What are the Parameters to look when matching a donor hdd
Posted: January 29th, 2009, 14:38
by seeprakash
Hi Gurus,
Could someone put some light on what are the parameters that needs to matched
for a donor harddrive.
MODEL,CODE,PCBA...etc.
If we dont get exact model+code+PCBA how can we proceed or what could be the nearest
LDR that can be loaded.
After we load a ldr, is it that that the max lba should match the disk which has prob.
or
say per example when we replace :
PN
18 0029 0139 û û û AT_PDL 1 AT_PDL - P-List
When we regenerate the Transtable does it afffect or cause wrong shifting.
Re: What are the Parameters to look when matching a donor hdd
Posted: January 29th, 2009, 21:12
by thatdellguy
Use the forum search feature...
