 Post subject: WD200BB
PostPosted: March 16th, 2009, 18:10
Hi to all,
Have this disk that dont spin, so i found a match and change PCB but did not give the disk ID, but will get DRD DSC.
So i resolde the ROM from patient to donor.
Now the donor PCB dont spin with the ROM from patient, and also the patient PCB with the ROM from donor also dont spin.
It looks like the ROM has been bad resolder so i check it and it looks OK.
So i found other PCB change it and the disk SPIN but the ID is not correct.
What can be happening here ?
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: WD200BB
PostPosted: March 16th, 2009, 18:36
ZeBong
" Россия еще раз"
PostPosted: March 16th, 2009, 19:09
ROM could be corrupted.
www.datarecoveryne.com
PostPosted: March 16th, 2009, 19:15
This family dont have option to rebuild the ROM from SA ?
Can anyone tell-me the defaul off the headmaps for this drive
Wich heads are working ?
Heads configuration..................... : Default
ZeBong
ZeBong
" Россия еще раз"
PostPosted: March 16th, 2009, 22:00
Your head count is 1.
Provide a full model number.
With one head it should be easy to change.
Probably your head is bad and it should not be difficult to change.
PostPosted: March 17th, 2009, 6:55
The full model is : WD200BB-00AUA1 01 DEC 2000
PCB:
Patient :0000 001003-001 A
Donor : 0000 001003-000 C
When i enter with the donor disk i have this: ( head map) one head in use, but dont know wich is.
The patient disk with the donor pcb i have this:
ZeBong
ZeBong
" Россия еще раз"
PostPosted: March 17th, 2009, 18:02
All you need to do is download the correct ROM to the donor PCB. Or find a PCB from a drive of the same model number WD200BB-xxAUA1. Your donor PCB is not compatible as it stands.
PostPosted: March 17th, 2009, 18:26
Thanks Sean,
Will try that tomorow morning.
ZeBong
" Россия еще раз"
PostPosted: March 18th, 2009, 7:22
Need a ROM for this model
WD200BB-00AUA1
Anyone have this
ZeBong
ZeBong
" Россия еще раз"
PostPosted: March 19th, 2009, 13:30
No one have this ROM ?
ZeBong
" Россия еще раз"
PostPosted: March 19th, 2009, 13:39
pm me with your email
PostPosted: March 19th, 2009, 15:45
WD200BB-60AUA1
Mikippp
PostPosted: March 20th, 2009, 11:54
THanks all, will test it now.
ZeBong
" Россия еще раз"
PostPosted: March 20th, 2009, 12:35
Test all the ROm but did not get the correct size.
The version off the ROM are different
Mikippp, your ROM give-me this
Writing ROM from file................... : <HDD Profile>\Data\ROM\WDC.18.11--ROM_1809D_25_2022_WD200BB-60AUA1.bin
ROM writing error (ROM data checking)
Also i have other ROM in the database with the same error, but it looks like a close match off my disk.
Writing ROM from database............... : /Caviar Cyl 16 bit/WDC WD200BB-00AUA1 18.20D18 WD-WMA6Y1883452/ROM
the version looks like the 18.20D
Any hint here?
ZeBong
ZeBong
" Россия еще раз"
PostPosted: March 20th, 2009, 13:04
Are U sure that on PCB is installed flash M29F102 ... not eprom 27C1024 ...
Mikippp
PostPosted: March 20th, 2009, 13:29
In this family i have seen some times OTP PROM chip for the rom image.
And as we expect, yes, it can be damaged. :S
Janos
PostPosted: March 20th, 2009, 13:30
Mikippp
The PCB from client it have the eprom AT27C1024
Donor PCB it have the flash M29F102BB
I have to found a PCB with the "AT27C1024" eprom ?
ZeBong
ZeBong
" Россия еще раз"
PostPosted: March 23rd, 2009, 5:45
I also get this error while writing ROM :
Any one know why this happens ?
PostPosted: March 25th, 2009, 7:56
Hi Again,
need some help here.
i found other donor disk, i try hot swap and it start clicking.
i try the PCB again in the patiente disk and the same problem.
Now the disk that i have found as a donor, it have 15 days different.... it should work .... this model dont have too much adaptive info.
The different that i see from patiente disk, from the donor disk´s that i try in the ROM chip
the patiente disk have the eprom AT27C1024 and the donor disk have the flash M29F102BB
Any comments are welcome.
ZeBong
" Россия еще раз"
PostPosted: March 25th, 2009, 14:29
eprom AT27C1024
ZeBong
" Россия еще раз"
