| SAMSUNG HM120JC http://forum.hddguru.com/viewtopic.php?f=11&t=11252 |
Page 1 of 1 |
| Author: | zebong [ February 9th, 2009, 13:21 ] |
| Post subject: | SAMSUNG HM120JC |
Hi to all, Have this in terminal Open the disk and the motor dont spin. Code: IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 IndS=+00003 Spn Err: 0001 WritUSctLog0-- buffer not valid LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 LED 16 Anyone can help-me here. Thanks ZeBong |
| Author: | pepe [ February 10th, 2009, 18:38 ] |
| Post subject: | Re: SAMSUNG HM120JC |
probably heads stuck on the platter... pepe |
| Author: | zebong [ February 10th, 2009, 19:08 ] |
pepe wrote: probably heads stuck on the platter... pepe Hi Pepe, no the heads are not stuck in the platte are in the park zone , they dont move. |
| Author: | prodata [ February 10th, 2009, 22:52 ] |
then must its preamp dead |
| Author: | BlackST [ February 11th, 2009, 12:30 ] |
Head stiction or motor broken or PCB bad ... These are not the symptoms of died preamp (or better...) LED 16 should have told you everything. |
| Author: | pepe [ February 11th, 2009, 18:36 ] |
agree. Check motor windings, or try with another PCB to see if it spins... pepe |
| Author: | zebong [ February 11th, 2009, 18:39 ] |
Thanks to all |
