : 1296 : 1332 : 0 4 :97 665 919 : 99 051 288 : 1332 : 1296 : 1323 : 1296 : 1332 : 0 5 :99 051 289 : 105 907 913 : 1296 : 1296 : 1323 : 1296 : 1296 : 0 6 :105 907 914 : 170 047 926 : 1296 : 1256 : 1323 : 1256 : 1296 : 0 7 :170 047 927 : 174 102 660 : 1296 : 1256 : 1296 : 1256 : 1296 : 0 8 :174 102 661 : 184 844 196 : 1296 : 1234 : 1296 : 1234 : 1296 : 0 9 :184 844 197 : 186 183 126 : 1296 : 1234 : 1296 : 1234 : 1296 : 0 10 :186 183 127 : 254 177 226 : 1296 : 1234 : 1296 : 1234 : 1296 : 0 11 :254 177 227 : 255 778 110 : 1296 : 1234 : 1296 : 1234 : 1296 : 0 12 :255 778 111 : 261 334 791 : 1296 : 1209 : 1296 : 1209 : 1296 : 0 13 :261 334 792 : 268 391 226 : 1252 : 1209 : 1296 : 1209 : 1252 : 0 14 :268 391 227 : 323 493 884 : 1252 : 1209 : 1296 : 1209 : 1252 : 0 15 :323 493 885 : 342 699 510 : 1252 : 1188 : 1296 : 1188 : 1252 : 0 16 :342 699 511 : 344 509 094 : 1252 : 1188 : 1252 : 1188 : 1252 : 0 17 :344 509 095 : 348 097 675 : 1224 : 1188 : 1252 : 1188 : 1224 : 0 18 :348 097 676 : 397 377 100 : 1224 : 1188 : 1252 : 1188 : 1224 : 0 19 :397 377 101 : 410 503 768 : 1224 : 1152 : 1252 : 1152 : 1224 : 0 20 :410 503 769 : 413 000 088 : 1188 : 1152 : 1252 : 1152 : 1188 : 0 21 :413 000 089 : 418 466 908 : 1188 : 1152 : 1252 : 1152 : 1188 : 0 22 :418 466 909 : 455 583 266 : 1188 : 1152 : 1215 : 1152 : 1188 : 0 23 :455 583 267 : 475 145 894 : 1188 : 1116 : 1215 : 1116 : 1188 : 0 24 :475 145 895 : 478 315 424 : 1188 : 1116 : 1215 : 1116 : 1188 : 0 25 :478 315 425 : 487 310 420 : 1188 : 1116 : 1188 : 1116 : 1188 : 0 26 :487 310 421 : 525 014 375 : 1152 : 1116 : 1188 : 1116 : 1152 : 0 27 :525 014 376 : 533 777 207 : 1152 : 1080 : 1188 : 1080 : 1152 : 0 28 :533 777 208 : 541 489 615 : 1110 : 1080 : 1188 : 1080 : 1110 : 0 29 :541 489 616 : 549 172 633 : 1110 : 1080 : 1141 : 1080 : 1110 : 0 30 :549 172 634 : 586 869 306 : 1110 : 1080 : 1141 : 1080 : 1110 : 0 31 :586 869 307 : 590 564 378 : 1110 : 1080 : 1141 : 1080 : 1110 : 0 32 :590 564 379 : 594 907 806 : 1080 : 1080 : 1141 : 1080 : 1080 : 0 33 :594 907 807 : 600 606 601 : 1080 : 1080 : 1116 : 1080 : 1080 : 0 34 :600 606 602 : 633 812 660 : 1080 : 1036 : 1116 : 1036 : 1080 : 0 35 :633 812 661 : 634 706 468 : 1080 : 1036 : 1080 : 1036 : 1080 : 0 36 :634 706 469 : 641 380 807 : 1080 : 1036 : 1080 : 1036 : 1080 : 0 37 :641 380 808 : 659 878 510 : 1080 : 1008 : 1080 : 1008 : 1080 : 0 38 :659 878 511 : 675 483 556 : 1036 : 1008 : 1080 : 1008 : 1036 : 0 39 :675 483 557 : 681 685 607 : 1036 : 972 : 1080 : 972 : 1036 : 0 40 :681 685 608 : 692 953 142 : 1036 : 972 : 1080 : 972 : 1036 : 0 41 :692 953 143 : 696 518 195 : 999 : 972 : 1080 : 972 : 999 : 0 42 :696 518 196 : 725 669 450 : 999 : 972 : 1032 : 972 : 999 : 0 43 :725 669 451 : 728 547 080 : 999 : 936 : 1032 : 936 : 999 : 0 44 :728 547 081 : 730 389 452 : 999 : 936 : 1032 : 936 : 999 : 0 45 :730 389 453 : 732 618 074 : 972 : 936 : 1032 : 936 : 972 : 0 46 :732 618 075 : 762 876 697 : 972 : 936 : 999 : 936 : 972 : 0 47 :762 876 698 : 763 278 565 : 972 : 936 : 999 : 936 : 972 : 0 48 :763 278 566 : 766 636 609 : 972 : 894 : 999 : 894 : 972 : 0 49 :766 636 610 : 767 605 939 : 925 : 894 : 999 : 894 : 925 : 0 50 :767 605 940 : 799 193 709 : 925 : 894 : 956 : 894 : 925 : 0 51 :799 193 710 : 804 522 529 : 925 : 864 : 956 : 864 : 925 : 0 52 :804 522 530 : 808 463 510 : 891 : 864 : 956 : 864 : 891 : 0 53 :808 463 511 : 812 570 426 : 891 : 864 : 918 : 864 : 891 : 0 54 :812 570 427 : 837 764 925 : 891 : 864 : 918 : 864 : 891 : 0 55 :837 764 926 : 841 249 137 : 864 : 864 : 918 : 864 : 864 : 0 56 :841 249 138 : 846 355 917 : 864 : 864 : 918 : 864 : 864 : 0 57 :846 355 918 : 846 537 444 : 864 : 864 : 885 : 864 : 864 : 0 58 :846 537 445 : 865 642 027 : 864 : 828 : 885 : 828 : 864 : 0 59 :865 642 028 : 871 085 861 : 864 : 792 : 885 : 792 : 864 : 0 60 :871 085 862 : 874 063 394 : 864 : 792 : 864 : 792 : 864 : 0 61 :874 063 395 : 878 075 054 : 864 : 792 : 864 : 792 : 864 : 0 62 :878 075 055 : 898 935 498 : 820 : 792 : 864 : 792 : 820 : 0 63 :898 935 499 : 901 471 158 : 820 : 768 : 864 : 768 : 820 : 0 64 :901 471 159 : 902 138 598 : 792 : 768 : 864 : 768 : 792 : 0 65 :902 138 599 : 905 622 034 : 792 : 768 : 864 : 768 : 792 : 0 66 :905 622 035 : 919 109 722 : 792 : 768 : 810 : 768 : 792 : 0 67 :919 109 723 : 925 760 578 : 792 : 740 : 810 : 740 : 792 : 0 68 :925 760 579 : 935 006 238 : 756 : 740 : 810 : 740 : 756 : 0 69 :935 006 239 : 937 384 488 : 756 : 740 : 777 : 740 : 756 : 0 70 :937 384 489 : 942 442 536 : 756 : 740 : 777 : 740 : 756 : 0 71 :942 442 537 : 951 150 472 : 756 : 709 : 777 : 709 : 756 : 0 72 :951 150 473 : 955 795 185 : 756 : 709 : 777 : 709 : 756 : 0 73 :955 795 186 : 958 866 452 : 740 : 709 : 777 : 709 : 740 : 0 74 :958 866 453 : 965 563 620 : 740 : 709 : 756 : 709 : 740 : 0 75 :965 563 621 : 966 919 128 : 709 : 709 : 756 : 709 : 709 : 0 76 :966 919 129 : 971 823 229 : 709 : 691 : 756 : 691 : 709 : 0 77 :971 823 230 : 976 773 167 : 709 : 691 : 756 : 691 : 709 : 0 78 :976 773 167 : 976 773 167 : 709 : 691 : 720 : 691 : 709 : 0 MODULES DIRECTORY (01) SA Copy num Location State --------------------------------------------------- 0 c: -1 H: 0 Ok 1 c: -1 H: 1 Ok Modules number.......................... : 125 CONFIGURATION MODULE (02) SA Copy num Location State --------------------------------------------------- 0 c: -2 H: 0 Ok 1 c: -2 H: 1 Header HDD Identify Model................................... : WDC WD5000KS-55MNB0 Serial number........................... : WD-WCANUxxxxxxxxx..... Logical parameters...................... : LBA : 976 773 167 Master-password Set..................................... : No User-password Set..................................... : No Security level.......................... : High Log DCM (C5) SA Copy num Location State --------------------------------------------------- 0 c: -2 H: 0 Ok 1 c: -2 H: 1 Header Zeus ZEU +--- Head DCM Codes -------- Media DCM Codes -----+ | | | | ALPS: A,B | SHOWA: F,K,Q,7 | | SAE: D | TRACE: D,E,J,M,P,3,4,9 | | WDB : 7 | EXP : L,N,R | | | | +-------------------------------------------------+ P-List (33) SA Copy num Location State --------------------------------------------------- 0 c: -2 H: 0 Ok 1 c: -2 H: 1 Header Defects number.......................... : 1649 G-List (34) SA Copy num Location State --------------------------------------------------- 0 c: -9 H: 0 Ok 1 c: -9 H: 1 Header Defects number.......................... : 0 |
