Discussions related to PC-3000
Please no pirated software here!
Who will deal with WD 1600JS-75NCB2 ?
April 23rd, 2009, 22:08
WD 1600JS-75NCB2 PCB burned, ROM burning at the same time, the installation of a good PCB, but abnormal sound, like: DA DA DA STOP DA DA DA STOP DA DA DA STOP ..... how to deal with? thanks
Re: Who will deal with WD 1600JS-75NCB2 ?
April 24th, 2009, 6:32
First you have to check if your donor PCB is compatible with the patient one.
Even if it is, that may happen as when it burned the PCB, burned the preamp as well.
April 24th, 2009, 8:43
If your board is badly damaged, your preamp probably gone also.
