 Post subject: WD800BB problem
PostPosted: April 24th, 2009, 16:02
I have a WD800BB HDD with problem... i need your help, thank.
Carlos
 Post subject: Re: WD800BB problem
PostPosted: April 24th, 2009, 16:22
Does the drive sound normal?
(I.e. Spin up and calibrate.)
Or spin up, click and spin down?
PostPosted: April 24th, 2009, 16:24
The disk spin up, three times click and spin down..
PostPosted: April 24th, 2009, 17:14
Heads I bet...Try disabling one head at a time....
Data Recovery Ireland
PostPosted: April 24th, 2009, 17:36
I had check PCB problems too in some cases on that family with that syntomph´s check that too
PostPosted: April 25th, 2009, 3:48
May be it has bad sectors on SA area. As to
your screen shot, SA FW has not been read.
Rewriting the bad modules or relocating the bad sectors may help.
SalvationData has SA modules relocation option for WD drives.
:idea: Before doing anything, use "head test" option of the PC-3K to be sure that
the problem is not bad head.
Regards,
PostPosted: April 26th, 2009, 17:49
I guess PCB, heads, head alignment, in that order.
PostPosted: April 27th, 2009, 20:14
I think now you have a much clear idea of what might be the problem, every part of the drive :mrgreen:
So you should start to get rid of some options to get somewhere.
PostPosted: April 30th, 2009, 9:48
Hi Gurus,
CK was right. Disabled head 1 and I left only activates the 0, now the disc does not sound (clicks) and spin up normal.
Still it is not recognized totally.
I tested of head 0 and this good.
I did service area format and now it has access to the SA,
Result SA structure test:
the modules are well only in Copy (0) in Copy (1) not.
The cylinders from the -1 to the -19 are good the -20 bad.
SA MODULES LIST
Id:Copy: Importance:Cyl :Head:Sector:Size:Read : Hdr : CS : CS Value: Date : Vers.: Desription
19: 0 : B : -1: 0: 2: 19:Yes : Ok : Ok : D1 :30-07-03:0100W :Loaded part of microprogram code
19: 1 : B : -10: 0: 2: 19:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
1B: 0 : B : -1: 0: 22: 2:Yes : Ok : Ok : 53 :30-07-03:0100W :Loaded part of microprogram code
1B: 1 : B : -10: 0: 22: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
1A: 0 : : -1: 0: 25: 4:Yes : Ok : Ok : 59 :30-07-03:0200? :
1A: 1 : : -10: 0: 25: 4:Yes :Error: Ok : 00 :/WRONG/ :..... :
42: 0 : B : -2: 0: 0: 2:Yes : Ok : Ok : 05 :17-08-03:0202? :Configuration (HDD ID)
42: 1 : B : -11: 0: 0: 2:Yes : Ok : Ok : 05 :17-08-03:0202? :Configuration (HDD ID)
43: 0 : Dd : -2: 0: 3: 360:Yes : Ok : Ok : 91 :30-07-03:0200? :P-List (Primary defect list)
43: 1 : Dd : -11: 0: 3: 360:Yes :Error: Ok : 00 :/WRONG/ :..... :P-List (Primary defect list)
44: 0 : C : -2: 0: 364: 8:Yes : Ok : Ok : B9 :19-08-03:0200? :G-List (Grown defect list)
44: 1 : C : -11: 0: 364: 8:Yes :Error: Ok : 00 :/WRONG/ :..... :G-List (Grown defect list)
59: 0 : Dr : -2: 0: 373: 4:Yes : Ok : Ok : 36 :30-07-03:0100? :T-List (Track defect list)
59: 1 : Dr : -11: 0: 373: 4:Yes :Error: Ok : 00 :/WRONG/ :..... :T-List (Track defect list)
5A: 0 : : -2: 0: 378: 1:Yes : Ok : Ok : A8 :30-07-03:0100? :
5A: 1 : : -11: 0: 378: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :
20: 0 : Ad : -2: 0: 380: 144:Yes : Ok : Ok : 9E :01-01-98:0701? :Translator
20: 1 : Ad : -11: 0: 380: 144:Yes :Error: Ok : 00 :/WRONG/ :..... :Translator
