| Broken Maxtor ARES C64K http://forum.hddguru.com/viewtopic.php?f=11&t=12719 |
Page 1 of 1 |
| Author: | patknott [ July 12th, 2009, 8:26 ] |
| Post subject: | Broken Maxtor ARES C64K |
Hello Guys, i have here an broken Maxtor Drive. It dosn't make sounds like a broken Device. In the Bios it is recognizing as Maxtor ARES C64K. Could somebody help me, i don't have a PC-3000 Device but i read that this is the only way to fix the Firmware? I still need the Data. Greetings from Germany, Patrick |
| Author: | BlackST [ July 12th, 2009, 10:39 ] |
| Post subject: | Re: Broken Maxtor ARES C64K |
Want to send the drive for recovery, then? |
| Author: | pcimage [ July 12th, 2009, 13:14 ] |
Sorry to say that you have a firmware problem, but it cannot be properly diagnosed or repaired without proper (expensive) equipment such as PC3000, Salvation or Atola. If you're prepared to send to UK, I can almost certainly recover the data for a reasonable price. Or member "falther" is in Austria and also has the appropriate kit. Cheers Sean |
| Author: | dobrevjetser [ July 13th, 2009, 2:30 ] |
Drives form Germany arrive here too Sie konnen uns ruhig die festplatte zuschicken wenn Sie wollen. Wir machen Sie ein kostenloses angebot. Mfg, Dobre |
| Author: | pcimage [ July 13th, 2009, 3:24 ] |
Dobre is recognised pro here on this forum, based in Belgium. He too can resolve this problem, which unfortunately cannot be DIY'd. |
