Sagate 7200.9 ST3160812A Of unable To Of load Of overlay
Posted: April 29th, 2009, 15:44
by xsx007
P) PATA Of reset
Failed of sys of sect. write
Read Of ver Of retrys
Read Of ver Of falture!
Unable To Of load Of overlay 01|000A
I want to Recovery Data??
Re: Sagate 7200.9 ST3160812A Of unable To Of load Of overlay
Posted: April 29th, 2009, 21:38
by Doomer
There are some guys in China which probably can help you. If you willing to pay a lot I also can find a Russian guy in China who's a guru in DR
Posted: May 2nd, 2009, 0:21
by -BR-
Hi xsx007
we have many cases like yours
to recover data from this condition, you will have to perform head-swap
-BR-
Posted: May 3rd, 2009, 22:56
by prodata
and need several Set of Donor Head
Posted: October 15th, 2009, 13:33
by StuKeR
Perhaps it's not necessary to do a head swap. By hyperterminal you can send some commands to Force to writte the sys sec.
Posted: October 15th, 2009, 16:00
by pepe
I does not work in all of the cases. There could be a hardware cause of inability to write on H0.
In this case u cannot force writing. U can, but it won't do anything useful... :)
MHA replacement solves the problem in most of the cases when it is HW issue.
Posted: October 15th, 2009, 16:06
by N.C.
even if the hw problem in the pcb? :P
Posted: October 15th, 2009, 17:35
by pepe
I said 'most of the cases'.
In most of the cases the cause is not the pcb. At least I never met a PCB that prevented writing, but I met several cases when the MHA caused such problem.
Posted: October 15th, 2009, 17:58
by N.C.
you are right.
I haven't seen this too.
Only i can imagine the situation, but only in the extreme category.
Janos
Posted: October 15th, 2009, 18:22
by pepe
thx for agreeing :D
