 Post subject: Hitachi HTS541 - cannot read ID
PostPosted: January 8th, 2009, 10:20
Hail to all GURUs ;)
I just got drive which has been worked on by some other DR company. As far as I've been told it was password-protected and they wouldn't be able to unlock it.
Model is HTS541010G9SA00
I saw many topics related to this drive, PC3000 UDMA wouldn't unlock it.
Now this drive spins up, DRD and DSC comes OK but PC3K won't detect drive ID.
I assume there is a problem with either ROM or NV-RAM. All modules are OK.
Selected family......................... : HTS541
Model by ID............................. :
Techno mode key......................... : Ok
NV-RAM reading.......................... : Ok
Loading modules table................................................. : Ok
Loading the table of "open" modules................................... : Error
Error :............................................................... : Error executing loading "open" modules dir command
Loading zone allocation table......................................... : Ok
SA can be checked and there was no errors (besides common ones like F copy or DUMP module).
PCB is original and nothing has been swapped on it (no traces of soldering).
Thanks,
yco.
 Post subject: Re: Hitachi HTS541 - cannot read ID
PostPosted: January 8th, 2009, 10:32
All modules are ok ?
The open modules list is not loaded so not all modules will have been tested.
Also, which Factory Modules are not ok?
Even better, could you us show the full SA Test report
<itch>
https://www.mjm.co.uk/
PostPosted: January 8th, 2009, 13:32
I got same problem like u when u tried to read HDD reach Readiness but when u tried to read any Sector show u ABRT at ATA registers, and when u check SA doesnt find nothing wrong , only DUMP module wich cannot be readed, well i got a solution by my self, i dont know if its same problem if its same contact me on PM or by MSN its more easy for me
PostPosted: January 8th, 2009, 14:58
Sounds like they buggered up the NVRAM trying to unlock it :-(
PostPosted: January 8th, 2009, 15:05
Hy friend at my case no another people tried to access before strange :o at has the same "syntomph" only DUMP module damaged well now data back from this hdd so need to got some free time to search on deep whats happening inside :D
PostPosted: January 8th, 2009, 15:54
isnt this the type of job salvation data claim data compass can recover from? Bypassing firmware on this model.
PostPosted: January 8th, 2009, 16:03
They said that but i dont have that tool, so only need to got the solution with my hands :D
PostPosted: January 9th, 2009, 6:20
Thanks,
yco.
Can you view sectors if you select 'Sector Edit' from PC3K utility?
If so data can be recovered by accessing DE without reading ID and manually entering LBA, and selecting 'Read from Active Utility' option
PostPosted: January 9th, 2009, 8:10
I can edit both RDMT and PSHT
Test : RDMT reading
Reading defect list...
Loading : RDMT, G-List module......................................... : Ok
Saving defects to file : <HDD Profile>\Defects\RDMT.lba
Result.................................. : Ok
Test : PSHT reading
Loading : PSHT, P-List module......................................... : Ok
Saving defects to file : <HDD Profile>\Defects\PSHT.chs
but when trying to view PList:
Test : View P-List
Error requesting defect list (PList)
When trying 'Sector Edit' just getting 'Read error, 10000 ms timeout'
SA check report:
ROM ID.................................. : C60P
NV-RAM ID............................... : C60P
RESF version............................ : C60P
NV-RAM parameters
NV-RAM report
Loaded.................................. : Yes
Checksum................................ : Ok
mu-code................................. : C60P
