 Post subject: SAMSUNG HD501LJ
PostPosted: January 12th, 2009, 15:04
Have this samsung disk that i could copy about 6 xxx xxx sectores and now it give this error in terminal.
Any clue for this ?
ZeBong
SPW 1.5G LinkOk! ADC: 0001
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: 0001
DAC: 8E8B
Unlatch Tk: 0001737F
Unlatch Done
ENG>SRV>
SvoTbl Loaded
AP_FSAM
C: 000005D8 H: +00002
H: +00000
Unlatch Tk: 0001718E
Unlatch Done
AP_FSAM
C: 000005D9 H: +00002
H: +00000
Unlatch Tk: 0001721F
Unlatch Done
AP_FSAM
C: 000005E3 H: +00002
H: +00000
Unlatch Tk: 00017229
Unlatch Done
AP_FSAM
C: 000005ED H: +00002
H: +00000
Unlatch Tk: 000175DE
Unlatch Done
AP_FSAM
C: 000005F7 H: +00002
H: +00000
Unlatch Tk: 000171F7
Unlatch Done
AP_FSAM
C: 00000601 H: +00002
r\ìZÖæaÏË* | V t N 9 ç _ R m k > )
# á s T Å ùppÐà0``ppÀÐ PppÐà0``ppÀÐ PppÀà P`ppÀÐ P=Í;8IßÇs5Ðì2h,Û 7"_3àþÔ÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ):Àò8,=õÎp:iÅc89Îp6û\4Ô÷;,x8ÓÌ)=Í;8IßÇs5Ðì2h,Û 7"_3àþÔ÷;,x8ÓÌ)=ú;5GÇs6(É43Ù1Ö/g÷ÞÓ9Í+7ÔÎp9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)9Áò7H<Ð9sÆY7-8\Ð3û17Û ;,x8ÓÌ)CQuILqILqILqILqCQu BF
AP_FSAM
C: 0001ED14 H: +00002
UF 6 GrayFailErr
H: +00001
Unlatch Tk: 000151D4
Unlatch Done
WriteSctLog -- buffer not valid
LED 14 0000
LED 14 0000
ZeBong
" Россия еще раз"
 Post subject: Re: SAMSUNG HD501LJ
PostPosted: January 12th, 2009, 18:48
H2 is damaged, U need to replace the MHA.
PostPosted: January 12th, 2009, 20:19
You should have done reverse imaging witha good heads only and then use a bad head.
www.datarecoveryne.com
PostPosted: January 12th, 2009, 21:04
use a bad head :?:
PostPosted: January 12th, 2009, 23:39
He could scan up to 6 000 000+ sectors, so head was alive. :D
PostPosted: January 13th, 2009, 7:44
I try again some times this "power on / power off" , them rest the drive four some time, and the drive get ID.
So i start to copy in reverse, it copy again some sectors Ok them it stop.
So i make a head map and see wich head it stop, Head 2.
Them i choose the others heads to copy all the data.
It copy all right during the night, now i am copying again just head 2, and is going ok :)
Thanks for the help
ZeBong
" Россия еще раз"
PostPosted: January 13th, 2009, 15:22
just for info i could copy the data in terminal it appear a lot off this:
HEAD 2 COPY
-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-Tout-ToutHEr:1140 1140
ZeBong
" Россия еще раз"
PostPosted: January 13th, 2009, 15:29
Samsungs use Zone-per-head translation that's why it is a big chunk of data per a head
PostPosted: January 14th, 2009, 19:42
yes, one zone on these drives is ~3.000.000 sectors in the outer area of the platter.
that's why he had ~6.000.000 sectors readable from H0 and H1.
he can try to image from ~9.500.000, and probably get other 3 x ~3.000.000 sectors. (H3,H0,H1)
or swap heads and recover the whole thing.
PostPosted: January 20th, 2009, 5:31
That explains why I have samsungs with completely healthy MHDD patterns, but which fail to recover due to head faults! :D
Users browsing this forum: Google [Bot] and 19 guests
