error selft test 2f040l0 ares64
http://forum.hddguru.com/viewtopic.php?f=11&t=11338
Author:  hamidbid [ February 18th, 2009, 3:09 ]
Post subject:  error selft test 2f040l0 ares64
hi to all
i have a maxtor with very badsector but sa is tru
i done selftest prosses
load ldr is safe mode with chksum E7CF => utility start
also (chesum sa is E7CF)
ctrl+alt+3 (selftest)=> launch selftest =>after swithing on
then power off => power on
load ldr and check box self test monitoring then utility start
then ctrl+alt+3 (menu self test) and monitoring
but unfortunatly first led blinking and drive drd dsc after afew minute bsy and led is on !!? :(
pls help
with tanks for your answere
i'm so sorry for bad english
Author:  hamidbid [ February 18th, 2009, 6:52 ]
Post subject:  Re: error selft test 2f040l0 ares64
i have try two another hdd 40 ares 64
this on selftest start and continues :o but other hdd again DRD DSC and then BSY :x :?
i have checked sa structure ,sa surface is ok !!
pls guide me
why dont start selftest,
thanks for u answere
Author:  hddguy [ February 18th, 2009, 8:57 ]
did you try 'SA Surface Verification' with Remap option on?
Author:  hamidbid [ February 18th, 2009, 9:41 ]
thanks for yor replay
but i have tested 'sa surface verificaton ' was good ,sa no bad sectors
surface hdd is scratched and have very bad sectors
Author:  hamidbid [ February 19th, 2009, 7:49 ]
repeat again with another hdd ares 64 !!!? DRD DSC then BSY
but that hdd 40 start to selftest stop in test 67 first led on and then off 4 hourse later
step number test number
67 0075
pls,guide me masters hdd ??
i replaced pcb but again BSY
any oher person exprinced BSY?
with tanks for u attention
:wink:
Author:  hamidbid [ February 22nd, 2009, 15:28 ]
time solved the problem!!?
i told my hdds scratched when logical scan (in pc3000) on bad sectors power off and power on then continues how self scan could removed this bad sector on
surface disk :lol:
