| Need map module (01h) for WD5000AAVS-00ZTB0 http://forum.hddguru.com/viewtopic.php?f=11&t=12065 |
Page 1 of 1 |
| Author: | drc [ April 25th, 2009, 11:08 ] |
| Post subject: | Need map module (01h) for WD5000AAVS-00ZTB0 |
Need map module (01h) for WD5000AAVS-00ZTB0... thanks. |
| Author: | hddguy [ April 25th, 2009, 16:53 ] |
| Post subject: | Re: Need map module (01h) for WD5000AAVS-00ZTB0 |
arent these modules unique to each drive? |
| Author: | drc [ April 26th, 2009, 17:46 ] |
Possible. The two that I have are different. The relevant one seems to be bad, in that it appears to only correctly indicate the positions of the first five or so modules. I suppose my next step is to try to figure out how to manually correct it. |
| Author: | zebong [ April 26th, 2009, 18:08 ] |
HI, i have this drive: WDC WD5000AAVS-32ZTB0 01.01B01 WD-WMASU0309528 it help you ? ZeBong |
| Author: | Mikippp [ April 27th, 2009, 7:40 ] |
Hi, U not need file 01.rpm from other drive... Module with modules table catalog is saved in the beginning of the track -170 on system heads... Modules table have additional copy in SA - module 110.rpm contains base part of modules table catalog... Mikippp |
| Author: | guru [ April 27th, 2009, 9:37 ] |
also make sure model is supported correctly by acelabia |
| Author: | drc [ April 27th, 2009, 14:00 ] |
zebong wrote: HI, i have this drive: WDC WD5000AAVS-32ZTB0 01.01B01 WD-WMASU0309528 it help you ? ZeBong I'd love to take a look at it, even just for scientific purposes. Mikippp wrote: Module with modules table catalog is saved in the beginning of the track -170 on system heads... Modules table have additional copy in SA - module 110.rpm contains base part of modules table catalog... Interesting. To add to the confusion I'm using the salvation tools in combination with ATA register commands. I'm not certain that the salvation numbering system is the same as PC3K (in some other drives in the past it has been different), but what I'm looking for is the module that begins with "52 4F 59 4C 01 00 30 00 01 00". When I change this module with one from a different drive that I have, it changes the position the salvation utility is looking at for module loading, so I was assuming this was what the drive used as well. Perhaps it is not. |
| Author: | zebong [ April 27th, 2009, 14:05 ] |
PM me your email for send you. |
