| SAMSUNG TRIDENT HD400LD - clicks 5 times then stays busy http://forum.hddguru.com/viewtopic.php?f=11&t=10720 |
Page 1 of 1 |
| Author: | yco [ December 12th, 2008, 12:06 ] |
| Post subject: | SAMSUNG TRIDENT HD400LD - clicks 5 times then stays busy |
SAMSUNG HD400LD, TRIDENT PATA Spins up, clicks once and then clicks found times. Stays BSY but doesn't click any more. Terminal output: Code: SpnOk spd: 0000 0000 0000 ADC: FFFF DAC: A191 H: +00000 Unlatch Tk: 00015443 Unlatch Done ENG>SRV> SvoTbl Loaded BD BITmp=0033 Every time I power cycle it "DAC" and "Unlatch Tk" returns a bitdefferent values DAC: A090, A191, A291 Unlatch Tk: 00015443, 0001549F, 000154E0. Is that Head failure? If so how to get compatible donor. There is no sticker on the side or P/V anywhere. Regards, Paul |
| Author: | dmarques [ December 15th, 2008, 5:26 ] |
| Post subject: | Re: SAMSUNG TRIDENT HD400LD - clicks 5 times then stays busy |
Have you tried a soft reset and tried to read modules? |
| Author: | yco [ December 15th, 2008, 10:29 ] |
Drive is not responding 'Drive is not ready', no soft/hard reset helps here. I cannot access SA, neither in normal nor safe mode. |
| Author: | Doomer [ December 15th, 2008, 11:44 ] |
SA most likely |
| Author: | dmarques [ December 16th, 2008, 4:55 ] |
I agree on SA problem too by the log that the drive provides. |
| Author: | yco [ December 16th, 2008, 5:32 ] |
OK then, what can I do? Will hot-swap work here? (*I haven't tried it on Samsung) |
| Author: | Doomer [ December 16th, 2008, 10:37 ] |
hot-swap should help you figure out the problem |
| Author: | yco [ January 8th, 2009, 10:00 ] |
Customer decided not to go ahead with this so will abandon this case. |
| Author: | hddguy [ January 9th, 2009, 6:22 ] |
Thats a shame, would have been nice to see the outcome of this one. |
| Author: | yco [ January 9th, 2009, 7:54 ] |
He left this drive to recycle, so if I get suitable donor will give it a try. |
