 Post subject: How to fix a MAXTOR 6E040L0 40GB IDE
PostPosted: February 10th, 2009, 10:35
Hi , need some help how to fix this drive.
the sounds is like this :
6E040L0-40GB-IDE.zip [485.2 KiB]
Downloaded 1317 times
Put the disk in safe mode and enter the utility:
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: How to fix a MAXTOR 6E040L0 40GB IDE
PostPosted: February 10th, 2009, 13:15
From the sound of the drive, it appears that heads and/or media are bad. However, you can try the following: after loader loads, you should run 1) HDD ID reading (which it looks like you did) to make sure firmware number changes to end in 0, and 2) Run Initialize HDD/Initialize all which, if proper loader has loaded, will correctly ID the drive. You should try several loaders to see if you can reach this stage. At that point you can try to read SA. If unsuccessful with loader then try hotswap with same model.
PostPosted: February 10th, 2009, 13:32
You have to check head condition and fix SA
www.datarecoveryne.com
PostPosted: February 16th, 2009, 12:39
Hi to all,
I try the loader for this model but i can not work.
Also do hot swap and dont work.
How can i open this disk ... ? to check the Heads.
Should i try more loaders i just have 3, if so can anyone send to me.
ZeBong
ZeBong
" Россия еще раз"
PostPosted: March 6th, 2009, 15:52
Afther open the disk, notice that the filter is very dirty, and the platte is like this:
ZeBong
" Россия еще раз"
PostPosted: March 6th, 2009, 17:07
Case closed.
I have some similar from N40P.... :)
Janos
PostPosted: May 26th, 2009, 9:11
How I Can to got this Utilitity load my LDR??
PostPosted: May 26th, 2009, 10:36
This is the PC3000 UDMA on the pic.
You need to buy it.
Janos
Users browsing this forum: No registered users and 6 guests
