WD5000AAVS - Head change
http://forum.hddguru.com/viewtopic.php?f=11&t=10882
Author:  zebong [ January 2nd, 2009, 11:52 ]
Post subject:  WD5000AAVS - Head change
Have change the head in this WD, but now i have the disk give DRD / DSC but dont have any info about the disk the model, serial, FW, size ?
PATIENT : WD5000AAVS-00ZTB0
DCM: HHRNNTJAHB
I just could find this model for head change:
DONNOR: WD5000AAVS-32ZTB0
DCM: HBNCHT2CH
Is any other problem here that i dont see ?
ZeBong
Author:  N.C. [ January 2nd, 2009, 12:12 ]
Post subject:  Re: WD5000AAVS - Head change
ZeBong
Yes. :)
(if i think right, more than one...)
I can recover for you, if you need....
Regars,
Janos
Author:  cryoborgofthevenus [ January 3rd, 2009, 5:30 ]
DCM: HHRNNTJAHB
DCM: HBNCHT2CH
ZeBong
Translator ?
Author:  Real_Jose_Pinto [ January 3rd, 2009, 7:17 ]
yes HDA does not match
Author:  hddguy [ January 5th, 2009, 7:30 ]
Are you referring to DCM code?
Author:  Harvey [ January 6th, 2009, 12:30 ]
It seems that some strings of DCM should match.
Author:  zebong [ January 6th, 2009, 12:50 ]
Hi, wich ones ?
Jose
Author:  hddguy [ January 6th, 2009, 15:15 ]
I believe it is 5th and 6th.....
Author:  pcimage [ January 6th, 2009, 15:17 ]
yes
Author:  zebong [ January 6th, 2009, 18:43 ]
pcimage wrote:
yes
So in here just the 6th match
DCM: HHRNNTJAHB
DCM: HBNCHT2CH
So i get the DRD / DSC, but dont get the ID off the disk, in this case have to find other donnor.
ZeBong
Author:  zebong [ February 28th, 2009, 18:26 ]
Salvation say´s this:
WD Head Change:
Model
The first 3 digits of DCM
Motor Number
Author:  Creator [ March 2nd, 2009, 14:23 ]
WD Head Change:
Model
Motor Number
DCM is SHIT!
Forgot about it!!
You sould check head map!
Head maps must be same.
Author:  zebong [ March 2nd, 2009, 14:30 ]
Creator wrote:
WD Head Change:
Model
Motor Number
DCM is SHIT!
Forgot about it!!
:lol:
Learn :D
Author:  zebong [ March 25th, 2009, 18:47 ]
Aligment problem !!!
DRD / DSC ok , no ID off the disk.
Author:  thatdellguy [ March 25th, 2009, 19:13 ]
"No! No different! Only different in your mind. You must unlearn what you have learned."
Author:  zebong [ March 26th, 2009, 6:59 ]
Confused ... :?
What are you saying please PM me.
ZeBong
Author:  zebong [ March 27th, 2009, 15:58 ]
Have unlearn everything about WD.
Author:  harddrivespecialist [ March 27th, 2009, 16:20 ]
Unlearn everything that Salvation provides for a requirement.
Author:  hddguy [ April 1st, 2009, 7:03 ]
harddrivespecialist wrote:
Unlearn everything that Salvation provides for a requirement.[/quote]
I agree.