25: 0 : Ad : -2: 0: 525: 15:Yes : Ok : Ok : 81 :01-01-98:0600? :Translator
25: 1 : Ad : -11: 0: 525: 15:Yes :Error: Ok : 00 :/WRONG/ :..... :Translator
23: 0 : B : -2: 0: 541: 6:Yes : Ok : Ok : DB :30-07-03:C807? :Translator
23: 1 : B : -11: 0: 541: 6:Yes :Error: Ok : 00 :/WRONG/ :..... :Translator
4C: 0 : As : -2: 0: 548: 2:Yes : Ok : Ok : BC :30-07-03:0200? :Adaptive data
4C: 1 : As : -11: 0: 548: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data
70: 0 : : -2: 0: 551: 2:Yes : Ok : Ok : 9E :30-07-03:0200? :
70: 1 : : -11: 0: 551: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :
72: 0 : : -2: 0: 554: 2:Yes : Ok : Ok : 9C :30-07-03:0200? :
72: 1 : : -11: 0: 554: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :
74: 0 : : -2: 0: 557: 2:Yes : Ok : Ok : 9A :30-07-03:0200? :
74: 1 : : -11: 0: 557: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :
4D: 0 : As : -2: 0: 560: 2:Yes : Ok : Ok : 6D :30-07-03:0200? :Adaptive data
4D: 1 : As : -11: 0: 560: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data
71: 0 : : -2: 0: 563: 2:Yes : Ok : Ok : 51 :30-07-03:0200? :
71: 1 : : -11: 0: 563: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :
73: 0 : : -2: 0: 566: 2:Yes : Ok : Ok : 4F :30-07-03:0200? :
73: 1 : : -11: 0: 566: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :
75: 0 : : -2: 0: 569: 2:Yes : Ok : Ok : 4D :30-07-03:0200? :
75: 1 : : -11: 0: 569: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :
18: 0 : : -2: 0: 572: 2:Yes : Ok : Ok : 1F :30-07-03:0100? :Table 2 sectors
18: 1 : : -11: 0: 572: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Table 2 sectors
2B: 0 : B : -2: 0: 575: 25:Yes : Ok : Ok : 54 :30-07-03:0100? :S.M.A.R.T. Log
2B: 1 : B : -11: 0: 575: 25:Yes :Error: Ok : 00 :/WRONG/ :..... :S.M.A.R.T. Log
4E: 0 : As : -2: 0: 601: 32:Yes : Ok : Ok : 6A :30-07-03:0100? :Ver. Info Log
4E: 1 : As : -11: 0: 601: 32:Yes :Error: Ok : 00 :/WRONG/ :..... :Ver. Info Log
2C: 0 : B : -3: 0: 0: 10:Yes : Ok : Ok : 35 :30-07-03:0104? :S.M.A.R.T. Log
2C: 1 : B : -12: 0: 0: 10:Yes :Error: Ok : 00 :/WRONG/ :..... :S.M.A.R.T. Log
2E: 0 : B : -3: 0: 11: 21:Yes : Ok : Ok : 49 :30-07-03:0704? :Original S.M.A.R.T. Parameters table
2E: 1 : B : -12: 0: 11: 21:Yes :Error: Ok : 00 :/WRONG/ :..... :Original S.M.A.R.T. Parameters table
5B: 0 : : -3: 0: 33: 1:Yes : Ok : Ok : 36 :30-07-03:0100? :
5B: 1 : : -12: 0: 33: 1:Yes :Error: Ok : 00 :/WRONG/ :..... :
26: 0 : B : -3: 0: 35: 21:Yes : Ok : Ok : 64 :30-07-03:0704? :S.M.A.R.T. Parameters
26: 1 : B : -12: 0: 35: 21:Yes :Error: Ok : 00 :/WRONG/ :..... :S.M.A.R.T. Parameters
22: 0 : B : -3: 0: 57: 6:Yes : Ok : Ok : DF :30-07-03:C807? :Translator
22: 1 : B : -12: 0: 57: 6:Yes :Error: Ok : 00 :/WRONG/ :..... :Translator
48: 0 : As : -3: 0: 64: 2:Yes : Ok : Ok : 1B :30-07-03:0.00? :Adaptive data
48: 1 : As : -12: 0: 64: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data
49: 0 : As : -3: 0: 67: 2:Yes : Ok : Ok : D9 :01-01-98:0.11? :Adaptive data
49: 1 : As : -12: 0: 67: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data
4A: 0 : As : -3: 0: 70: 4:Yes : Ok : Ok : 75 :30-07-03:0100? :Adaptive data
4A: 1 : As : -12: 0: 70: 4:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data