FW Ver Code............................. : 0x9948F63D
Head map................................ : 0 1 2 3
FW boot flag............................ : 0x80
SA top cyl delimiters (by heads)........ : 0x788D; 0x788D; 0x788D; 0x788D
Used module table
Report on module RESF,  "Main module table"
ABA..................................... : 7FE20000
Length (sectors)........................ : 2
Identified.............................. : Yes
FW Ver code............................. : 00000000
ID  : Copy : Importn.:    ABA   :    ABA   :  Size :  Read :  Size  : Address in : Read :   Hdr : Description
     :      :         :          :(original): (sect): (sect): (byte) :     RAM    :      :       :
RSVD :   0  :     B   : 7FD20000 : 7FD20000 :    3  :     3 :   1536 :  00000000  :  Yes :    Ok : SA marker
RSVD :   1  :     B   : 7FD21000 : 7FD20000 :    3  :     3 :   1536 :  00000000  :  Yes :    Ok : SA marker
RSVD :   F  :     B   : 7FD00000 : 7FD20000 :    3  :     0 :   1536 :  00000000  :   No :       : SA marker
RESF :   0  :     B   : 7FE20000 : 7FE20000 :    2  :     2 :      0 :  000FFFFF  :  Yes :    Ok : Main module table
RESF :   1  :     B   : 7FE21000 : 7FE20000 :    2  :     2 :      0 :  000FFFFF  :  Yes :    Ok : Main module table
RESF :   F  :     B   : 7FE00000 : 7FE20000 :    2  :     2 :      0 :  000FFFFF  :  Yes :    Ok : Main module table
RAM0 :   0  :     B   : 7FE20002 : 7FE20002 :  138  :   138 :      0 :  0004C800  :  Yes :    Ok : Code module
RAM0 :   1  :     B   : 7FE21002 : 7FE20002 :  138  :   138 :      0 :  0004C800  :  Yes :    Ok : Code module
RAM0 :   F  :     B   : 7FE00002 : 7FE20002 :  138  :   138 :      0 :  0004C800  :  Yes :    Ok : Code module
OVR0 :   0  :     B   : 7FE2008C : 7FE2008C :   18  :    18 :      0 :  0005DC00  :  Yes :    Ok : Code overlay module
OVR0 :   1  :     B   : 7FE2108C : 7FE2008C :   18  :    18 :      0 :  0005DC00  :  Yes :    Ok : Code overlay module
OVR0 :   F  :     B   : 7FE0008C : 7FE2008C :   18  :    18 :      0 :  0005DC00  :  Yes :    Ok : Code overlay module
RESF :   0  :     B   : 7FE2009E : 7FE2009E :    2  :     2 :      0 :  000FFFFF  :  Yes :    Ok : Main module table
RESF :   1  :     B   : 7FE2109E : 7FE2009E :    2  :     2 :      0 :  000FFFFF  :  Yes :    Ok : Main module table
RESF :   F  :     B   : 7FE0009E : 7FE2009E :    2  :     2 :      0 :  000FFFFF  :  Yes :    Ok : Main module table
PTCH :   0  :     B   : 7FE200A0 : 7FE200A0 :    3  :     3 :      0 :  000FFFFF  :  Yes :    Ok : Microcode connections table module
PTCH :   1  :     B   : 7FE210A0 : 7FE200A0 :    3  :     3 :      0 :  000FFFFF  :  Yes :    Ok : Microcode connections table module
PTCH :   F  :     B   : 7FE000A0 : 7FE200A0 :    3  :     3 :      0 :  000FFFFF  :  Yes :    Ok : Microcode connections table module
CNS1 :   0  :     B   : 7FE200A3 : 7FE200A3 :    1  :     1 :    386 :  00034E80  :  Yes :    Ok : HDD logical configuration module
CNS1 :   1  :     B   : 7FE210A3 : 7FE200A3 :    1  :     1 :    386 :  00034E80  :  Yes :    Ok : HDD logical configuration module
CNS1 :   F  :     B   : 7FE000A3 : 7FE200A3 :    1  :     1 :    386 :  00034E80  :  Yes :    Ok : HDD logical configuration module
RWCN :   0  :     B   : 7FE200A4 : 7FE200A4 :    1  :     1 :     96 :  0003AAF0  :  Yes :    Ok :
RWCN :   1  :     B   : 7FE210A4 : 7FE200A4 :    1  :     1 :     96 :  0003AAF0  :  Yes :    Ok :
RWCN :   F  :     B   : 7FE000A4 : 7FE200A4 :    1  :     1 :     96 :  0003AAF0  :  Yes :    Ok :
ZONE :   0  :    Ad   : 7FE200A5 : 7FE200A5 :   10  :    10 :   4612 :  00038C00  :  Yes :    Ok : Zone allocation table module
ZONE :   1  :    Ad   : 7FE210A5 : 7FE200A5 :   10  :     0 :   4612 :  00038C00  :   No :       : Zone allocation table module
