MAXTOR-6E040L0
http://forum.hddguru.com/viewtopic.php?f=11&t=10978
Author:  zebong [ January 13th, 2009, 14:22 ]
Post subject:  MAXTOR-6E040L0
Hi Have also this maxtor that have this Sounds.
MAXTOR-6E040L0-ENTER-SAFE-MODE.zip [1.03 MiB]
Downloaded 761 times
It looks like the motor is having problem in spining or the heads can not read the SA.
ZeBong
Author:  thatdellguy [ January 13th, 2009, 15:09 ]
Post subject:  Re: MAXTOR-6E040L0
Sounds like a bad scratch to the outer edge. Remove the silver inspection sticker on the bottom and look toward the outer edge of the platter with a good light. I bet your gonna find a lot of damage.
Author:  zebong [ January 13th, 2009, 18:15 ]
When i enter in the udma it give-me N40P SAFE MODE detected
Maybe can be FW, but i hear this disk just have one SA, no backup off the SA.
Author:  pcimage [ January 13th, 2009, 18:17 ]
I have had PCB cause this sound too, but more likely to be bad heads/platter damage.
Author:  zebong [ January 13th, 2009, 18:19 ]
Thanks , that´s good to know i have two PCB will test it :)
Author:  HDD Spaz [ January 14th, 2009, 14:54 ]
I'm 99% sure this is head problem and 80% sure of platter damage. No need to swap heads, only platter for this model.