01: 0 : B : -3: 0: 75: 12:Yes : Ok : Ok : 26 :30-07-03:0100W :Loaded part of microprogram code
01: 1 : B : -12: 0: 75: 12:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
36: 0 : B : -3: 0: 88: 38:Yes : Ok : Ok : 6E :30-07-03:0100W :Loaded part of microprogram code
36: 1 : B : -12: 0: 88: 38:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
10: 0 : B : -3: 0: 127: 43:Yes : Ok : Ok : 57 :30-07-03:0100W :Loaded part of microprogram code
10: 1 : B : -12: 0: 127: 43:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
12: 0 : B : -3: 0: 171: 22:Yes : Ok : Ok : 95 :30-07-03:0106W :Loaded part of microprogram code
12: 1 : B : -12: 0: 171: 22:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
11: 0 : B : -3: 0: 194: 62:Yes : Ok : Ok : 8C :30-07-03:0100W :Loaded part of microprogram code
11: 1 : B : -12: 0: 194: 62:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
14: 0 : B : -3: 0: 257: 58:Yes : Ok : Ok : 2D :30-07-03:0100W :Loaded part of microprogram code
14: 1 : B : -12: 0: 257: 58:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
61: 0 : B : -3: 0: 316: 21:Yes : Ok : Ok : 8B :30-07-03:0110W :Flash rewriting microprogram (LDuCODE)
61: 1 : B : -12: 0: 316: 21:Yes :Error: Ok : 00 :/WRONG/ :..... :Flash rewriting microprogram (LDuCODE)
02: 0 : B : -3: 0: 338: 100:Yes : Ok : Ok : 9B :30-07-03:0100W :Loaded part of microprogram code
02: 1 : B : -12: 0: 338: 100:Yes :Error: Ok : 00 :/WRONG/ :..... :Loaded part of microprogram code
BF: 0 : : -3: 0: 439: 2:Yes : Ok : Ok : 41 :30-07-03:0100? :
BF: 1 : : -12: 0: 439: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :
46: 0 : As : -3: 0: 442: 14:Yes : Ok : Ok : 00 :30-07-03:0200? :Adaptive data
46: 1 : As : -12: 0: 442: 14:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data
4B: 0 : As : -3: 0: 457: 3:Yes : Ok : Ok : FA :30-07-03:0100? :Adaptive data
4B: 1 : As : -12: 0: 457: 3:Yes :Error: Ok : 00 :/WRONG/ :..... :Adaptive data
21: 0 : B : -3: 0: 461: 10:Yes : Ok : Ok : 79 :30-07-03:0104? :Event log
21: 1 : B : -12: 0: 461: 10:Yes :Error: Ok : 00 :/WRONG/ :..... :Event log
17: 0 : : -3: 0: 472: 2:Yes : Ok : Ok : 7D :30-07-03:0100? :Table 2 sectors
17: 1 : : -12: 0: 472: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Table 2 sectors
2A: 0 : B : -3: 0: 475: 33:Yes : Ok : Ok : 4D :30-07-03:0100? :S.M.A.R.T. Log
2A: 1 : B : -12: 0: 475: 33:Yes :Error: Ok : 00 :/WRONG/ :..... :S.M.A.R.T. Log
2F: 0 : B : -3: 0: 509: 8:Yes : Ok : Ok : 61 :30-07-03:0100? :S.M.A.R.T. Log (reserved)
2F: 1 : B : -12: 0: 509: 8:Yes :Error: Ok : 00 :/WRONG/ :..... :S.M.A.R.T. Log (reserved)
1E: 0 : : -3: 0: 518: 4:Yes : Ok : Ok : B6 :30-07-03:0100? :
1E: 1 : : -12: 0: 518: 4:Yes :Error: Ok : 00 :/WRONG/ :..... :
5C: 0 : : -3: 0: 523: 2:Yes : Ok : Ok : 2C :30-07-03:0100? :
5C: 1 : : -12: 0: 523: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :
29: 0 : C : -8: 0: 280: 21:Yes : Ok : Ok : 4F :30-07-03:0704? :S.M.A.R.T. Parameters
29: 1 : C : -17: 0: 280: 21:Yes :Error: Ok : 00 :/WRONG/ :..... :S.M.A.R.T. Parameters
2D: 0 : C : -8: 0: 303: 21:Yes : Ok : Ok : 4B :30-07-03:0704? :S.M.A.R.T. Parameters
2D: 1 : C : -17: 0: 303: 21:Yes :Error: Ok : 00 :/WRONG/ :..... :S.M.A.R.T. Parameters
FF: 0 : Dr : -6: 0: 0: 705:Yes : Ok : Ok : 27 :04-08-03:588G? :Selfscan module