ZONE :   F  :    Ad   : 7FE000A5 : 7FE200A5 :   10  :     0 :   4612 :  00038C00  :   No :       : Zone allocation table module
PTRT :   0  :     B   : 7FE200AF : 7FE200AF :    2  :     2 :    640 :  000E8580  :  Yes :    Ok :
PTRT :   1  :     B   : 7FE210AF : 7FE200AF :    2  :     2 :    640 :  000E8580  :  Yes :    Ok :
PTRT :   F  :     B   : 7FE000AF : 7FE200AF :    2  :     2 :    640 :  000E8580  :  Yes :    Ok :
SRVP :   0  :     B   : 7FE200B1 : 7FE200B1 :    1  :     1 :    272 :  0003C72C  :  Yes :    Ok :
SRVP :   1  :     B   : 7FE210B1 : 7FE200B1 :    1  :     1 :    272 :  0003C72C  :  Yes :    Ok :
SRVP :   F  :     B   : 7FE000B1 : 7FE200B1 :    1  :     1 :    272 :  0003C72C  :  Yes :    Ok :
SRVM :   0  :    Ad   : 7FE200B2 : 7FE200B2 :    3  :     3 :   1508 :  00038600  :  Yes :    Ok : Module contains cylinder defects table
SRVM :   1  :    Ad   : 7FE210B2 : 7FE200B2 :    3  :     3 :   1508 :  00038600  :  Yes :    Ok : Module contains cylinder defects table
SRVM :   F  :    Ad   : 7FE000B2 : 7FE200B2 :    3  :     3 :   1508 :  00038600  :  Yes :    Ok : Module contains cylinder defects table
CHNL :   0  :     B   : 7FE200B5 : 7FE200B5 :   11  :    11 :   4924 :  00037000  :  Yes :    Ok :
CHNL :   1  :     B   : 7FE210B5 : 7FE200B5 :   11  :    11 :   4924 :  00037000  :  Yes :    Ok :
CHNL :   F  :     B   : 7FE000B5 : 7FE200B5 :   11  :    11 :   4924 :  00037000  :  Yes :    Ok :
IDNT :   0  :     B   : 7FE200C0 : 7FE200C0 :    2  :     2 :    184 :  0003A842  :  Yes :    Ok : HDD ID data module
IDNT :   1  :     B   : 7FE210C0 : 7FE200C0 :    2  :     2 :    184 :  0003A842  :  Yes :    Ok : HDD ID data module
IDNT :   F  :     B   : 7FE000C0 : 7FE200C0 :    2  :     2 :    184 :  0003A842  :  Yes :    Ok : HDD ID data module
SN00 :   0  :     B   : 7FE200C1 : 7FE200C1 :    1  :     1 :     20 :  0003A856  :  Yes :    Ok : Module contains HDD SN
SN00 :   1  :     B   : 7FE210C1 : 7FE200C1 :    1  :     1 :     20 :  0003A856  :  Yes :    Ok : Module contains HDD SN
SN00 :   F  :     B   : 7FE000C1 : 7FE200C1 :    1  :     1 :     20 :  0003A856  :  Yes :    Ok : Module contains HDD SN
MISC :   0  :     B   : 7FE200C2 : 7FE200C2 :    1  :     1 :     20 :  0003A910  :  Yes :    Ok :
MISC :   1  :     B   : 7FE210C2 : 7FE200C2 :    1  :     1 :     20 :  0003A910  :  Yes :    Ok :
MISC :   F  :     B   : 7FE000C2 : 7FE200C2 :    1  :     1 :     20 :  0003A910  :  Yes :    Ok :
ICES :   0  :     B   : 7FE200C3 : 7FE200C3 :    1  :     1 :     72 :  0003A930  :  Yes :    Ok : Security information module
ICES :   1  :     B   : 7FE210C3 : 7FE200C3 :    1  :     1 :     72 :  0003A930  :  Yes :    Ok : Security information module
ICES :   F  :     B   : 7FE000C3 : 7FE200C3 :    1  :     1 :     72 :  0003A930  :  Yes :    Ok : Security information module
MLBA :   0  :     B   : 7FE200C4 : 7FE200C4 :    1  :     1 :     10 :  0003A900  :  Yes :    Ok : HDD logical configuration module
MLBA :   1  :     B   : 7FE210C4 : 7FE200C4 :    1  :     1 :     10 :  0003A900  :  Yes :    Ok : HDD logical configuration module
MLBA :   F  :     B   : 7FE000C4 : 7FE200C4 :    1  :     1 :     10 :  0003A900  :  Yes :    Ok : HDD logical configuration module
QMCN :   0  :     B   : 7FE200C5 : 7FE200C5 :    4  :     4 :   2044 :  0003A000  :  Yes :    Ok :
QMCN :   1  :     B   : 7FE210C5 : 7FE200C5 :    4  :     4 :   2044 :  0003A000  :  Yes :    Ok :
QMCN :   F  :     B   : 7FE000C5 : 7FE200C5 :    4  :     4 :   2044 :  0003A000  :  Yes :    Ok :
SMRT :   0  :     B   : 7FE200C9 : 7FE200C9 :    1  :     1 :    420 :  0003C25A  :  Yes :    Ok : S.M.A.R.T. module
SMRT :   1  :     B   : 7FE210C9 : 7FE200C9 :    1  :     1 :    420 :  0003C25A  :  Yes :    Ok : S.M.A.R.T. module
