SEAGATE 80GB
http://forum.hddguru.com/viewtopic.php?f=11&t=10762
Author:  zebong [ December 17th, 2008, 8:53 ]
Post subject:  SEAGATE 80GB
Afther change heads could copy about 50% off the disk.
But now it have this in the Terminal
ANd try to copy the sectores but it give "yellow"
Anyone nows wich is this error ?
ZeBong
Interface task reset
1024k x 16 buffer detected
SNOWMASS - 1_Disk 3.19 11-20-01 12:12
Power Cycling
ATReset
Head Mask 000F - Switch to full int.
Spin Ready
Sweeping 189 Cyls
PMaster
ATReset
SMaster
AT Er 08 Nwt Er 00 RdWr 1072.01.0093
ATA St d0 Er 10 Op c8 e, 4c4b400,00 00 03
Niwot: 00227326 ff 7326.0.022 0022 7326 0022 0080
ATA St d0 Er 10 Op 20 e, 4c4b400,01 01 03
ATReset
HMaster
AT Er 08 Nwt Er 00 RdWr 0561.02.0093
ATA St d0 Er 10 Op 20 e, 4c4b464,01 01 00
Niwot: 00010561 02 0561.0.001 0000 f4b2 0044 0561
ATReset
HMaster
AT Er 08 Nwt Er 00 RdWr 26cc.01.0093
ATA St d0 Er 10 Op 20 e, 4c4b4c8,01 01 00
Niwot: 000126cc 02 26cc.0.001 0000 eac3 01f7 26cc
ATReset
HMaster
AT Er 08 Nwt Er 00 RdWr 2232.01.0093
ATA St d0 Er 10 Op 20 e, 4c4b52c,01 01 00
Niwot: 00012232 02 2232.0.001 0000 0b25 01bc 2232
ATReset
HMaster
AT Er 08 Nwt Er 00 RdWr 0977.02.0093
ATA St d0 Er 10 Op 20 e, 4c4b590,01 01 00
Niwot: 00010977 02 0977.0.001 0000 21e6 007a 0977
ATReset
HMaster
AT Er 08 Nwt Er 00 RdWr 2b50.01.0093
ATA St d0 Er 10 Op 20 e, 4c4b5f4,01 01 00
Niwot: 00012b50 02 2b50.0.001 0000 b648 0232 2b50
ATReset
HMaster
Author:  zebong [ December 17th, 2008, 8:58 ]
Post subject:  Re: SEAGATE 80GB
Think Problem Solve.
Change LBA to Max. :)
Author:  rameez [ December 18th, 2008, 14:08 ]
After changing heads did ID corrupt ?
Author:  zebong [ December 18th, 2008, 16:16 ]
No the ID was Ok,
finish the disk copy 97% off the sectors.
Author:  rameez [ December 21st, 2008, 14:51 ]
Why did u set LBA to max then ?
Author:  zebong [ December 21st, 2008, 19:15 ]
When the utility start the LBA is not correct, so have to change the LBA "tools menu"
ZeBong
Author:  Harvey [ January 6th, 2009, 13:30 ]
just set LBA to max? Interesting!
Author:  hddguy [ January 6th, 2009, 15:18 ]
Seems strange to have this LBA error aswell as damaged heads, surely LBA would have been correct before heads failed??
Author:  zebong [ January 6th, 2009, 17:01 ]
Yes, First problem was heads, afther head change could copy the data, afther change to MAX LBA size.
ZeBong
