 Post subject: WD2500AAKS - 00B3A0 Rom
PostPosted: September 4th, 2009, 8:21
Anyone have a rom from this disk please
Also can somebody tell me its family name?
Zero Alpha: zeroalpha.com.au
 Post subject: Re: WD2500AAKS - 00B3A0 Rom
PostPosted: September 5th, 2009, 8:17
WD2500AAKS-00B3A0 -> Pinnacle
Mikippp
PostPosted: September 5th, 2009, 9:07
Thanks soooooooo much... See if I can fix it now.
PostPosted: September 8th, 2009, 9:27
do you still need ROM for this?
PostPosted: September 9th, 2009, 8:25
Yes please, I'm still chasing a ROM.
PostPosted: September 9th, 2009, 11:10
Can you not recreate from SA modules?
PostPosted: September 9th, 2009, 21:01
This drive will not spin up because i'm suspecting a pcb/rom failure. I have a donor pcb from a different family that will spin the drive but I need the correct rom so that I can disable heads as the drive is clicking. It looks like this drive has 2 problems so far, dead pcb and probably dead heads. A rom with correct head map would be very handy for this job.
PostPosted: September 9th, 2009, 23:31
I think that will be difficult as you would need to match the version, which if you can't see the modules to get the correct version number will be shooting in the dark...
PostPosted: September 10th, 2009, 10:00
Yes its going to be difficult. Having 2 separate problems makes it more fun right? My strategy is to get a working ROM then I can diagnose why heads are clicking. Fix the clicking and regen the ROM. Customer gets data back and I earn my income. :) :)
ROM anyone?