SMRT :   F  :     B   : 7FE000C9 : 7FE200C9 :    1  :     1 :    420 :  0003C25A  :  Yes :    Ok : S.M.A.R.T. module
PNID :   0  :     D   : 7FE200CA : 7FE200CA :    2  :     2 :      0 :  00FFFFFF  :  Yes :    Ok : Module contains information from label on PCB
PNID :   1  :     D   : 7FE210CA : 7FE200CA :    2  :     2 :      0 :  00FFFFFF  :  Yes :    Ok : Module contains information from label on PCB
PNID :   F  :     D   : 7FE000CA : 7FE200CA :    2  :     2 :      0 :  00FFFFFF  :  Yes : Error : Module contains information from label on PCB
ABLP :   0  :     B   : 7FE200CC : 7FE200CC :    1  :     1 :    104 :  0003AA20  :  Yes :    Ok :
ABLP :   1  :     B   : 7FE210CC : 7FE200CC :    1  :     1 :    104 :  0003AA20  :  Yes :    Ok :
ABLP :   F  :     B   : 7FE000CC : 7FE200CC :    1  :     1 :    104 :  0003AA20  :  Yes :    Ok :
ABLD :   0  :     B   : 7FE200CD : 7FE200CD :    1  :     1 :    144 :  0003A990  :  Yes :    Ok :
ABLD :   1  :     B   : 7FE210CD : 7FE200CD :    1  :     1 :    144 :  0003A990  :  Yes :    Ok :
ABLD :   F  :     B   : 7FE000CD : 7FE200CD :    1  :     1 :    144 :  0003A990  :  Yes :    Ok :
SSTL :   0  :     B   : 7FE200CE : 7FE200CE :    2  :     2 :      0 :  000FFFFF  :  Yes :  Skip :
SSTL :   1  :     B   : 7FE210CE : 7FE200CE :    2  :     2 :      0 :  000FFFFF  :  Yes :  Skip :
SSTL :   F  :     B   : 7FE000CE : 7FE200CE :    2  :     2 :      0 :  000FFFFF  :  Yes :  Skip :
SERL :   0  :     B   : 7FE200D0 : 7FE200D0 :    2  :     2 :   1024 :  00036800  :  Yes :  Skip : S.M.A.R.T. error log module
SERL :   1  :     B   : 7FE210D0 : 7FE200D0 :    2  :     2 :   1024 :  00036800  :  Yes :  Skip : S.M.A.R.T. error log module
SERL :   F  :     B   : 7FE000D0 : 7FE200D0 :    2  :     2 :   1024 :  00036800  :  Yes :  Skip : S.M.A.R.T. error log module
SSST :   0  :     B   : 7FE200D2 : 7FE200D2 :    1  :     1 :    512 :  00036400  :  Yes :  Skip :
SSST :   1  :     B   : 7FE210D2 : 7FE200D2 :    1  :     1 :    512 :  00036400  :  Yes :  Skip :
SSST :   F  :     B   : 7FE000D2 : 7FE200D2 :    1  :     1 :    512 :  00036400  :  Yes :  Skip :
DCOT :   0  :     B   : 7FE200D3 : 7FE200D3 :    1  :     1 :     18 :  0003A830  :  Yes :    Ok :
DCOT :   1  :     B   : 7FE210D3 : 7FE200D3 :    1  :     1 :     18 :  0003A830  :  Yes :    Ok :
DCOT :   F  :     B   : 7FE000D3 : 7FE200D3 :    1  :     1 :     18 :  0003A830  :  Yes :    Ok :
SRIF :   0  :     B   : 7FE200D4 : 7FE200D4 :    1  :     1 :      2 :  0003CB2E  :  Yes :    Ok : Self Test start management module
SRIF :   1  :     B   : 7FE210D4 : 7FE200D4 :    1  :     1 :      2 :  0003CB2E  :  Yes :    Ok : Self Test start management module
SRIF :   F  :     B   : 7FE000D4 : 7FE200D4 :    1  :     1 :      2 :  0003CB2E  :  Yes :    Ok : Self Test start management module
RDMT :   0  :    Ad   : 7FE40000 : 7FE40000 :   64  :    64 :      0 :  000A0000  :  Yes :    Ok : G-List module
RDMT :   1  :    Ad   : 7FE41000 : 7FE40000 :   64  :    64 :      0 :  000A0000  :  Yes :    Ok : G-List module
RDMT :   F  :    Ad   : 7FE01000 : 7FE40000 :   64  :    64 :      0 :  000A0000  :  Yes :    Ok : G-List module
RELI :   0  :     B   : 7FE40040 : 7FE40040 :    1  :     1 :      0 :  000A8000  :  Yes :  Skip :
RELI :   1  :     B   : 7FE41040 : 7FE40040 :    1  :     1 :      0 :  000A8000  :  Yes :  Skip :
RELI :   F  :     B   : 7FE01040 : 7FE40040 :    1  :     1 :      0 :  000A8000  :  Yes :  Skip :
PSHT :   0  :    Ad   : 7FE40041 : 7FE40041 :  482  :   482 :      0 :  000A8200  :  Yes :    Ok : P-List module
PSHT :   1  :    Ad   : 7FE41041 : 7FE40041 :  482  :   482 :      0 :  000A8200  :  Yes :    Ok : P-List module
PSHT :   F  :    Ad   : 7FE01041 : 7FE40041 :  482  :   482 :      0 :  000A8200  :  Yes :    Ok : P-List module
