| SEAGATE HEAD CHANGE http://forum.hddguru.com/viewtopic.php?f=11&t=11483 |
Page 1 of 1 |
| Author: | zebong [ March 4th, 2009, 9:16 ] |
| Post subject: | SEAGATE HEAD CHANGE |
Hi to all, Afther change heads in the disk i have this. PCB is from donor HEADS from donor Code: Reset 4096k x 16 DRAM GALAXY2D - 1_Disk S-6A 05-31-06 13:44 Head Mask FFFF - Switch to full int. Spin Ready ERR Read App Code F> Platter have this: Attachment: Thanks Ze |
| Author: | dobrevjetser [ March 4th, 2009, 11:25 ] |
| Post subject: | Re: SEAGATE HEAD CHANGE |
What are the drive models? PN ? FW? Country ? If original pcb is ok always use that. Best regards, Dobre |
| Author: | zebong [ March 4th, 2009, 11:35 ] |
Hi Dobre, Attachment: ST3320820AS.jpg [ 37.18 KiB | Viewed 13488 times ] The original PCB is OFF Flash Rom Erased Attachment: Thanks Ze |
| Author: | Creator [ March 4th, 2009, 14:42 ] |
Zebong, You should perform terminal command F>R4 And then paste here result (A3 or A6?) A3: App code damaged (BAD's in SA) A6: Incompatible App code (PCB is incompatible) If A6 - change PCB and see; If A3 - you should find compatible Loader (same Eng Rev with patient) and load only App code. Then F>j. But don't write to SA anything (App code for example). |
| Author: | zebong [ March 5th, 2009, 8:35 ] |
Thanks Creator, Have this in terminal. Code: Reset
4096k x 16 DRAM GALAXY2D - 1_Disk S-6A 05-31-06 13:44 Buzz - Head Mask FFFF - Switch to full int. Spin Ready ERR Read App Code F>R4 Code - FF Track 15A76.0.022 Sns 022 F> |
| Author: | N.C. [ March 5th, 2009, 10:36 ] |
zebong wrote: Thanks Creator, Have this in terminal. Code: Reset 4096k x 16 DRAM GALAXY2D - 1_Disk S-6A 05-31-06 13:44 Buzz - Head Mask FFFF - Switch to full int. Spin Ready ERR Read App Code F>R4 Code - FF Track 15A76.0.022 Sns 022 F> FF - Unsupported preamp? |
| Author: | ccc [ March 6th, 2009, 3:05 ] |
FF=Unsupported code in the new preamp interface....Looks like incompatible heads. Rgds |
| Author: | zebong [ March 6th, 2009, 14:53 ] |
Hi ccc, Look at my patient / donor : Attachment: What do you think is possible to have different preamp ? Thanks ZeBong |
| Author: | prodata [ March 6th, 2009, 21:20 ] |
start a loader and see what happen.. maybe we can discuss OL See My PM |
| Author: | craig6928 [ March 13th, 2009, 1:31 ] |
check the preamp ic-chip and see if its matches with the other one it looks to use that its using a diffrent type ic dirty tricks of seagate to stop us recovering hard drives |
| Author: | drsc [ February 4th, 2013, 18:47 ] |
hi , How do you do the scratches on your disc surface used during the head is broken |
| Author: | drsc [ February 8th, 2013, 20:26 ] |
hi, data recovery device for scratched surface could you give information |
