ST3500820AS - 7200.11
http://forum.hddguru.com/viewtopic.php?f=11&t=11324
Author:  zebong [ February 16th, 2009, 12:55 ]
Post subject:  ST3500820AS - 7200.11
Hi to all,
Have this disk it have 0Mb but it look like heads problem.
Make a head test and give-me this in terminal.
ZeBong
Author:  z007 [ February 18th, 2009, 4:25 ]
Post subject:  Re: ST3500820AS - 7200.11
FINAL WARNING: Please do NOT try this if you have valuable data on your drive. Do not blame anyone if something goes wrong. You do it at your own risk. Remember that if something goes wrong, it is extremely unlikely that anyone will be able to help you remotely. One wrong command via terminal could easily result in a completely bricked HDD (I really do mean bricked = no one will be able to recover it, even Seagate).
Added by admin.
This tutorial is not for unexperienced users!!! Do NOT POWER OFF YOUR hdd,comp, during it, (EXCEPT IF I SAY SO)and you just to be shure connect your comp to UPS.
Great thanks goes to http://www.elektroda.pl/rtvforum/topic1198189.html who pointed me to
http://yura.projektas.lt/files/seagate/720011_ES2.html witch published commands from this motion picture http://www.elektroda.pl/rtvforum/topic1165039.html
This is my original link but i must edit it and enter complete information.
http://www.google.com/search?hl=hr&q=0+ ... ivanje&lr=
just enter in google 0 LBA
First you must have to build serial rs232 converter to TX,RX GND, you can use any data cabel from your cell phone,like i do, from siemens 35 series custom build data cable buid on this picture with max232. Be shure that you put zener diode 2V7 at the picture..Because you could burn your Tx,Rx, on HDD-s PCB.
So, when you build,get your adapter, connect it to this pins on Seagete drive.
[ '''''''''''''''| |''''''''' ] [ .. ..] ----> Rx .. Tx
You do not need to connect SERIAL-ATA CABEL
open hyper terminal or another type of terminal select Serial port example "COM1"
set bitrate to 38400bps
data bits 8
parity N
stop bits 1
it's default settings except bps.
plug power to disk and after that you will see on terminal something like this:
PART 1
Rst 0x10M
hit Ctrl + Z to get "prompt"
F3 T>
now, if your BIOS recognize disk but there is 0 LBA,0 capacity
all you need is to hit this command:
F3 T>m0,2,2,0,0,0,0,22 Enter
!!!IMPORTANT, dont turn hdd power off, or comp off, wait about 30 sec to 2 minutes until it finished!!!
then you see something like this.
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 Max retries Wr = 00, Max Rd retries = 00, Max T-ECC Level = 14, Max certify Rewrite retries = 00C8
User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs
User Partition Format Successful - Elapsed Time 0 mins 05 secs User Partition Successful Format - Elapsed Time 0 mins 05 secs
After that hit
F3 T>/2
and
F3 2>Z
Spin Down Complete
Elapsed Time 3.038 msecs
Turn off power from your HDD, od shutdown your comp.
PART 2
If your HDD 7200.11 is not recognize by BIOS,
and after you connect him to COM1 and turn on power if you have this response for any command like:
Rst 0x10M
LED:000000CC FAddr:0025BF67
Ctrl + Z
F3 T>
your drive is bussy!
power off your Hdd
slightly unscrew one screw near to motor connection to PCB and put plastic visit card! or you can remove PCB.
Effect is the same..
power on your hdd,
Ctrl +Z
F3 T>/2
F3 2>
F3 2>Z
Spin Down Complete
Elapsed Time 0.138 msecs
F3 2>
now you put PCB back,or pull visitcard
enter this
F3 2>U
Spin Up Complete
Elapsed Time 7.242 secs
F3 2>
F3 T>/1
F3 1>N1
this is a S.M.A.R.T. erase
after that POWER off HDD, it means that you plug off power to hdd,
power on hdd,
reenter
CTRL+Z on terminal
F3 T>i4,1,22
this is G-list erase
reenter
CTRL+Z on terminal
After that hit
F3 T>/2
and
F3 2>Z
Spin Down Complete
Thats All!
Special thanks once again to
Nirvanowiec
and his source with correct commands Yura
http://74.125.77.113/translate_c?hl=hr& ... UJLI_CNavA
And, i try i successfully recover 0 LBA on Sathurday,
here is a link who successfully recover BIOS recognition
http://www.msfn.org/board/index.php?sho ... 28807&st=0
Thanks to all! AND maysoft who let me repost original thread.
If you have any comment please say if it works.!
Author:  cryoborgofthevenus [ February 18th, 2009, 4:28 ]
z007:
zebong owns orginal ACE's PC3K
Author:  Steve [ February 18th, 2009, 4:44 ]
how many times is this going to be posted?
Author:  hddguy [ February 18th, 2009, 8:59 ]
Useless info now that many recoveries are offering these cheap, and even free!!
Not worth the risk of further data loss IMHO
Author:  zebong [ February 18th, 2009, 11:23 ]
it look likes the disk have FW problems, but the client drop the disk to the floor.
Also the fw it looks like is the new one SD25 and not the SD15.
Author:  ephraim2 [ May 5th, 2009, 14:39 ]
HI FRIENDS,
I HAVE A ST31000333AS. THE DRIVE IS NOT DETECTED BY BIOS. AFTER RECOVERING TWO OTHER DRIVES SUCCESSFULLY, THIS ONE GOES MORE DIFFICULT.
I AM GETTING THE RST 0x20M MESSAGE ALL THE TIME. ALSO THE MESSAGE LED:000000CE.....
IS ANYTHING CAN BE DONE?
TKS FOR YOUR ASSISTANCE.
TKS VERY MUCH
EPHRAIM
Author:  meow [ May 6th, 2009, 3:58 ]
zebong, did you manage to solve the problem ?
I get one similar case but it is 1.5 TB.
Let me know if you have any luck.
Author:  Russwinters [ May 6th, 2009, 18:10 ]
meow, the fix posted above *should* work for you.
use at your own risk, as there can be complications which will result in even more difficult recovery, or worse, unrecoverable.
I recommend you send it to a pro as well.
Author:  meow [ May 6th, 2009, 20:43 ]
No. I worked with ACElab PC3000 and there is no need to do such DIY solution.
Acelab support also told me it was hard to fix. Got to try harder.
Author:  meow [ May 6th, 2009, 21:53 ]
Problem solved :lol:
Typically the problem is it shows "zero size" with disk ID detected. When you try to apply the "standard solution", it will hang and go to "LED:000000" error mode.
Now if you try the standard solution for "SG BSY not ready", it will not work either.
Same with "N1" command. It will just drop dead.
Check head after power on/off show that heads are ready.
Conclude that this is a firmware issue.
Author:  ephraim2 [ May 7th, 2009, 0:17 ]
HELLO FRIENDS
IS THESE PROCEDURES APPLIES ALSO TO 7200.10 DRIVES.
PLS ADVICE
TKS
EPHRAIM
Author:  zebong [ May 7th, 2009, 17:44 ]
No i did make make this disk, and it was not FW Problem.
The client did not want to get the data, the fee was too hight for the client.
But the real Problem was HEADS, the disk has drop to the floor.
If you to listen to the disk, and try to understant what the disk tell-you.
Author:  meow [ May 7th, 2009, 21:08 ]
Spildit, yes, this is one of the option but it did not solve my problem. My firmware revision is cc1g so it may be firmware specific.