OVR1 :   0  :     B   : 7FE50000 : 7FE50000 :   72  :    72 :      0 :  000FFFFF  :  Yes :    Ok : Code overlay module
OVR1 :   1  :     B   : 7FE51000 : 7FE50000 :   72  :    72 :      0 :  000FFFFF  :  Yes :    Ok : Code overlay module
SPRE :   0  :     B   : 7FE50048 : 7FE50048 :   54  :    54 :      0 :  000FFFFF  :  Yes :  Skip :
SPRE :   1  :     B   : 7FE51048 : 7FE50048 :   54  :    54 :      0 :  000FFFFF  :  Yes :  Skip :
PESD :      :     D   : 7FE60000 : 7FE60000 :  128  :   128 :      0 :  000FFFFF  :  Yes :    Ok : PES data log
MFGP :      :    Dr   : 7FE61000 : 7FE61000 :    1  :     1 :      0 :  000FFFFF  :  Yes :    Ok : Self Test parameters module
SRST :      :     C   : 7FE70000 : 7FE70000 :  128  :   128 :      0 :  000FFFFF  :  Yes :  Skip : Self Test report module
FLOG :      :     B   : 7FE80000 : 7FE80000 :  128  :   128 :      0 :  000FFFFF  :  Yes :  Skip :
DUMP :      :     D   : 7FE90000 : 7FE90000 :  256  :     1 :      0 :  000FFFFF  :   No :       : Self Test log
Modules checking completed
Information about copy 0
Report on module RSVD,  "SA marker"
ABA..................................... : 7FD20000
Length (sectors)........................ : 3
Report on module RAM0,  "Code module"
ABA..................................... : 7FE20002
Length (sectors)........................ : 138
FW Ver code............................. : 9948F63D
Report on module OVR0,  "Code overlay module"
ABA..................................... : 7FE2008C
Length (sectors)........................ : 18
Report on module OVR1,  "Code overlay module"
ABA..................................... : 7FE50000
Length (sectors)........................ : 72
Report on module IDNT,  "HDD ID data module"
ABA..................................... : 7FE200C0
Firmware................................ : MBZO
Model................................... : HTS541010G9SA00
Serial.................................. : MP2ZM4X0JEWG4R
Report on module CNS1,  "HDD logical configuration module"
ABA..................................... : 7FE200A3
AutoReassign............................ : OFF
Maximal LBA............................. : 195371567
Report on module MLBA,  "HDD logical configuration module"
ABA..................................... : 7FE200C4
Capacity................................ : 0
Report on module ZONE,  "Zone allocation table module"
ABA..................................... : 7FE200A5
Length (sectors)........................ : 10
Head count.............................. : 4
Full capacity........................... : 197835583
ABA sub-zones count..................... : 920
ABA sub-zones cyl. step by heads........ : 55 3C 4F 3F
   #   Init. Cyl   End Cyl  Head    SPT
  0 :        0  :    3887 :    0 :  924
    :        0  :    2759 :    1 : 1012
    :        0  :    3599 :    2 :  946
    :        0  :    2879 :    3 : 1012
  1 :     3888  :    7343 :    0 :  891
    :     2760  :    6209 :    1 :  990
    :     3600  :    5471 :    2 :  946
    :     2880  :    6479 :    3 :  990
  2 :     7344  :   10655 :    0 :  880
    :     6210  :    8279 :    1 :  968
    :     5472  :    9215 :    2 :  924
    :     6480  :    8639 :    3 :  968
  3 :    10656  :   13967 :    0 :  858
    :     8280  :   10763 :    1 :  946
    :     9216  :   12527 :    2 :  902
    :     8640  :   11231 :    3 :  946
  4 :    13968  :   16991 :    0 :  836
    :    10764  :   14765 :    1 :  924
    :    12528  :   15551 :    2 :  880
    :    11232  :   15407 :    3 :  924
  5 :    16992  :   19439 :    0 :  825
    :    14766  :   17525 :    1 :  902
    :    15552  :   17279 :    2 :  880
    :    15408  :   18287 :    3 :  902
  6 :    19440  :   21167 :    0 :  814
    :    17526  :   19457 :    1 :  891
