DE UDMA task settings
Posted: February 19th, 2009, 9:50
Hi guys
I am cloning a drive not knowing a lot of bad sectors ahead( after head exchange), I set a new task and do cloning, then I encountered bad sectors then i change settings while the cloning process is running, will it change and take effect immediately? or do i need to stop whole process or set a new task?
The reason I ask is the drive when enountered bad sectors it seems to struggle
alot until i issue a soft reset manually then it runs smoothly until the next encounters with bad sectors. I have set the setting but not sure if it does take the effect while cloning.
thanks guys
thanks guys
