 Post subject: Need CERT for ST3160812AS
PostPosted: March 24th, 2009, 17:30
I'm assuming. Never seen this in terminal before:
Interface task reset
4096k x 16 SDRAM
TONKA2 - 1_Disk    M-31   03-22-06 10:53
              Spin Ready
(P)SATA Reset
Not Interface Age!
************* Cert Log Cyls inadequate. 0006 more cyls required
INVALID Cert Disk Code - ROM Resident Revision Required: BQH4T1
Command Inactive - No VALID Cert Code Detected
Drive info:
Eng Rev = .0K2
TONKA2 - 1_Disk    3.BQH  07-17-06 15:36 BQH,1D_S_013_N1,4T
CERT Rev = .0B8
.0B8
Mask Rom Rev = M-31
Unique Descriptor = .3N1
Orig Code = BQH4T1
odGray,133MHz,Code DRAM,Early Exit,Stall Converter,RwF
CERT=.0B8 CRC ==> 7C03
 Post subject: Re: Need CERT for ST3160812AS
PostPosted: March 25th, 2009, 14:32
Hi ,
I have a lot off this loaders PM me your email.
ZeBong
" Россия еще раз"
PostPosted: March 25th, 2009, 15:45
PMed.
I don't have PC3K, so was just looking for binaries. I guess I can probably pull them out of the loader. Thanks.