    :    17280  :   20447 :    2 :  858
    :    18288  :   20303 :    3 :  891
  7 :    21168  :   24191 :    0 :  792
    :    19458  :   21389 :    1 :  880
    :    20448  :   22751 :    2 :  836
    :    20304  :   22319 :    3 :  880
  8 :    24192  :   26351 :    0 :  792
    :    21390  :   24425 :    1 :  858
    :    22752  :   25055 :    2 :  825
    :    22320  :   25487 :    3 :  858
  9 :    26352  :   27935 :    0 :  770
    :    24426  :   26219 :    1 :  836
    :    25056  :   26783 :    2 :  814
    :    25488  :   27359 :    3 :  836
10 :    27936  :   30239 :    0 :  748
    :    26220  :   28289 :    1 :  825
    :    26784  :   29663 :    2 :  792
    :    27360  :   29519 :    3 :  825
11 :    30240  :   31679 :    0 :  748
    :    28290  :   30359 :    1 :  814
    :    29664  :   31679 :    2 :  770
    :    29520  :   31679 :    3 :  814
12 :    31680  :   35135 :    0 :  726
    :    30360  :   33809 :    1 :  770
    :    31680  :   34991 :    2 :  759
    :    31680  :   35279 :    3 :  770
13 :    35136  :   39023 :    0 :  693
    :    33810  :   37121 :    1 :  759
    :    34992  :   38591 :    2 :  726
    :    35280  :   38735 :    3 :  759
14 :    39024  :   41327 :    0 :  682
    :    37122  :   40571 :    1 :  726
    :    38592  :   42191 :    2 :  704
    :    38736  :   42335 :    3 :  726
15 :    41328  :   44927 :    0 :  660
    :    40572  :   43607 :    1 :  704
    :    42192  :   44927 :    2 :  682
    :    42336  :   45503 :    3 :  704
16 :    44928  :   47663 :    0 :  627
    :    43608  :   44849 :    1 :  693
    :    44928  :   48383 :    2 :  660
    :    45504  :   46799 :    3 :  693
17 :    47664  :   49967 :    0 :  616
    :    44850  :   46643 :    1 :  682
    :    48384  :   50831 :    2 :  627
    :    46800  :   48671 :    3 :  682
18 :    49968  :   52127 :    0 :  594
    :    46644  :   49817 :    1 :  660
    :    50832  :   52991 :    2 :  616
    :    48672  :   51983 :    3 :  660
19 :    52128  :   55871 :    0 :  572
    :    49818  :   51749 :    1 :  638
    :    52992  :   55871 :    2 :  594
    :    51984  :   53999 :    3 :  638
20 :    55872  :   58031 :    0 :  550
    :    51750  :   53819 :    1 :  616
    :    55872  :   58031 :    2 :  572
    :    54000  :   56159 :    3 :  616
21 :    58032  :   61055 :    0 :  528
    :    53820  :   56027 :    1 :  594
    :    58032  :   60047 :    2 :  550
    :    56160  :   58463 :    3 :  594
22 :    61056  :   63359 :    0 :  495
    :    56028  :   59201 :    1 :  561
    :    60048  :   63071 :    2 :  528
    :    58464  :   61775 :    3 :  561
23 :    63360  :   66239 :    0 :  462
    :    59202  :   63479 :    1 :  506
    :    63072  :   66239 :    2 :  484
    :    61776  :   66239 :    3 :  506
Report on module RDMT,  "G-List module"
ABA..................................... : 7FE40000
Length (sectors)........................ : 64
Header
Capacity................................ : 3988
Defects count........................... : 90
In spare area........................... : 85
Described sectors in User Area.......... : 15
Totally remaped......................... : 100
SMART, Realloc Event Count.............. : 4
SMART, Pending Count.................... : 0
Data:
Candidate............................... : 0
Total hidden (cand.).................... : 0
Total hidden (grown).................... : 100
Information about copy 1
Module not loaded! ID = ZONE Copy 1; Zone allocation table module
Error : Module is not loaded (ZONE, Zone allocation table module)
Header
Data:
Information about factory copy
Module not loaded! ID = RSVD Copy F; SA marker
Error : Module is not loaded (RSVD, SA marker)
mu-code................................. : C6GT
Incompatible with NV-RAM!
