| HD753LJ http://forum.hddguru.com/viewtopic.php?f=11&t=12475 |
Page 1 of 1 |
| Author: | zebong [ June 10th, 2009, 13:41 ] |
| Post subject: | HD753LJ |
Hi to all, Have this disk HD753LJ, anyone knows in UDMA how can i see the terminal ? The PC-Seagate terminal works here ? Thanks |
| Author: | N.C. [ June 10th, 2009, 14:22 ] |
| Post subject: | Re: HD753LJ |
Yes, you can use the terminal, but i have used my own, made by myself.... For the case, let me guess: The drive can init, appears in BIOS, you can read until about 21-26G, and than starts to clicking hardly... No? Janos |
| Author: | zebong [ June 10th, 2009, 14:25 ] |
Hi Janos, Do not know yet , i am cloning other disk, them i will connect the Samsung, The disk have been drop to the floor, i think the heads should be BAD. |
| Author: | zebong [ June 10th, 2009, 14:51 ] |
I can see the terminal log The log is this: Code: ++ SU MaxPhyHead = 0006 RPM at Handoff: 0204 PwrOnPhy@USSHOS - Released on 2008/01/26 13:15 by jiwon47.ha DRAM=32MB SoC=26A3 SHOS-(1AA08caM.a28) L=00000000,00000000 <SpinOn_2>KeepSpinOn! RV Circuit Enabled Temp : 24 degC SpinOk mServoStatus1 00000003 UF 3 1stGrayErr Vel Parking! PK_3 C: 0 H:0 SK C: 99685 H:1 S_2 0000000A 0000000A 00000000 00000000AP:1 C: 2000 H:0Vel Parking! PK_3 C: 2149 H:0 SK C:100840 H:1 S_2 00000097 00000097 00000000 00000000AP:1 C: 2000 H:0Vel Parking! PK_3 C:100840 H:0 SK C: 99315 H:1 S_2 000000C9 000000C9 00000000 00000000AP:1 C: 2000 H:0Vel Parking! PK_3 C: 99315 H:0 SK C: 98943 H:1 S_2 00000026 00000026 00000000 00000000AP:1 C: 2000 H:0Vel Parking! PK_3 C: 98943 H:0 SK C: 99290 H:1 S_2 0000007D 0000007D 00000000 00000000AP:1 C: 2000 H:0Vel Parking! PK_3 C: 99290 H:0 SK C:100735 H:1 S_2 00000024 00000024 00000000 00000000AP:1 C: 2001 H:0Vel Parking! PK_3 C:100735 H:0 SK C:100523 H:1 S_2 00000066 00000066 00000000 00000000AP:1 C: 2000 H:0Vel Parking! PK_3 C:100523 H:0 SK C: 97869 H:1 S_2 000000EF 000000EF 00000000 00000000AP:1 C: 2000 H:0Vel Parking! PK_3 C: 97869 H:0 SK C:100303 H:1 S_2 00000035 00000035 00000000 00000000AP:1 C: 1999 H:0Vel Parking! PK_3 C:100302 H:0 SK C: 98797 H:1 S_2 000000B1 000000B1 00000000 00000000AP:1 C: 2000 H:0Vel Parking! PK_3 C: 98798 H:0 SK C: 99361 H:1 S_2 0000003F 0000003F 00000000 00000000AP:1 C: 2001 H:0Vel Parking! PK_3 C: 99360 H:0 SK C: 99218 H:1 S_2 000000AB 000000AB 00000000 00000000AP:1 C: 2001 H:0Vel Parking! PK_3 C: 99217 H:0 SK C:100757 H:1 S_2 00000033 00000033 00000000 00000000AP:1 C: 2000 H:0Vel Parking! PK_3 C:100758 H:0 SK C: 98879 H:1 S_2 00000081 00000081 00000000 00000000AP:1 C: 1999 H:0Vel Parking! PK_3 C: 98878 H:0 SK C: 99392 H:1 S_2 000000D7 000000D7 00000000 00000000AP:1 C: 1999 H:0Vel Parking! PK_3 C: 99392 H:0 SK C:100494 H:1 S_2 0000000A 0000000A 00000000 00000000AP:1 C: 2000 H:0Vel Parking! PK_3 C:100494 H:0 SK C: 98533 H:1 S_2 00000079 00000079 00000000 00000000AP:1 C: 2000 H:0Vel Parking! PK_3 C: 98533 H:0 SK C: 99284 H:1 S_2 000000D1 000000D1 00000000 00000000AP:1 C: 2000 H:0Vel Parking! PK_3 C: 99284 H:0 SK C: 98124 H:1 S_2 0000002E 0000002E 00000000 00000000AP:1 C: 2000 H:0Vel Parking! I connect a good disk and have this: PSL ++ SU MaxPhyHead = 0006 RPM at Handoff: 01F2 UtSHOS - Released on 2009/01/19 13:27 by heewoo.chun DRAM=32MB SoC=26A3 SHOS-(1AA13fyM.a38) L=00000000,00000000 <SpinOn_2>KeepSpinOn! RV Circuit Enabled Temp : 24 degC SpinOk SK C:115313 H:0 ServoTable Loaded FdtTable Loaded Hd: 0 Zn: 0 Avg.:- 131 Hd: 0 Zn: 1 Avg.: 118 PASS | 21 | SET_MAX | 3 | 0 | 142 | B98B | | 21 | SET_MAX | 3 | 1 | 142 | B98B | | 21 | SET_MAX | 3 | 2 | 142 | B98B | | 22 | SECURITY | 3 | 0 | 143 | B98B | | 22 | SECURITY | 3 | 1 | 143 | B98B | | 22 | SECURITY | 3 | 2 | 143 | B98B | | 159 | DCO | 31 | 0 | 0 | B98B | | 159 | DCO | 31 | 1 | 0 | B98B | | 159 | DCO | 31 | 2 | 0 | B98B | RecordValid : 00078021 No DRM 1.5G Lp00,PwrOnDn ENG> |
| Author: | N.C. [ June 10th, 2009, 15:05 ] |
yep Heads are gone. You need to exchange MHA to do this rec. Janos |
| Author: | BlackST [ June 11th, 2009, 0:32 ] |
May be limited to head 0 and 1 but yes, need to change MHA. Drive dropped? |
