 Post subject: SAMSUNG TRIDENT HD400LD - clicks 5 times then stays busy
PostPosted: December 12th, 2008, 12:06
SAMSUNG HD400LD, TRIDENT PATA
Spins up, clicks once and then clicks found times. Stays BSY but doesn't click any more.
Terminal output:
SpnOk
spd:  0000 0000 0000
ADC: FFFF
DAC: A191
H: +00000
Unlatch Tk: 00015443
Unlatch Done
ENG>SRV>
  SvoTbl Loaded
  BD
BITmp=0033
Every time I power cycle it "DAC" and "Unlatch Tk" returns a bitdefferent values
DAC: A090, A191, A291
Unlatch Tk: 00015443, 0001549F, 000154E0.
Is that Head failure? If so how to get compatible donor. There is no sticker on the side or P/V anywhere.
Regards,
Paul
 Post subject: Re: SAMSUNG TRIDENT HD400LD - clicks 5 times then stays busy
PostPosted: December 15th, 2008, 5:26
Have you tried a soft reset and tried to read modules?
PostPosted: December 15th, 2008, 10:29
Drive is not responding 'Drive is not ready', no soft/hard reset helps here. I cannot access SA, neither in normal nor safe mode.
PostPosted: December 15th, 2008, 11:44
SA most likely
PostPosted: December 16th, 2008, 4:55
I agree on SA problem too by the log that the drive provides.
PostPosted: December 16th, 2008, 5:32
OK then, what can I do? Will hot-swap work here? (*I haven't tried it on Samsung)
PostPosted: December 16th, 2008, 10:37
hot-swap should help you figure out the problem
PostPosted: January 8th, 2009, 10:00
Customer decided not to go ahead with this so will abandon this case.
PostPosted: January 9th, 2009, 6:22
Thats a shame, would have been nice to see the outcome of this one.
PostPosted: January 9th, 2009, 7:54
He left this drive to recycle, so if I get suitable donor will give it a try.
