HDD GURU FORUMS
http://forum.hddguru.com/
ST380011A Problem
http://forum.hddguru.com/viewtopic.php?f=11&t=12029
Page 1 of 1
Author:  dabihsss [ April 21st, 2009, 0:07 ]
Post subject:  ST380011A Problem
ST380011A model is not detecting , 80Gb detected as 128gb , serial no is correct, can read sa surface, but getting error while reading tracks, can you figure out what is the problem ?
Author:  dmarques [ April 21st, 2009, 4:05 ]
Post subject:  Re: ST380011A Problem
As you can see, the drive is not detected correctly.
So you have to check why. Maybe even the problem is not on the drive, but on cabling.
Author:  dabihsss [ April 21st, 2009, 14:50 ]
Thank you dmarques,
I think you were right, i couln't see anything without connecting terminal, but how can i check my ide connection circuit , can you help me please.
Author:  hddguy [ April 21st, 2009, 14:58 ]
Seems unusual for model to be wrong, but not garbled, and also serial number and all other parameters are correct.
Have you verified a working drive on the channel? Does HDD still give same ID on alternative station, such as MHDD station?
Do you have legitimate Acelab PC3000?
Author:  N.C. [ April 21st, 2009, 15:03 ]
It looks like the drive is ss'ed, or loosed the STUFF.
Janos
Author:  Creator [ April 22nd, 2009, 14:17 ]
Firstly better to show here terminal log.
I could see there reading error (bad heads or corrupted R/W channel on PCB - popular problem on 7200.7)
Author:  hddguy [ April 22nd, 2009, 14:23 ]
this is my suspicion. Also, in my experience, 7200.7 are prone to surface damage and/or dirty heads. terminal would help.
Author:  rameez [ April 26th, 2009, 5:28 ]
You have stuffed the drive with default values use edit hdd ID to correct the problem.
Author:  dabihsss [ April 26th, 2009, 6:05 ]
Terminal Log
Author:  hddguy [ April 26th, 2009, 11:06 ]
Has any physical work been performed on this disk?
Author:  dabihsss [ April 26th, 2009, 23:43 ]
no, i was trying to read using DE , whilw these terminal log
Author:  dmarques [ April 27th, 2009, 20:08 ]
You could swap PCB and check terminal again, but from some quantity of these cases I had in the past I would bet heads are about to die.
http://www.phpbb.com/
