Hi to all,
Have this drive that in udma it start with no ID.
I enter the utility and make a soft Reset, and get DRD DSC, get out off Samsung utility and them enter again in the utility and can read the model off the disk.
When enter in the utility i can have the Model,FW, and size., but could not get the serial number.
In terminal show this:
SPW 1.5G LinkOk! ADC: 0003
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: 0004
DAC: 898E
Unlatch Tk: 00016F1E
Unlatch Done
ENG>SRV>
SvoTbl Loaded
BD
WriteSctLog -- buffer not valid
LED B5 0000
LED B5 0000
LED B5 0000
LED B5 0000
LED B5 0000
SRST
0x5B Maintenance read errorCode:
HDD parameters
CONFIGURATION GENERAL INFORMATION:
ATA device
Fixed device and/or controller
Logical cylinders count..................................... 16383
Logical sectors per track................................... 63
Logical heads count......................................... 16
Model....................................................... SAMSUNG HD501LJ
Serial number
Firmware.................................................... CR100-12
Maximal block size for READ/WRITE MULTIPLE commands......... 16
Features
Stop Timer Value
IORDY............................................. Supported
LBA Mode.......................................... Supported
DMA Mode.......................................... Supported
Current Logical Parameters
Cylinders......................................... 0
Heads............................................. 0
Sectors........................................... 0
Capacity.......................................... 0 Sectors ( Mb)
Capacity available in LBA Mode.................... 863 526 960 Sectors (421 644 Mb)
Capacity available in LBA 48 Mode................. 863 526 960 Sectors (421 644 Mb)
Available DMA Mode
Multiword DMA Mode 0
Multiword DMA Mode 1
Multiword DMA Mode 2
Active DMA Mode
Active UDMA/33 modes
Ultra DMA/33 Mode 0
Ultra DMA/33 Mode 1
Ultra DMA/33 Mode 2
Ultra DMA/33 Mode 3
Ultra DMA/33 Mode 4
Ultra DMA/33 Mode 5
Ultra DMA/33 Mode 6
Current UDMA/33 mode........................................ [none]
Current PIO mode
Supported Enhanced PIO Modes
PIO MODE 3
PIO MODE 4
Minimal multiword DMA cycle time............................ 120 ns
Recommended multiword DMA cycle time........................ 120 ns
Minimal multiword PIO cycle time w/o stream control......... 120 ns
Minimal multiword PIO cycle time with IORDY................. 120 ns
Supported standards
ATA - 3
ATA - 4
ATA - 5
ATA - 6
Supported Command Sets
S.M.A.R.T functions
Security control
Security system............................................. Supported
condition flags :
password set...................................... NO
HDD Locked........................................ NO
HDD Frozen........................................ NO
wrong password count exceeded..................... NO
security erase support............................ YES
security level.................................... HIGH
Master code................................................. FFFE
Any help ?
ZeBong
