 Post subject: error selft test 2f040l0 ares64
PostPosted: February 18th, 2009, 3:09
hi to all
i have a maxtor with very badsector but sa is tru
i done selftest prosses
load ldr is safe mode with chksum E7CF => utility start
also (chesum sa is E7CF)
ctrl+alt+3 (selftest)=> launch selftest =>after swithing on
then power off => power on
load ldr and check box self test monitoring then utility start
then ctrl+alt+3 (menu self test) and monitoring
but unfortunatly first led blinking and drive drd dsc after afew minute bsy and led is on !!? :(
pls help
with tanks for your answere
i'm so sorry for bad english
NS DATA RECOVERY
www.nsrecovery.ir
 Post subject: Re: error selft test 2f040l0 ares64
PostPosted: February 18th, 2009, 6:52
i have try two another hdd 40 ares 64
this on selftest start and continues :o but other hdd again DRD DSC and then BSY :x :?
i have checked sa structure ,sa surface is ok !!
pls guide me
why dont start selftest,
thanks for u answere
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 18th, 2009, 8:57
did you try 'SA Surface Verification' with Remap option on?
PostPosted: February 18th, 2009, 9:41
thanks for yor replay
but i have tested 'sa surface verificaton ' was good ,sa no bad sectors
surface hdd is scratched and have very bad sectors
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 19th, 2009, 7:49
repeat again with another hdd ares 64 !!!? DRD DSC then BSY
but that hdd 40 start to selftest stop in test 67 first led on and then off 4 hourse later
step number test number
67 0075
pls,guide me masters hdd ??
i replaced pcb but again BSY
any oher person exprinced BSY?
with tanks for u attention
:wink:
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 22nd, 2009, 15:28
time solved the problem!!?
i told my hdds scratched when logical scan (in pc3000) on bad sectors power off and power on then continues how self scan could removed this bad sector on
surface disk :lol:
NS DATA RECOVERY
www.nsrecovery.ir
Users browsing this forum: Bing [Bot] and 87 guests
