HDD GURU FORUMS
http://forum.hddguru.com/
PCB Exchange problem Hitachi Plat 80 GB
http://forum.hddguru.com/viewtopic.php?f=11&t=11610
Page 1 of 1
Author:  ccamargol [ March 16th, 2009, 10:22 ]
Post subject:  PCB Exchange problem Hitachi Plat 80 GB
Hi
I have a Hitachi Plat of 80 GB with the damaged PCB.
I got another PCB and I replaced it to the hard disk, rewrite the NV-RAM.
Now the hard disk recognizes it totally (Model, firmware, modules, etc)
I made an SA Checking Test and everything was perfect.
When I try to extract the data or when I make a recalibration, the disk presents
the following sound: tac, tac, tac, tac.... and power off
Because this happens?
Carlos.
Author:  Creator [ March 16th, 2009, 15:27 ]
Post subject:  Re: PCB Exchange problem Hitachi Plat 80 GB
What shows express utility?
Maybe you could clone the data without recalibration? :D
Author:  ccamargol [ March 17th, 2009, 9:32 ]
It didn't work cloning the hard disk.
Some other idea?
Author:  beto [ March 17th, 2009, 9:58 ]
Did u tried to read a surface scan? maybe there are bad surface or a bad head
Author:  Creator [ March 17th, 2009, 10:33 ]
Some other idea?
Try to run express test from universal utility. Do you know how to do it?
Or use magic key....Alt+V
Author:  ccamargol [ March 17th, 2009, 21:33 ]
very bad in express test...
please help me!!!
imagen.doc [119.5 KiB]
Downloaded 684 times
Author:  harddrivespecialist [ March 17th, 2009, 23:00 ]
Try the end , middle. See if you have same results.
Author:  beto [ March 17th, 2009, 23:43 ]
Could be a bad head zone, tried to build a head map, and check, that
Author:  ccamargol [ March 24th, 2009, 18:38 ]
It didn't work head map the hard disk.
Some other idea?
Author:  harddrivespecialist [ March 24th, 2009, 19:46 ]
Some other idea?
Another option is to send it for a professional recovery.
http://www.phpbb.com/
