| Fixing firmware on Fujitsu - MHV2080BH http://forum.hddguru.com/viewtopic.php?f=11&t=11572 |
Page 1 of 1 |
| Author: | romulluss [ March 12th, 2009, 17:16 ] |
| Post subject: | Fixing firmware on Fujitsu - MHV2080BH |
Hello.. I have a problem with laptop hard drive: Fujitsu MHV2080BH Basically, drive spins up normally, heads trying to calibrate, but after a while drive just spins, and there is no further movement of heads. Does anyone know if it is firmware issue and if it is how to fix it (I think that's the issue). Drive cannot be seen in BIOS? Also.. how can I make the hard drive to be detected? Any suggestions, how can I do it on PC3000? Also, what should I click, like step by step guide, just to check, and not to make it worse than is. Thank you. |
