 Post subject: What are the Parameters to look when matching a donor hdd
PostPosted: January 29th, 2009, 14:37
Hi Gurus,
Could someone put some light on what are the parameters that needs to matched
for a donor harddrive.
MODEL,CODE,PCBA...etc.
If we dont get exact model+code+PCBA how can we proceed or what could be the nearest
LDR that can be loaded.
After we load a ldr, is it that that the max lba should match the disk which has prob.
or
say per example when we replace :
PN
18 0029 0139 û û û AT_PDL 1 AT_PDL - P-List
When we regenerate the Transtable does it afffect or cause wrong shifting.
 Post subject: Re: What are the Parameters to look when matching a donor hdd
PostPosted: February 1st, 2009, 13:49
For geting an appropriate LDR u need to match its checksum .