FF: 1 : Dr : -15: 0: 0: 705:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan module
D4: 0 : Dr : -1: 0: 30: 144:Yes : Ok : Ok : 27 :07-10-02:588G? :Selfscan test microprogram
D4: 1 : Dr : -10: 0: 30: 144:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
D5: 0 : Dr : -1: 0: 174: 144:Yes : Ok : Ok : 5C :07-10-02:588G? :Selfscan test microprogram
D5: 1 : Dr : -10: 0: 174: 144:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
D6: 0 : Dr : -1: 0: 318: 144:Yes : Ok : Ok : C0 :07-10-02:588G? :Selfscan test microprogram
D6: 1 : Dr : -10: 0: 318: 144:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
C4: 0 : Dr : -1: 0: 514: 109:Yes : Ok : Ok : 30 :04-08-03:L.0KW :Calibrations module
C4: 1 : Dr : -10: 0: 514: 109:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations module
C5: 0 : Dr : -1: 0: 623: 3:Yes : Ok : Ok : A2 :15-07-03:L.08? :Calibrations log (DCM)
C5: 1 : Dr : -10: 0: 623: 3:Yes :Error: Ok : 00 :/WRONG/ :..... :Calibrations log (DCM)
EF: 0 : Dr : -1: 0: 626: 72:Yes : Ok : Ok : 21 :04-08-03:58XXW :Selfscan test microprogram
EF: 1 : Dr : -10: 0: 626: 72:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
E2: 0 : Dr : -1: 0: 698: 74:Yes : Ok : Ok : D3 :04-08-03:58XXW :Selfscan test microprogram
E2: 1 : Dr : -10: 0: 698: 74:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
E4: 0 : Dr : -2: 0: 634: 50:Yes : Ok : Ok : E1 :04-08-03:58XXW :Selfscan test microprogram
E4: 1 : Dr : -11: 0: 634: 50:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
E5: 0 : Dr : -2: 0: 684: 74:Yes : Ok : Ok : 45 :04-08-03:58XXW :Selfscan test microprogram
E5: 1 : Dr : -11: 0: 684: 74:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
D9: 0 : Dr : -3: 0: 526: 74:Yes : Ok : Ok : 14 :04-08-03:58XXW :Selfscan test microprogram
D9: 1 : Dr : -12: 0: 526: 74:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
E3: 0 : Dr : -3: 0: 600: 55:Yes : Ok : Ok : 6C :04-08-03:58XXW :Selfscan test microprogram
E3: 1 : Dr : -12: 0: 600: 55:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
F3: 0 : Dr : -3: 0: 655: 52:Yes : Ok : Ok : 59 :04-08-03:58XXW :Selfscan test microprogram
F3: 1 : Dr : -12: 0: 655: 52:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
E7: 0 : Dr : -3: 0: 707: 51:Yes : Ok : Ok : F7 :04-08-03:58XXW :Selfscan test microprogram
E7: 1 : Dr : -12: 0: 707: 51:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
E9: 0 : Dr : -7: 0: 0: 94:Yes : Ok : Ok : 5D :04-08-03:58XXW :Selfscan test microprogram
E9: 1 : Dr : -16: 0: 0: 94:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
ED: 0 : Dr : -7: 0: 94: 60:Yes : Ok : Ok : FC :04-08-03:58XXW :Selfscan test microprogram
ED: 1 : Dr : -16: 0: 94: 60:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
F2: 0 : Dr : -7: 0: 154: 49:Yes : Ok : Ok : A9 :04-08-03:58XXW :Selfscan test microprogram
F2: 1 : Dr : -16: 0: 154: 49:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
F4: 0 : Dr : -7: 0: 203: 74:Yes : Ok : Ok : 39 :04-08-03:58XXW :Selfscan test microprogram
F4: 1 : Dr : -16: 0: 203: 74:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
F5: 0 : Dr : -7: 0: 277: 73:Yes : Ok : Ok : 9E :04-08-03:58XXW :Selfscan test microprogram
F5: 1 : Dr : -16: 0: 277: 73:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
FD: 0 : Dr : -1: 0: 772: 5:Yes : Ok : Ok : 86 :04-08-03:`T0Q? :Selfscan log