| Author: | zebong [ December 1st, 2008, 14:30 ] |
I see that the problem is when i cut the heads the LBA now is different. So the disk was the data with 8 heads but now is only work with 6 heads. Anyone was work in a case like this: Disk only detect by the pc3k iff cut head 6 and 7, with all the LBA size correct ID and Serial. Afther that the disk is detect and in the DE i can edit sectores but all came with "dark green" ECC Error but it have data there. Also i try the head map without the head 6 and 7 , and the problem is the same, "dark green" ECC Error. So i think i just have to know how can i get the data by change the LBA size ? Anyone have any ideia ? Thanks ZeBong |
| Author: | imaarouf [ December 12th, 2008, 17:14 ] |
I had the same problem, I got two cases from with same problem, when i disable Heads 6,7 , HD is identified, but look if you have ACE manuals, there is detailed decribtion of how to disable heads, you should remove defects from p-list, that are related to the defective heads, 6 and 7, if you do not have the manuals, tell me, i will check on my cases and inform you good luck |
| Author: | zebong [ December 12th, 2008, 19:09 ] |
Thanks I miss that in the manual 8.2.1. Head disabling procedure Disable the translator, To disable the translator, set to zero the checksum byte in modules ID=20h and ID=25h Enter Defect list editor (P-List), select Remove defects for head. Clear G-List Edit HDD ID menu to correct the Max LBA Perform internal formatting using P-List Run a logical test and hide all revealed defects |
| Author: | hddguy [ December 16th, 2008, 5:25 ] |
zebong wrote: Thanks I miss that in the manual 8.2.1. Head disabling procedure Disable the translator, To disable the translator, set to zero the checksum byte in modules ID=20h and ID=25h Enter Defect list editor (P-List), select Remove defects for head. Clear G-List Edit HDD ID menu to correct the Max LBA Perform internal formatting using P-List Run a logical test and hide all revealed defects Is this the same procedure as used in CYL32 and MARVEL? Also, is this procedure with HDD repair or HDD recovery in mind? |
| Author: | zebong [ December 16th, 2008, 18:54 ] |
Hi, It dont work for this disk WD5000KS-55MNB0 Anyone knows what can be done to recovery data , without two heads. Rebuild new translator ? |
| Author: | Steve [ December 16th, 2008, 19:24 ] |
I don't want to sound like I am stating the obvious, but since you want to recover data, have you tried a head replacement? |
| Author: | hddguy [ December 17th, 2008, 7:58 ] |
Steve wrote: I don't want to sound like I am stating the obvious, but since you want to recover data, have you tried a head replacement? I think the aim here is to try to get data, even a minimal ammount, without head repalcement as head replacement on these disks is actually quite difficult |