FW Ver code............................. : B5E7BA2D
Incompatible with active RESF!
AutoReassign............................ : ON
Module not loaded! ID = ZONE Copy F; Zone allocation table module
Header
Defects count........................... : 0
In spare area........................... : 0
Described sectors in User Area.......... : 0
Totally remaped......................... : 0
SMART, Realloc Event Count.............. : 0
Data:
Total hidden (grown).................... : 0
Information about common modules (Open+Spec)
Report on module MFGP,  "Self Test parameters module"
ABA..................................... : 7FE61000
Level................................... : 0000
Heads................................... : 4
Zones................................... : 24
Cylinders............................... : 29439
RPM..................................... : 5423
SID`s................................... : 132
Bytes in ECC............................ : 51
SRVM cyl base........................... : 0
Zone #  Init. Cyl   SPT   Last LBA
     0          0   861 2147483646
     1      65535     1 2147483646
     2      65535     1 2147483646
     3      65535     1 2147483646
     4      65535     1 2147483646
     5      65535     1 2147483646
     6      65535     1 2147483646
     7      65535     1 2147483646
     8      65535     1 2147483646
     9      65535     1 2147483646
    10      65535     1 2147483646
    11      65535     1 2147483646
    12      65535     1 2147483646
    13      65535     1 2147483646
    14      65535     1 2147483646
    15      65535     1 2147483646
    16      65535     1 2147483646
    17      65535     1 2147483646
    18      65535     1 2147483646
    19      65535     1 2147483646
    20      65535     1 2147483646
    21      65535     1 2147483646
    22      65535     1 2147483646
    23      65535     1         -1
PostPosted: January 9th, 2009, 11:01
Try to fix this.
PostPosted: January 9th, 2009, 19:26
Hi
should be 0x01
PostPosted: January 9th, 2009, 20:39
pepe wrote:
Hi
should be 0x01
incorrect
has to be 81
PostPosted: January 9th, 2009, 21:05
maybe :)
PostPosted: January 10th, 2009, 3:13
both Incorrect..
must be 41
:D
Спасибо
СУТИОНО / АПИНГ
PostPosted: January 10th, 2009, 20:21
hmmmm
PostPosted: January 11th, 2009, 4:58
all incorrect,
can be 81 or 41 or 80
PostPosted: January 11th, 2009, 21:55
HMmm NICE :)
Спасибо
СУТИОНО / АПИНГ
PostPosted: January 12th, 2009, 5:17
Doomer wrote:
pepe wrote:
Hi
should be 0x01
incorrect
has to be 81
Changed flag to 0x81 and boom! drive comes up ready and can read Drive ID but now:
ATTENTION! Security-locked HDD.
Tried method described in manual (shorting NV-Ram pins) but not to avail. Any ideas how to unlock it?
PostPosted: January 12th, 2009, 8:18
you sure you have done it right?
PostPosted: January 12th, 2009, 9:15
Clicked [Password Unlock] button, chose SATA. Utility powered off the drive and asked to short 4th and 5th pin of NV-Ram chip (U6, am I correct?) so I did. Then it asked me to remove short and press OK. It looked like all is going well but after putting controller back onto drive it is still locked. Did I miss something?