FD: 1 : Dr : -10: 0: 772: 5:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan log
FB: 0 : Dr : -7: 0: 350: 50:Yes : Ok : Ok : 06 :04-08-03:58XXW :Selfscan test microprogram
FB: 1 : Dr : -16: 0: 350: 50:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
D3: 0 : Dr : -7: 0: 400: 68:Yes : Ok : Ok : 8E :04-08-03:58XXW :Selfscan test microprogram
D3: 1 : Dr : -16: 0: 400: 68:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
D2: 0 : Dr : -7: 0: 468: 49:Yes : Ok : Ok : 94 :04-08-03:58XXW :Selfscan test microprogram
D2: 1 : Dr : -16: 0: 468: 49:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
D7: 0 : Dr : -7: 0: 517: 54:Yes : Ok : Ok : BF :04-08-03:58XXW :Selfscan test microprogram
D7: 1 : Dr : -16: 0: 517: 54:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
D8: 0 : Dr : -7: 0: 571: 49:Yes : Ok : Ok : 83 :04-08-03:58XXW :Selfscan test microprogram
D8: 1 : Dr : -16: 0: 571: 49:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
DA: 0 : Dr : -7: 0: 620: 74:Yes : Ok : Ok : 49 :04-08-03:58XXW :Selfscan test microprogram
DA: 1 : Dr : -16: 0: 620: 74:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
FA: 0 : Dr : -8: 0: 0: 72:Yes : Ok : Ok : D4 :04-08-03:58XXW :Selfscan test microprogram
FA: 1 : Dr : -17: 0: 0: 72:Yes :Error: Ok : 00 :/WRONG/ :..... :Selfscan test microprogram
C3: 0 : : -2: 0: 758: 37:Yes : Ok : Ok : BA :04-08-03:B.08W :
C3: 1 : : -11: 0: 758: 37:Yes :Error: Ok : 00 :/WRONG/ :..... :
41: 0 : : -1: 0: 0: 2:Yes : Ok : Ok : 9B :17-08-03:773RW :Modules directory
41: 1 : : -10: 0: 0: 2:Yes :Error: Ok : 00 :/WRONG/ :..... :Modules directory
Zone allocation table
Number of zones......................... : 2
# : Initial cylinder : Final cylinder : SPT
0 : -32 : -1 : 820
1 : 0 : 87 905 : 861
CONFIGURATION SECTOR (42)
SA Copy num Location Status
0 c: -2 H: 0 Ok
1 c:-11 H: 0 Ok
HDD ID
Model................................... : WDC WD800BB-75DKA0
Serial number........................... : WD-WMAHL3333858
Logical parameters...................... : Cyl : 155072 Head : 16 Sec : 63
Master-password
Set..................................... : No
User-password
Security level.......................... : High
Log DCM (C5)
0 c: -1 H: 0 Ok
1 c:-10 H: 0 Header
XEN Xenon 40
+ XEN codata L.08 ----- Drive Head DCM Codes -----+
| READ-RITE: F, 0, 7, Y ( zero offset head) |
| HEADWAY: D, 8, 9 ( zero-offset head) |
| ALPS: A ( zero-offset head) |
| ALPS: L, J, H, R (non-zero offset head) |
Avalable scripts
"B" - B9XENL.08
"_" - _9XENL.08
"V" - V9XENL.08
"T" - T9XENL.08
"A" - A9XENL.08
Log Version Info (4E)
0 c: -2 H: 0 Ok
1 c:-11 H: 0 Header
ROM version............................. : .......
Link table version...................... : ......
Disk FW version......................... : .......
P-List (43)
0 c: -2 H: 0 Ok
1 c:-11 H: 0 Header
Number of defects....................... : 684
G-List (44)
0 c: -2 H: 0 Ok
1 c:-11 H: 0 Header
Number of defects....................... : 83
That I need so that is recognized totally?
(excuse me for my english)
thank,
Carlos
PostPosted: April 30th, 2009, 18:17
Well that errors wich u get on the SA report are caused because u disable COPY 1, tried to enable head, 1 if knocks , u have head 1 bad, if no knocks check SA , maybe are translator modules on COPY 1 bad , or another modules
